Advice on Setting up a Stereo Camera
Started Mar 29, 2017 | Questions
grantcollier New Member • Posts: 4
I have a lot of experience in photography, but am new to stereo imaging. I'd like the following in a stereo set up for occasional use:
- zoom lens with effective focal length of at least 24-60mm (35mm equiv.)
- be able to shoot two vertical images with lenses 3"-4" apart
- raw files and full manual exposure control
- total cost under $600
I don't think there's any existing stereo cameras or lenses that offer the focal lengths I need. The two D800s I own are too bulky to get closer than 5" apart. So I'm considering buying two used Sony Nex-5T cameras with 16-50mm (24-75mm effective) lens. These appear to offer the best image quality I can find for a compact $250 camera + lens. They don't appear to allow wired remote cords, so I'd likely get a Foto&Tech Infrared Wireless Remote. I'm assuming I can trigger two cameras at the same time with this, but haven't been able to verify it.
Can anyone confirm that any infrared remote can trigger two cameras at once?
I've read that these cameras still can't be perfectly synced. I'm just not sure how much the sync would be off and how much it would matter for what I'm doing. I'd have moving objects in maybe 20% in of my shots, either people walking or cars moving. I don't think I'd have any real close cars, they'd maybe be 30+ feet away, so I wouldn't consider it action shots. I don't plan to shoot any videos.
Should I be okay with this or could syncing be an issue?
I've read that you can sync Canon Powershot cameras more closely, though don't know how complicated it is. The ones I've found for around $250 seem to produce significantly lower image quality than the Sony, based on DxoMark. Admittedly, I may only print 8x10 anaglyphs and 4x7 stereo pairs with these, so camera quality may not matter so much, if syncing were a bigger issue. But it's possible I'd want to do much larger prints someday. I also haven't searched much to see which Canons might have the focal length and other specs I need.
I think I can mount the cameras side-by-side in a vertical orientation using a dual-camera bracket and two L-brackets like these:
https://smile.amazon.com/LimoStudio-Bracket-Aluminum-Universal-Speedlite/dp/B01HH5NB2Y
https://smile.amazon.com/Desmond-Bracket-Cameras-Stereoscopic-Photography/dp/B00BCSTGUE/
Can anyone confirm that these brackets would work?
Thanks!
NEX-5T
Sailor Blue
Sailor Blue Forum Pro • Posts: 15,536
Re: Advice on Setting up a Stereo Camera
Search this forum and you will find a number of posts about using two Canon cameras and how to simultaneously trigger them. There are also a number of posts on using two GoPro cameras. For most uses it is simply easier and better to just buy a Fuji Real 3D W3 camera.
If you want to use a camera with a higher resolution sensor or variable focal lenghts there is the cha-cha method where you take one photo then sway to the side and take the second image. StereoPhoto Maker does an excellent job of aligning the two images. With practice you can sway more for distant objects and less for closeups.
StereoPhoto Maker (English)
In order to be able to use my Canon 7D for stereo I bought a cheap slide, kept the slide clamp and removed the worm gear mechanism. A Bulldog type clip is positioned at the desired stereo base (see images below). This allows me to release the clamp, slide the rail quickly, then reclamp it. This is much faster than using the worm gear to move the slide.
eBay - 2 way Macro Shot Focusing Focus Rail Slider for CANON NIKON SONY Camera D-SLR
I mounted a Stroboframe 300-115 Vertaflip on the modified rail so I can use my Canon 7D either in horizontal or vertical orientation while keeping the lens centered over the tripod screw in the slide.
Amazon.com: Stroboframe 300-115 Vertaflip PHD Camera Platform (Black): Camera & Photo
The desired stereo base depends on focal length and subject distance.
Lens Interaxial Distance: 3D and Stereo Photography Forum: Digital Photography Review
Stereo Base Mathematics
BaseCalc: A free pocket-sized stereo base calculator - www.stereoscopie.fr
There is an android application called "BaseCalc" that I keep on my phone that can give you the stereo base in either metric or English measurements.
BaseCalc - Android Apps on Google Play
This rig works well for inanimate non-moving subjects but not for any subject that moves.
Living and loving it in Pattaya, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Canon EOS 5DS R Tamron SP AF 90mm F/2.8 Di Macro Tokina AT-X 16-28mm f/2.8 Pro FX +9 more
OP grantcollier New Member • Posts: 4
Thank you for the reply! I have attempted a couple images with the cha cha method and the 3D effect worked well. However for the project I have in mind, there will be moving objects in some of the shots. So I need the dual cameras. The Fuji focal isn't wide enough for some shots I'll need. I'll look up more on the Canons. I'd prefer the two Sonys and think it will work for what I need, but want to know for sure before investing in the equipment.
