Panasonic Lumix - Lightroom color profiles
Started Apr 14, 2017 | Discussions
bsas
bsas Contributing Member • Posts: 620
17
Hi all,
Since Adobe released the new Camera Raw patch with the DCP (Camera Profile) files for the GH5, I am converting those to support "older" cameras (like mine G85) and, even if I cannot ensure color accuracy (of course, because the cameras are different), I think the color profiles are close enough. Anyway, it is better then nothing.
If you want to try yourself be my guest and let me know if it works for you. Here is the list of the ones I converted. You just need to copy all DCP files to the folder:
C:\Users\{user name}\AppData\Roaming\Adobe\CameraRaw\CameraProfiles
If you miss your camera, please let me know:
Panasonic G85/G80/G81:
https://www.dropbox.com/s/73hy8aqpdrewonc/Panasonic%20DMC-G8.zip?dl=0
Panasonic G7:
https://www.dropbox.com/s/e5baunnjdise3j8/Panasonic%20DMC-G7.zip?dl=0
Panasonic GM1:
https://www.dropbox.com/s/p6u9toj872b2rxs/Panasonic%20DMC-GM1.zip?dl=0
Panasonic GM5:
https://www.dropbox.com/s/07x6sl9vo7i1r8o/Panasonic%20DMC-GM5.zip?dl=0
Panasonic GX8:
https://www.dropbox.com/s/tp3kbo6jutq7s7u/Panasonic%20DMC-GX8.zip?dl=0
Panasonic GX85/GX80/GX7 Mark II:
https://www.dropbox.com/s/sv19oj4fi2wgh80/Panasonic%20DMC-GX85.zip?dl=0
 bsas's gear list:bsas's gear list
Sony a7 III Sony a7R III Sony Alpha NEX-7 Sony a7R Tamron 28-75mm F2.8 III +12 more
Minstadave Regular Member • Posts: 381
Re: Panasonic Lumix - Lightroom color profiles
Thank you for sharing this, going to try them out now
 Minstadave's gear list:Minstadave's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Olympus M.Zuiko Digital 45mm F1.8 +4 more
Keit ll Veteran Member • Posts: 4,674
Many thanks, Just installed the GX-80 profiles, they look promising & are significantly different from the Adobe Standard profile.
PS - if anyone has trouble finding the Roaming file , type %appdata% in start search box.
These are great, thank you!
Bruce McL Senior Member • Posts: 1,409
People should expect some unusual behavior when adjusting white balance with these profiles. It's hard to explain exactly what happens, but I'll try:
When you leave the white balance on "As Shot" and change profiles, the colors will look pretty good, but you will see the numbers for tone and/or temperature change. If you adjust the white balance tone and temperature sliders or use another preset while you are in Adobe Standard, then the numbers will not change when you change profiles. This will usually make the new profile look worse than it did when using it "as shot."
The workaround for this is to use the ColorMatrix1 and ColorMatrix2 data from the Adobe Standard profile of the camera you are converting to. This will make the white balance numbers match Adobe Standard. However it will affect the color somewhat. How much depends on the camera.
"Anyway, it is better then nothing."
I don't think that is always true. Downloading a few RAW files from each camera and trying the profiles out would be a good idea before releasing the profiles to the public.  Photographyblog and Imaging-Resource are two good sources for RAW files.
bsas
OP bsas Contributing Member • Posts: 620
Did you tried the files or do you just think that behavior will happen for sure? I am just curious.
One of the reasons I built those is exactly because the "color science" on the GH5 "should" be close enough from the other Lumix cameras, and it is the first time Adobe released a Lumix color set.
Unfortunetly there is no "Adobe Standard" DCP file for those cameras (at least I couldn't find). If you know where they are let me know and I will fix those.
One of the main reasons I am sharing these is for people to tryout. I am not promising they will work. Another reason is try to show Adobe that there is a demand for this, so they can build a proper set.
I politely disagree
If the select box has 1 option only (so you just can't change it) or a bunch, even if the behavior is a little off, at least you can tweak it.
Sorry, I just don't have time for trying all those profiles with every single camera RAW. That is why I am asking the people from the forum to help me test and tweak it.
If you don't want to download my "broken profiles", be my guest
I just think that sharing those at least can (I hope) call some attention from Adobe about the demand for it.
I have tried this on many profiles for many different cameras myself. This time around I looked at your GX8 profiles.
They are in a different folder. Where you see the Camera files, go to the enclosing folder and you will see "Camera" and "Adobe" folders. Adobe Standard for all cameras are loose in the "Adobe" folder.
I politely disagree
In Adobe Standard, set white balance to "As Shot."
Switch to your profile.
Don't go back, but go forward and switch back to Adobe Standard.
Change the color temperature by 50 degrees.
Go forward and switch to your profile.
Using history, compare the first and second time you switched to your profile. The colors will not be 50 degrees apart. They will be much more different than that. The difference will vary from camera to camera.
I don't think that's a good thing to do to other people.
