Clicking noise when shooting electronic shutter on E-M1 Mk II
Started Mar 28, 2017 | Discussions
brianric Veteran Member • Posts: 8,980
I usually shoot wide open on all my lenses on all my lenses so far this year so I never noticed this until this past weekend. If I stop down a couple stops at 8 fps in S-AF mode I get a distinct clicking noise while using the electronic shutter. This is most noticeable on my 75/1.8 and I was able to duplicate it on the 12-40/2.8. If I go to the C-AF mode the distinct clicking goes away. Is this normal and if so what is its cause?
 brianric's gear list:brianric's gear list
Sony RX100 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GX8 Sony a6400 Sony a9 II +6 more
Olympus 12-40mm F2.8 Pro Olympus E-M1 II Olympus M.Zuiko Digital ED 75mm F1.8
453C Veteran Member • Posts: 7,087
Re: Clicking noise when shooting electronic shutter on E-M1 Mk II
I'd guess it's the aperture shifting quickly between wide open and whatever value you selected. While looking into the front element, rattle off some shots and you should be able to see the aperture moving.
As for why you're now hearing it, the mechanical shutter sound would mask it, and if you have the aperture set wide open, it doesn't have to move for the exposure.
OP brianric Veteran Member • Posts: 8,980
It's fairly quiet on the C-AF mode, so why does the S-AF mode be so noisy. This past weekend was the first time I shot in the S-AF mode.
I don't have a Mark II, so that's for someone else to answer. If you experiment with the different modes while looking into the lens, you may figure it out. Please let us know.
drj3 Forum Pro • Posts: 12,634
I get a low click sound with the 300mm f4 in either the SAF+MF or CAF modes when the lens stops down.  I haven't noticed it to be louder on either one, but sometimes I notice it more than others depending on background noise levels.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
It's quite noticeable on my 75/1.8. At first I thought I damaged the lens or camera as I was changing lens at a school play this weekend. I'll play around with it later this week. Got a 14-35/2.0 coming in today, and I want to run that lens through its paces.
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
I'm hearing this when shooting with my 100-400 in particular but also on occasions with the 12-100 and the 40-150 mk2 kit lens.
As mentioned above I have put it down to aperture chatter and get it with both SAF and CAF.
Whilst I haven't done any systematic work to trace the cause I get the impression it doesn't happen when I shoot wide open, only when I stop down
The other thing is that it isn't consistent, sometimes there is no sound others its very frequent and obvious (I wonder if its something to do with the light levels? )
I'd stopped worrying about it until you posted this
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-45mm F4 Pro +1 more
Skeeterbytes Forum Pro • Posts: 23,186
In addition to the above you might try changing AEL/AFL mode. They lock exposure differently (half press/full press)  and perhaps that affects cycling the aperture blades (p.123). Or, S vs. A vs. M mode.
FWIW the mk1 does it too.
Ricl
