X-A1 vs X100T
Started Apr 4, 2017 | Discussions
Dwiptrlatief Regular Member • Posts: 286
X-A1 vs X100T
hei guys which one is the winner?i mean which one has the best image quality?Xa1 or X100t?
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X100T Fujifilm X-A1 Leica X1
Brorjace Regular Member • Posts: 267
Re: X-A1 vs X100T
The image quality will be pretty much the same from those two cameras.
 Brorjace's gear list:Brorjace's gear list
Fujifilm X100T Fujifilm X-Pro2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 16mm F1.4 R WR +2 more
OP Dwiptrlatief Regular Member • Posts: 286
Re: X-A1 vs X100T
so is it worth change my xa+35mm f1.4 to x100t?
Re: X-A1 vs X100T
Probably not, I don't think I could get by with just the x100t, I'd get the 23mm f2 or 18mm f2 if I were you.
Peter Foiles
Peter Foiles Senior Member • Posts: 2,389
Re: X-A1 vs X100T
Note that the X-A1 uses a conventional Bayer array while the X100T is X-Trans.
 Peter Foiles's gear list:Peter Foiles's gear list
Sony a1 OM-1 Fujifilm X-H2S Fujifilm X-H2 Sony a7R V +23 more
Re: X-A1 vs X100T
so is it worth if i change xa1 35mm f1.4 to x100t?
Les Lammers
Les Lammers Veteran Member • Posts: 4,247
Re: X-A1 vs X100T
Why are you considering changing?
 Les Lammers's gear list:Les Lammers's gear list
Ricoh GR Digital III Ricoh GR IIIx Fujifilm X-E1 Fujifilm X-H1 Fujifilm XF 18mm F2 R +6 more
Re: X-A1 vs X100T
because i like x100t body and i dont need to change lenses
Re: X-A1 vs X100T
Well, in that case, find a good price on a x100s or 100t... they are awesome.
