Lens for Street Photography?
Started Mar 26, 2017 | Questions
Stejo
Stejo Senior Member • Posts: 1,461
Re: Lens for Street Photography?
Street shooting is typically done in good light with large dof. For that you don't need a fast prime. If size isn't an issue, then a superzoom is the best option. 14-140 or so. Otherwise a pancake kit lens will do the trick.
 Stejo's gear list:Stejo's gear list
Panasonic Lumix DMC-G7 Panasonic GH5 Samyang 85mm F1.4 Aspherical IF Samyang 7.5mm F3.5 Fisheye Sigma 18-35mm F1.8 DC HSM Art +7 more
alfredo_tomato
alfredo_tomato Veteran Member • Posts: 4,382
Two lenses I use
I use the Lumix 20mm 1.7. They say it is slow, but I have little issue with the speed.  Sweet lens. You might find a good deal on this lens. Mine was $150 used.
The Sigma 30mm 2.8 is a very good lens. I use this lens a lot. It retails at and under $200.
For street, any lens you are comfortable with is the one you should use.
 alfredo_tomato's gear list:alfredo_tomato's gear list
Olympus PEN E-PL1s Olympus PEN E-PM2 Olympus OM-D E-M10 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +13 more
Pete_W
Pete_W Senior Member • Posts: 2,838
I recommend a wider lens, e.g. PL 15mm f/1.7 or PL 12mm f/1.4.
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
maggiemole Senior Member • Posts: 1,988
I use either the 20mm 1.7 or the 14mm 2.5, depending on which is on the camera at the time. Only one other respondent has mentioned the 14mm 2.5 (captura) and I'm curious as to why? I see a major requirement for street being unobtrusive, so unless I'm a long way off and can use a telephoto, it has to be a small lens. These two fit the bill perfectly. And using the tilt screen of a GX80 at low level against my body makes the photographer unobtrusive as well!
Maggie
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
007peter
007peter Forum Pro • Posts: 12,933
Depends on shooting CROWDs or Shooting Pretty Stranger (oly 45/1.8)
Street Photography can mean different things to different people.  I like to Take picture of "People" but I don't give much of a damn about the street itself.  As the result I tend to favor Long Telephoto prime, I think Olympus 45/1.8 is nearly perfect for this, as is the Olympus 75/1.8.  However, if you're just shooting the CROWDS, I think any wider 25mm will do just fined.
One thing you need to be aware of in 2017 is that people can be paranoid about being photograph in public.  That is why I no longer do street photography with my white Canon 70-200 F/4 DSLRwhich capture beautiful strangers stunningly
taken with my Canon 70-200 F4 IS on Asian Street market
Today, I have to shoot non-EVF Mirrorless with Tilty Screen.  People seem to react negatively when I look through an OVF or EVF, but they don't react @all when I LOOK DOWN on my camera pretending to adjust my menu sitting.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
generikku Contributing Member • Posts: 864
Is that 35 1.4 an adapted manual lens, Voigtlander perhaps? Have some street examples with that focal length? I use it but not for street as I find it too long, but curious about your compositions with the 70mm FOV and the MFD on the street.
 generikku's gear list:generikku's gear list
Olympus PEN E-PL1 Olympus PEN E-PL3 Olympus PEN E-P5 Sony a7 Olympus OM-D E-M10 +2 more
Sergey Borachev Veteran Member • Posts: 5,338
For most street photogs, the following attributes are important in a lens:
- small and unobtrusive
- fast AF
- sharpness (due to cropping, no time for careful framing)
- more DoF, or easier focusing, and hence a wider lens, which also means more need to crop.
- high shutter speed to reduce motion blur, which also suggests a faster lens (tho not terrible important) and shorter FL
None of the lenses you listed is perfect. The 20mm is small, sharp and the widest but still not that wide and it does not focus well. The others are too long for some shots. You can crop and get a usable pic from a wider lens, but you can't do anything with a lens that is too long.
The 17mm f/1.8 should be the most suitable,.except it's not very sharp. The 15mm is sharper and probably the best at this time but it's expensive. For what it costs, you can buy the Ricoh GR and do street shots much, much better. It's lens is a bit slow but otherwise as a street camera, it is just about perfect. It's lens is also a bit wide but can be "zoomed" instantly to 35mm using a button. And there are many more dedicated to street features.
People who use the longer lenses are not IMO complete street shooters. They can't get close enough when necessary to isolate the subject in crowded areas, include the surroundings or show the perspectives to let the viewers feel that they are right there close to the action. Not everybody has the courage, tact, and personality or quirkiness to shoot strangers at close range and get away with it. Don't bother with street if you can only zoom in from afar. That's more like snooping than street shooting. Check what Robin Wong or Kai does.
+1 to this, as I have these three lenses too. The 12-32 is surprisingly versatile for street. Even until around dusk. When the light gets lower though, then you'll need something at least F/1.8 to carry on.
I'm sure others have already brought these up, but if you can only get one lens for street, I recommend either the Panasonic 15mm or Olympus 17mm. The first has an aperture ring, the second has the pullback manual focus. For street, either of those provide a better more tactile and manual experience than the Panasonic 20mm. Also, the slightly shorter focal lengths will help with zone focusing or using hyper focal distance. The 20mm is slightly long then, mostly good for automatic - and it's not even the speediest at that for street.
gorred
gorred Senior Member • Posts: 1,205
There is no such thing as "the best lens for street photography". It depends on your shooting mode, and what you want to photograph.
On the other hand; a relatively small lens is less obtrusive and, together with a smaller camera, easier to carry around.
