A6000 bricked going from firmware 1.10 to 3.20
Started Apr 2, 2017 | Discussions
Admiral Krank Junior Member • Posts: 32
Ok, seriously this is one of those wt* moments.  I just upgraded an a7m2 same cable, same computer.  Then I went and got my a6000 and started to do an upgrade with a6000 specific firmware.
seriously... wt*.
the updater gave me a notice about the camera and computer being disconnected.
I now seem to have a bricked a6000.  When I put a battery in it, and turn it on, the battery light on the bottom comes on, but the menu, etc. doesn't show up.  Even when I turn off the unit, the battery light shows.
Is there any way to fix this.  I'm seriously annoyed.
Sony a6000
Htbaa Senior Member • Posts: 1,033
Re: A6000 bricked going from firmware 1.10 to 3.20
Have you tried running the updated again?
 Htbaa's gear list:Htbaa's gear list
Sony a6400 Sony E 50mm F1.8 OSS Sony E PZ 18-105mm F4 G OSS Sigma 150-600mm F5-6.3 | C Sigma 30mm F1.4 (E/EF-M mounts) +18 more
OP Admiral Krank Junior Member • Posts: 32
I'm at the "reset the camera" step of the upgrade, but I can't  get it to see that I've reset the camera (literally taken the battery in an out of it).
Ok, here's what I did.
Whatever you do, don't shut down the installer.  I kept repeating a few steps in between failures.  Ie) failing at "run the update", and also failing at "reset the camera" I tried using different USB cable (same result), and then a different USB port.
Upon using a different USB port, and going through a failure to reset the camera a few times, I got it to run the update, and "finish the update"
Stay at it folks, it's painful, but it's not entirely bricked.  I'm back to being a happy a6000 user (but somewhat annoyed at the adrenaline filled 2 hours I wasted at this...).
Joachim Wulfers
Joachim Wulfers Veteran Member • Posts: 5,893
Thanks to your post I was reminded to check my FW Version. I was at 2.0. I immediately updated to Version 3.2, but contrary to your experience it was all smooth sailing. I just followed the instructions by the letter, such as install a fully charged battery, remove the memory card, switch on the camera, connect it to the computer and don't touch anything. It worked while I filled out the satisfaction survey.
I am not sure if anything has improved, but thanks for reminding me.
 Joachim Wulfers's gear list:Joachim Wulfers's gear list
Fujifilm X100T Sony a6000 Sony a6600 Sony E 18-200mm F3.5-6.3 OSS Voigtlander 21mm F4 Color Skopar Pancake II +14 more
