Back and forth between Panasonic and Olympus.
Started Apr 2, 2017 | Discussions
im45us Regular Member • Posts: 179
We recently bought a Panasonic G85 and love it. It is really my wifes camera but I also use it. I am now looking for a used camera and I am wondering if having both brands is hard to get used to or would I be better off getting something from Panasonic?  I am thinking of the Olympus E-PL6. Seems to be a good size and some of the prices seem ok.
Thanks Ivan
 im45us's gear list:im45us's gear list
Sony Cyber-shot DSC-HX5 Panasonic G85 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Olympus PEN E-PL6 Panasonic G85
JudyN Veteran Member • Posts: 4,520
Re: Back and forth between Panasonic and Olympus.
5
I could be wrong, but in my experience every camera is different, same brand or not.  Yes, all (recent at least) Olympus have the Super Control Panel, but other than that...
Another issue would be batteries.  If you could be happy with a camera that uses the same battery as your wife's camera, that would be worth something...
I was thinking of getting a second EM1-II but instead got a EM5-II to replace my EM5 and that means I still have two different batteries.
Lenses will pretty much work on each, although Olympus at least has certain features that will only work with Olympus lenses and other features that will only work with CERTAIN Olympus lenses.
Judy
 JudyN's gear list:JudyN's gear list
Panasonic Lumix DMC-G1 Olympus E-M5 II Olympus E-M1 II Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +5 more
clemcam Contributing Member • Posts: 645
Only you can decide.  There are personal physiological and mental responses to a camera that no third party analysis can  reveal.  I have made some mistakes with cameras that  I have subsequently sold.  My main  satisfactory technque has been rental (from LensRental.com).  This has ruled out several potential candidates.   It is costly, but not as costly as buying the wrong camera,
 clemcam's gear list:clemcam's gear list
Olympus XZ-2 iHS Olympus E-M5 II Olympus E-M5 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +7 more
jalywol
jalywol Forum Pro • Posts: 12,301
It all depends on how comfortable you are with the Oly UI vs the Panasonic UI.  They are a little different.
I think most people find they prefer one or the other overall.  Whether or not you find it easy or confusing to switch back and forth is entirely dependent on your own comfort and familiarity with each/both.
I find using the Panasonic UI very intuitive.  Even after being away from it for a while, I immediately am comfortable with any of their cameras with just a few minute's use.  For me, the Oly UI just never becomes second nature.  I used an EPM2 for about a year, followed by an EM1, and I ended up, even after all that time, just never getting really used to the Olys.  I sold the EM1 after about six months, and got a GX7, which instantly felt more familiar to me than the Olys did even after a year and a half of using them.  Others have the opposite reaction.
So, my advice would be to spend some time in the store, if you can, with the Oly, and see how you feel about it.  It may work just fine for you.  Or, it may not.....consider a GX850 if it doesn't, maybe?
-J
Ulric Veteran Member • Posts: 4,559
I have one Olympus and two Panasonic cameras. It is not a problem to switch between them.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
rarecoinman Regular Member • Posts: 208
Both are ticking time bomb! 16mega pixels really, Wtfreg its 2017--
'what we do in life, echoes an eternity'
 rarecoinman's gear list:rarecoinman's gear list
Sony a6300 Sony E 50mm F1.8 OSS Sony Vario-Tessar T* E 16-70mm F4 ZA OSS
rsmithgi Senior Member • Posts: 2,939
I had a GX1 and E-M10 at the same time for a while. I didn't like switching between the two. I used the E-M10 much more so that had a lot to do with it. If you are using both regularly, it shouldn't be a problem. I did upgrade the GX1 to an E-P5 and the E-M10 to an E-M1.1 Now the two cameras share batteries and have similar interfaces (although I wish the E-P5 would show the SCP full time on the LCD when the VF-4 is attached.)
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 +5 more
situman1 Senior Member • Posts: 1,285
Thanks Ivan
The Epl6 is such a downgrade.  Go find yourself a new or used gx85 if you want most of the tech of the g85 at a much smaller package.
pdk42
pdk42 Senior Member • Posts: 1,299
 pdk42's gear list:pdk42's gear list
Olympus PEN-F Panasonic Lumix DC-S1R Panasonic Lumix DC-S5 +1 more
RSSrsvp Veteran Member • Posts: 3,251
What is your budget for this second camera?
 RSSrsvp's gear list:RSSrsvp's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +1 more
OP im45us Regular Member • Posts: 179
My budget seems to grow ;-). When I started to look for the first camera my budget was $1000 and no more. Camera, 2 extra lenses, batteries, filters and a tripod and I am close to $1700. I am just not sure how much I will get into it. My last real camera was a Minolta SRT-101 a very long time ago . Since then its been point and shoots.
I would like to keep it less than $500 but the more I look thats getting hard. I am more concerned with size at this point and whether I want to mix brands. We are just learning the Panasonic G85 and not sure I want to learn Olympus at the same time. But if the price is right I will give it a try.
I went to my local camera shop and tried a few cameras. The Olympus E-PL6 seemed ok and I tried a new Panasonic GM but that was too small.
The search continues...
Frankly I would consider really stretching your budget and purchase a second G85. The learning curve will be much shorter as you are already versed in the Panasonic menu and the Oly menu may complicate things. Wait for a promotion and go for it as we both know that the G85 is what you really want.
You can track the prices on www.camelcamelcamel.com.
By the way although you purchased the first camera for your wife you are doing all of the posting you should add the G85 body and the lenses to your DPR profile's Gear List.
AznJunkie Regular Member • Posts: 156
I owned the E-PL6 and personally I would go with the Panasonic GX85. With the GX85 there will be less of a learning curve since the interface will be very similar to the G85. It's smaller than the G85 and you'll get an EVF which the E-PL6 lacks. The E-PL6 is cheaper but it will feel like a major step backward if you start using the features on the G85.
You should be able to find a used GX85 for around $500.
 AznJunkie's gear list:AznJunkie's gear list
Sony a7 III Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 50mm F1.8 Sony FE 200-600 F5.6-6.3 Tamron 28-200mm F2.8-5.6 +3 more
Adorama has a used GX85 for $549 and a GX85 with the 12-32mm f3.5-5.6 lens for $599. They are both D rated which means "little or no signs of wear" which is excellent. They have a return policy and give a used warranty.
nevada5
nevada5 Forum Pro • Posts: 15,569
I don't have a problem using both, but I try to use the Olympus cameras in such a way as to avoid using the menus - life's easier that way.
If it's of interest - I have the E-PL6 and the E-PL-7. I would buy the 7 again but not the 6. The control dial on the top alone is worth it, but I prefer the size and ergonomics as well.
Stay thirsty, my friends.
Life is short - drive a convertible.
