Xf 35mm f/2 or Xf 50mm f/2?
Started Apr 5, 2017 | Discussions
davidleunufna New Member • Posts: 4
hey guys! so i need a prime lens for my xt10, because its hard taking photos in indoor events with low lighting such concerts. i only had 18-55 f2.8 for now and was thinking to get either 35mm f2 or the newest 50mm f2. i never realky tried both of them, so maybe can someone give me recommendations which one should i choose.
i mostly gonna use them for streetphotography 20% ,indoor events 30%, sports 10%, candid/portrait 40%.
thnaks in advance!
 davidleunufna's gear list:davidleunufna's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS +1 more
Fujifilm 50mm F2 R WR Fujifilm XF 35mm F2 R WR Fujifilm X-T10
Rod McD Veteran Member • Posts: 8,589
Re: Xf 35mm f/2 or Xf 50mm f/2?
thnaks in advance!
Hi,
Of the two, I think I'd be tempted to go for the 50/2 for indoor events, sports & portraits.  Street can be shot with a wide range of FLs.  Bear in mind that f2 lenses are only one stop faster than the 18-55 at the wide end.  They're two stops faster at the long end, which is a more significant gain.  (To go to the 56/1.2 would certainly involve spending a lot more.)
If you're more inclined to try the 35mm and indoor / low light street shooting are your main interest I'd consider whether you may wish to spend a tad more to go to the 35/f1.4 lens, though at some cost to AF speed.
Regards, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
Exit10 Senior Member • Posts: 2,264
thnaks in advance!
You have both 35 and 50 as part of the 18-55 zoom - check your existing photographs and see what you tend to use the most.
 Exit10's gear list:Exit10's gear list
Canon EOS Rebel T6i Fujifilm X-T3 Canon EF 200mm f/2.8L II USM Canon EF 24-105mm f/4L IS USM Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
G4b0r New Member • Posts: 8
You can always crop a 35mm image and get a lower resolution 50mm image. But you can never un-crop the 50mm image to get the 35mm version.
Mavry
Mavry Regular Member • Posts: 137
40% portraits...I guess that would make the 50/2 better suited. It needs some space indoors though.
My whole life has been about Parties, math and sports...I like photography because it gets me closer to some kind of art
https://500px.com/mauro_laserena
 Mavry's gear list:Mavry's gear list
Fujifilm X-T1 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR XF 90mm Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F2 R WR +1 more
mrgooch2008
mrgooch2008 Contributing Member • Posts: 842
Go for the new 50mm f2 .
 mrgooch2008's gear list:mrgooch2008's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
OP davidleunufna New Member • Posts: 4
Rod McD wrote:
Hi,
Regards, Rod
Mavry wrote:
40% portraits...I guess that would make the 50/2 better suited. It needs some space indoors though.mrgooch2008 wrote:
thanks guys for all the insights and replies! im leaning towards the 50 now. because i feel like i never used the 35mm anyway in my kit lens. i only shoot with 18 or 55.
iRanN
iRanN Contributing Member • Posts: 660
6
They're both really good, I've had the 35mm for a year because why not, it was dirt cheap and even though it's not my favorite length i ended up using it more than i thought i would since it's the super small and it's also WR, I got away bring it to concerts since the camera/lens would fit in my coat's pocket. The 50 on the other hand, not as good wide open, color fringe that quickly goes away by f2.5 and by 2.8(2.8-4, drops after that) is one of the sharpest fuji lenses today, not sure I love mine, it's not as small but i'm still going to keep it for hiking/landscape. I would chose the 35, you can still portrait work with it and you'll find it more useful when you can only bring one lens with you.
fullstop Regular Member • Posts: 121
Looking at images from the 50mm from other sites there always seems to be something missing composition wise
dv312
dv312 Veteran Member • Posts: 9,214
thnaks in advance!
from your usage pattern, I think the 50 may be the better fit
35 is better for street but the 50 can be used albeit at a distance
I figure for sports/indoor events you also need a longer reach so 50 is better than 35
for portraits, 50 would be more flattering
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
inecine New Member • Posts: 1
Hello, were the pictures shown taken with the 35mm?
ukeolo Regular Member • Posts: 187
I say the 35 is more versatile.
agree
jf_tea Senior Member • Posts: 1,577
indeed, look at the focal length of the picture you already take with your 18-55, ...
...but, rate your pictures and see what is the focal length of your best pictures
If you like primes, you will eventually get both 35 and 50mm.
 jf_tea's gear list:jf_tea's gear list
Panasonic Lumix DMC-GX1 Pentax K-01 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Pentax smc DA 15mm F4 ED AL Limited +6 more
italianbreadman New Member • Posts: 6
You can crop a 35mm shot to get a cropped 35mm shot. You'll never change the compression of the lens to match the other - in either direction.
purpwaltz
purpwaltz Regular Member • Posts: 409
Excellent images! Were they all shot with the 35mm f2? Also, would you mind sharing EXIF info? Thanks.
"My first thought is always of light" -- Galen Rowell
 purpwaltz's gear list:purpwaltz's gear list
Sony RX100 III Leica Q Leica D-Lux 7 Leica M Typ 240 Fujifilm X-T3 +7 more
baobob
baobob Forum Pro • Posts: 18,248
35mm better adapted to ypur needs
IQ in favor of the 50mm (the 35mm suffers of strong distortion, the bokeh of 50mm better)
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
laddsmith Regular Member • Posts: 395
IranN~Very very nice images.  A point I did not understand.  They are all labelled taken at 1/10000 sec.  Especially the singer~how did you do this?
Ladd Smith
 laddsmith's gear list:laddsmith's gear list
Fujifilm X-Pro2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 56mm F1.2 R +4 more
dmaclau Veteran Member • Posts: 3,053
street, portraits...kind of calls for 2 lenses.  A bit wider focal length is often preferable for street work while longer lenses are often preferred by portrait shooters.
The 35mm lens is closest to "normal" and is what I prefer.
I would suggest though that you consider the faster version of either lens.  They're more costly but are quite a bit better optics.  The trade off other than $$ is better low light performance vs better weather performance.  You more often shoot in low light or in rain?
absolute power corrupts...absolutely
 dmaclau's gear list:dmaclau's gear list
Fujifilm FinePix X100 Fujifilm X70 Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
Brian P Smith Contributing Member • Posts: 686
laddsmith wrote:
i
That's what DPR does when the image does not have EXIF date; it just labels everything as 1/10000 and that's all.
 Brian P Smith's gear list:Brian P Smith's gear list
Fujifilm X-T1 Nikon Z7 Fujifilm XF 35mm F1.4 R Nikon AF-S Nikkor 58mm f/1.4G Nikon AP-F 70-300mm F4.5-5.6E +3 more