My best combo for everyday photography including street photo is EM 10 II with the mZuiko 17mm/1,8. The lens is small, it is pretty fast and it is IMO really sharp! And the combo is nice and versatile.
I often carry the 45mm/1,8 and the 75mm/1,8 for backup, if I need longer lenses.
//Göran
 gorred's gear list:gorred's gear list
Olympus TG-5 Panasonic Lumix DMC-GH2 Olympus OM-D E-M10 II Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +9 more
jeffharris
jeffharris Forum Pro • Posts: 11,411
Thats it! Love that lens! It has nice character.
I use it on the street fairly often. For a while I was using it on the subway for "portraits"… faces and hands. In that constricted environment, it's a nice focal length. Sometimes I carry it with the 20mm for a compact combo.
I'll poke around and see what I have. I was religiously adding focal length to my EXIF data in Lightroom with LensTagger, but slacked off a bit lately. I've been renovating my apartment and been, how To put it, a bit consumed by it.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
jeffharris
Maggie
Of course, but unobtrusiveness is at least as much about your approach, how you're wielding the camera and vibe as it is about lens size. If you're holding a camera you're already suspect.
I've found that primes are certainly better than big zooms in that regard. I find that I'm noticed much more often with my 12-40mm than any of my (preferred) manual primes, even the chunky ones like the Voigtländer 17.5mm or 42.5mm.
I find ways to look away while shooting, the fully articulated LCD is great for that. Or blatantly use the EVF looking away and pivot toward my quarry to grab a few shots.
Marty4650
Marty4650 Forum Pro • Posts: 16,289
None of the above
Mohamed Mansour wrote:
Which of the following is the best for street photography?
1. Panasonic 20mm f1.7 II (pancake)
2. Panasonic 25mm f1.7
3. Olympus 25mm f1.8
At least for me, I prefer something much wider.
I currently have the Panasonic 14mm f/2.5 and the Olympus 17mm f/1.8. And both are pretty good for street photography. The 17mm gets used most often.
If I had it to do over I'd probably get the outstanding Panasonic 15mm f/1.7 lens. But I have too many lenses right now, and I just can't justify one more!
And does the first lens being a pancake affect output in anyway?
It might theoretically, but the 20mm f/1.7 lens is so GOOD that I doubt you would see any difference between a 20mm pancake and a 20mm conventional lens design.
Of your three options, I'd take the 20mm... because it is significantly wider, even if not wide enough for my taste.
 Marty4650's gear list:Marty4650's gear list
Panasonic LX100 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX85 +16 more
captura Forum Pro • Posts: 27,478
Re: Two lenses I use
I have the S. DF-DN 30/2.8 in the Sony e-mount version, which is the same as for M43, except for the mount. I seldom use it because the focus ring binds; a problem which was resolved in the newer 'ART' version. But the ART has been tested  as less sharp.
The S. 60/2.8 is said to be very sharp.
 captura's gear list:captura's gear list
Sony Alpha NEX-7 Canon EOS Rebel SL1 Sony a7 Olympus OM-D E-M10 Canon EF 85mm F1.8 USM +3 more
Maggie
Agreed. The 20 and 14 are old stand-by's, ultra-compact fast performers.  The 14/2.8 focuses faster than the 20.
My 14 may be a particularly stellar version.  On my beloved 12 mp E-PM1, it just glows and produces an unusual 3D-like effect, which I don't understand, but love it.
- fast AF
Snooping may be required on occasion.
Sometimes I use the Nikon 1 J1 with 30-110 lens, which is about the size of an E-M10 with kit lens, but takes it out to 300mm effective. Focusing is assured, just mash the shutter. Trouble is the body is red, but people think maybe it's a P&S. Mostly I can stand way back and not get noticed. I'm waiting for a nice used black V1 model to come up.
Valentinian
Valentinian Contributing Member • Posts: 883
street photography (updating my lenses)
jeffharris wrote:
(I'm thinking of selling my 20mm and 14mm f2.5 an getting a 15mm.)
I sold my 14/2.5 and my 25/1.4;
got the 15/1.7 and am happy with it-
the 35-100/2.8 should arrive any day
I will keep the Kowa 8.5/2.8
didn't decide yet if will keep the 75/1.8
(below, some "street photography" samples with the 8.5mm)
 Valentinian's gear list:Valentinian's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic 100-300mm F4-5.6 II Panasonic 35-100mm F2.8 II +1 more
larsbc Forum Pro • Posts: 18,282
I've shot street with the 20/1.7 ver 1 and the 25/1.4.  There's really not a huge difference in my eyes unless you're going to obsess about slight differences in perspective and DoF.
If you're comfortable photographing strangers fairly close up then I'd go with the 20 for its compact size.  Otherwise, the 25 might be a better choice.  Myself, I prefer the the 25, usually.
Lowell Herr
Lowell Herr Contributing Member • Posts: 595
JDLaing50 wrote:
None of the above.
17.5mm f/095 Voigtlander.
Is the Voigtlander a manual focus only?
Lowell
 Lowell Herr's gear list:Lowell Herr's gear list
Sony RX100 III Canon EOS 5D Mark II Olympus E-M1 II Olympus E-M1 III Canon EF 70-200mm f/2.8L USM +6 more
alfredo_tomato
Re: None of the above
The only real difference between the 20mm  and the 20mm II is the metal body on the II.
jeffharris
Lowell Herr wrote:
JDLaing50 wrote:
None of the above.
Yep and it does it beautifully.