Sailor Blue
With moving subject shutter synchronization would be critical so I understand your quandary. Unfortunately I don't have any information about syncing two cameras other than having seen that it is possible with two Canon point and shoot cameras or GoPro cameras.
This has been a topic in this DPReview Forum several times. Google "twin cameras for stereo" and you will find a link to several DPR discussions, including this one.
Here is one article about using two SLRs or smaller cameras with sync ports.
Make and Use a Twin Digital SLR Camera System for 3-D Stereo Photography and More
Best of luck with your project.
Brian F Flint
Brian F Flint Regular Member • Posts: 184
I have a couple of Nikon 1 V1 cameras with 10-30 mm lens ( 27- 81mm , 35mm equiv )
They do not have wired remote, so I have made a infra-red remote splitter so that an infra-red control unit can trigger both cameras. I mainly use this for starting two cameras into movie record mode. For good sync for still photos, the infra-red remote can have problems. For example I have found the cameras are best to be in manual focus mode  and  manual exposure mode. When a remote trigger signal is applied to two cameras in auto mode , one camera may decide to do an addition focus check or additional light reading check before taking the photo and the other camera may decide everything is fine and immediately take the photo. This results in poor sync.
I would advice a wired remote solution if you are going to use two cameras.
Another thing to consider is the focal length of the lens of the two cameras need to be set to the same position. Power zoom lens may make this tricky.
Another thing the white balance needs checking ( use a white card ). It is amazing how much the colours can differ between two cameras.
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
Oleg L K Regular Member • Posts: 293
We are working on dual-camera rigs with Sony E-mount cameras - to eventually make them commercially available. But it will take another year.
If you want to go on your own, consider newer cameras with wired remotes. A5000 shouldn't be too expensive.
Then, do you really need zoom lens for stereo photography? A purist like myself would recommend to go with the standard prime - with the FOV suiting frame-crop size that you choose.
You can see sample pictures from out prototype rigs at www.phereo.com/olegk .  Though most of them are horizontal, we for now settled on the vertical arrangement and cropping a quadrant out of it. I'll upload more stereopairs in the coming weeks.
Oleg.
Thank you, Oleg! The Sony E-mount setup you're working on sounds nice.
For the project I am planning, I'd need a variety of focal lengths. Two or more prime lenses would be ideal, but really more than I want to pay for the relatively small amount of stereo photography I'll be doing. It may be challenging to match the focal lengths on a zoom when not zoomed all the way in or out but I think I can do it with a manual zoom.
Since wireless remotes don't sound ideal for this, I think I'll be going with two Samsung NX1000s, with a setup similar to the one described at http://drt3d.blogspot.com/2016/10/twin-samsung-nx1000-for-stereo-part-i.html
Thanks Brian! Is the color difference from the two cameras the result of the cameras choosing different white balance settings in auto? Or do the colors appear different despite the cameras using the same white balance settings (thus requiring slightly different white balance settings to match)?
I will be avoiding power zooms, and I'd probably shoot entirely with manual focus / exposure.  But since wireless remotes might still not be ideal for this, I think I'll be going with two Samsung NX1000s with 18-55 lens, with a setup similar to the one described at http://drt3d.blogspot.com/2016/10/twin-samsung-nx1000-for-stereo-part-i.html
stereoscope3d New Member • Posts: 1
Stereoscopic imaging is a very complex field of endeavor. It is extremely subjective. As such, it is possible, in the right circumstances to use an amazing array of equipment and procedures. That said, this very complexity also means that, unless you really understand it, not getting it right is quite likely.
There are certain generalizations, or guidelines that can be helpful. For example, you will likely find the you will be using shorter focal length lenses much more than longer, since long focal lengths tend to "flatten" the subject. This is true also in 2D, but it is much more obvious in 3D.
Sync is often more critical than most imagine. If you are shooting a stereo pair of a perfectly still subject, say a building with no people or other moving objects, on a tripod, you can usually get away with several minutes between exposures. However, say there is a tree in the picture and a breeze, the flutter of the leaves will require fairly accurate sync to avoid what is called "retinal rivalry".
I would recommend that you read some of the free books in the Stereoscopic Virtual Library http://www.stereoscopic.org/library/index.html
As a start, I would suggest McKay's book, as it was written with the beginner in mind, and it has a bibliography of commonly used words and terms that are useful to get defined before reading the other books.
Most of these books were written several years ago, in the days of analog film stereography.  However, most of the basic principles outlined in them apply to digital imaging as well.  In fact, digital stereography often makes it easier (and cheaper to experiment).