At least you could warn people: please switch to "As Shot" before switching to these profiles.
bsas
Got it! I found the Standard profiles, and yes, looks like it behaves "better" replacing the "ColorMatrix1/2" sections with the original camera standard profiles.
I will rebuild the GX8 for you to test it out, is that OK?
I just can test my G85 files.
bsas
Can you please try those modified ones:
They are using the ColorMatrix1/2 of the GX8
It's not about me, I build my own profiles. it's about being nice to all the people who download your profiles. You can download GX8 RAW files at the bottom of this page and test on them yourself.
http://www.photographyblog.com/reviews/panasonic_lumix_dmc_gx8_review/sample_images/
It may not seem like it, but you are a software developer now. I have worked for software developers in the past. If you want to have happy users, a good reputation, and to be proud of your work, then testing is important.
bsas
Man, I am not a software developer "now", I am a software engineer for the past 20 years. So, that is very condescending and quite rude from you to say since you don't know me or my work. And I know the importance of testing, obviously.
But it is not "my work" or "my reputation" or even "my product" here. I did nothing. I am just recompiling Adobe profiles for whoever wants to use it. So, I cannot put time, effort or even "staple" as "my work", it is illegal. I would be "selling" Adobe's proprietary rights.
But I also know, as a "computer person", that a lot of people are intimidated by tools like the dcpTool that is a command line compiler/decompiler of XML to DCP files in the command line. And a lot of people don't build their own profiles like you do.
So, my only idea with this post was to help people.
I don't agree that keeping those files just to myself would be better. Also, I am not a professional color engineer, so, I cannot ever built a accurate profile to provide as "my own work". That is why I even stated at the beginning that I cannot assure accuracy and those are not "my profiles", just converted profiles from the original Adobe GH5.
If you provide your own profiles, cool! I would definitely check them out.
But that is not the purpose of this forum post. I am NOT providing "my own" profiles. This is Adobe's "adapted/recompiled" ones for people that can't open a command line and do it themselves.
If you don't want to test or help, fine. Just don't point out as I am misleading anyone, because I am not.
Jack Deeman Regular Member • Posts: 161
bsas wrote:
Hi all,
Panasonic G7:
Panasonic GM1:
Panasonic GM5:
Panasonic GX8:
Can this work with Lightroom CC?  I have a mac and don't see a similar folder to put these files into.  Cheers, JD.
 Jack Deeman's gear list:Jack Deeman's gear list
Canon PowerShot S100 Fujifilm X100F Nikon D7000 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +10 more
Paulmorgan Veteran Member • Posts: 8,948
Jack Deeman wrote:
bsas wrote:
Hi all,
Panasonic G7:
Panasonic GM1:
Panasonic GM5:
Panasonic GX8:
There are two folders for profiles, one for Adobes and a second for your own.
The above address takes you to the folder for our own profiles, you won`t find any of adobes profiles in that folder.
Adobes profiles are here.
C/ProgramData/Adobe/CameraRaw/CameraProfiles/Camera
Your own go here
valsan Contributing Member • Posts: 685
Thanks bsas. The colours for the GM1 are too red.
bsas
Sorry to hear
Probably the sensor on the GM1 is too different from the GH5. Nothing I can do to help.
Stejo
Stejo Senior Member • Posts: 1,461
Checking G7's profiles, they're pretty interesting. They're not identical to the in camera ones, but they're a fun tool to have available in lightroom regardless.
Natural seems to be identical to portrait though. Could it be that you mixed them up when compiling?
 Stejo's gear list:Stejo's gear list
Panasonic Lumix DMC-G7 Panasonic GH5 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Lumix G 25mm F1.7 ASPH Samyang 12mm F2.0 NCS CS +7 more
bsas
I can double check but I don't think so.
There is no way to make them identical unless if Adobe does it
Stejo
Yea, they're not identical after all, should've looked closer. There's a tiny difference that's imperceptible to my eyes but I can see it in the histogram if I look really close. Weird, these 2 profiles are quite different in camera.
Anyway, you're certainly not the one to blame for their accuracy. Thanks for providing them.
RobertG_Berlin Regular Member • Posts: 103
Thank you bsas! o)
I just found your profiles and they do a great job for me.
With these profiles, it's very easy to match what the camera jpg engine produces. Even if they are not 100% exact, they're so close that I don't care about small bits being off. I always had trouble getting the images to look similar to the jpgs the camera produces in a reasonable amount of time.
This seems to be past from now on and makes me think to quit shooting jpg+raw and to stick with raw only instead from now on. The OOC jpgs are quite ok for many situations, so being able to create that look in ACR *quickly* is a huge step up.
A big thank you to you! o)
 RobertG_Berlin's gear list:RobertG_Berlin's gear list
Panasonic Lumix DMC-FX01 Panasonic Lumix DMC-FZ28 Kyocera Finecam S3 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-G6 +14 more
bsas
RobertG_Berlin wrote:
Thank you bsas! o)
No problem, but Adobe just released an update to Lightroom with the "official" profiles, and they are more accurate then the ones I got, so, I recommend you to update your Lightroom and remove my profiles
