E-P5 has lost its focus
Started Mar 30, 2017 | Questions
PoohBill
PoohBill Regular Member • Posts: 363
We went for an evening drive last weekend on rumors of Snow Geese and Bald Eagle fledglings, only to discover one of my two E-P5s has lost its focus, no matter which lens is mounted or which focus mode I select. Even MF gets no response from focus ring turns.
1. Current firmware: 1.7
2. Full Reset
3. Removed battery for a time
Has anyone something else I should give a try? Thank you.
Bill
UPDATE: The body appears to be unable to detect a lens is mounted. Firmware display only shows Camera version. Clean the contacts?
B
 PoohBill's gear list:PoohBill's gear list
Olympus 12-40mm F2.8 Pro Olympus E-M5 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 +2 more
Olympus PEN E-P5
JaKing
JaKing Veteran Member • Posts: 6,300
Re: E-P5 has lost its focus
Bill, wipe the camera contacts using a clean dry lint free cloth. Check to make sure all the pins move freely and fully by carefully pressing and releasing each one. Check that none are failing to fully extend first.
Other than that, it might need to go on holidays to the service centre ... .
br, john, from you know where
My gear list and sordid past are here: https://www.dpreview.com/members/1558378718/overview
Gallery: http://canopuscomputing.com.au/gallery2/v/main-page/
 JaKing's gear list:JaKing's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 12-100mm F4.0 Olympus E-1 +29 more
PoohBill
OP PoohBill Regular Member • Posts: 363
Well, your sordid past must have included a stuck pin or two. Thank you! Back on focus.
Bill
JaKing
Haha!
Not my own, but plenty of other people's.
Glad to hear that all is well, Bill 😀.
