Hot pixels: fact of life in the old CCD Canons?
Started Apr 5, 2017 | Discussions
Kung Fu
Kung Fu Veteran Member • Posts: 3,990
My new (old) G6 has about six stuck/hot pixels. My SD770 had about three, out of the box.
I'm surprised Canon never added an automated hot pixel mapping feature. Both of my Olys from the same vintage ('04) have it.
So would you return an eBay camera for it, or should I just clone them out and be happy? 😜
Canon PowerShot G6
Geodude Contributing Member • Posts: 596
Re: Hot pixels: fact of life in the old CCD Canons?
Return if just bought second hand off EBay!
 Geodude's gear list:Geodude's gear list
Panasonic Lumix DMC-FZ50 Canon PowerShot G1 X Canon PowerShot SX50 HS
rpm40
rpm40 Senior Member • Posts: 2,411
I was glad to have the feature on my old Oly's, I remember not many cameras offered pixel mapping at that time.
If you like the camera and want to keep it otherwise, good news! You can use CHDK which has a pixel mapping feature (not to mention adding a lot of other nice options):
https://www.dpreview.com/forums/post/26604667
Edit: I don't see your models specifically listed, but some models will work anyway and have just not been tested. You could give it a shot.
reyalp Regular Member • Posts: 201
To be clear, we recommend against trying to run a CHDK build for a different model. There are a few a cases where Canon just re-badged the same internals, but that should be verified with a firmware dump rather than trying to run other builds.
CHDK is available for the SD770 (aka IXUS 85). The G6 will almost certainly never will be supported because it's a Digic 1 camera.
Kung Fu
OP Kung Fu Veteran Member • Posts: 3,990
Thanks guys. Honestly it's not that big of a deal, and at the prices 2004 cameras are going for, I just ordered a second G6. I'll keep the "bad" one as a backup. Fingers crossed that the next one has fewer or no stuck pixels!
OzarkAggie Senior Member • Posts: 2,153
DxO will correct stuck pixels, and I think PhotoShop does it too.
It's not the camera...
 OzarkAggie's gear list:OzarkAggie's gear list
Canon PowerShot A590 IS Canon PowerShot G1 Canon PowerShot Pro1 Canon EOS 10D Canon EOS M +11 more
Kung Fu
Update
Second eBay G6 arrived. About five or six stuck pixels again. 😕 Oh well, I'll live with it. Otherwise it's such a cool camera, can't wait to put it to good use.
