Lens for Street Photography?
Started Mar 26, 2017 | Questions
Mohamed Mansour
Mohamed Mansour New Member • Posts: 10
Which of the following is the best for street photography?
1. Panasonic 20mm f1.7 II (pancake)
2. Panasonic 25mm f1.7
3. Olympus 25mm f1.8
And does the first lens being a pancake affect output in anyway?
Thx,
Mo
 Mohamed Mansour's gear list:Mohamed Mansour's gear list
Olympus OM-D E-M10 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G 25mm F1.7 ASPH +1 more
Olympus M.Zuiko Digital 25mm F1.8 Panasonic 20mm F1.7 II Panasonic Lumix G 25mm F1.7 ASPH
Paulmorgan Veteran Member • Posts: 9,499
Re: Lens for Street Photography?
5
Thx,
Mo
There is no best lens, not from your list or anywhere else.
Use what ever suits you.
Peter Del Veteran Member • Posts: 7,988
I thought I would not like a small prime, but the Olympus 7mm f/1.8 came with the camera and acquitted itself ratyher well, IMHO.
https://www.dpreview.com/forums/post/59324984
Peter Del
 Peter Del's gear list:Peter Del's gear list
Olympus PEN-F Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +5 more
RSSrsvp Veteran Member • Posts: 3,251
6
Thx,
Mo
For street shooting I would go wider which is why I purchased the Oly 17mm f1.8. The. PL 15mm f1.7 is another great option. IMO they are both better choices than 20-25mm.
 RSSrsvp's gear list:RSSrsvp's gear list
Olympus E-M5 II Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 17mm F1.8 +1 more
h2odog
h2odog Senior Member • Posts: 1,225
Thx,
Mo
I often use the 20 1.7 II for street photography but don't feel obliged to always use it. Being a pancake lens doesn't detract in any way from its ability to produce excellent IQ.
 h2odog's gear list:h2odog's gear list
Panasonic Lumix DMC-GF1 Canon EOS Rebel SL2 Panasonic 20mm F1.7 II Canon EF-S 24mm F2.8 STM Canon EF-S 18-135mm F3.5-5.6 IS STM +4 more
MFiftysomething Senior Member • Posts: 1,075
Olympus 17mm F1.8 =35mm
Panasonic Leica 15mm F1.7  =30mm
I think 25mm (50mm) a bit too long but of your list on a panasonic camera the Panasonic 25mm as you can use DFD focus -also best value lens/cheap!
 MFiftysomething's gear list:MFiftysomething's gear list
Sony RX100 V Fujifilm X100V Sony a7 IV Sony a7C Fujifilm X-E4
norman shearer Senior Member • Posts: 1,418
Thx,
Mo
+1
However, it depends on how you shoot street. Do you shoot on the move? Do you shoot from the chest or hip or do you use the EVF and/or screen? Do you zone focus?
I personally shoot from the chest and the PL 15mm F1.7 is perfect. Paired with a GX80 it can focus and shoot as fast as I can depress the button. It is also ready for the next shot very quickly. I have custom multipoint focus set up with 3 cells across the width of the upper part of my screen. Providing I'm aiming the camera correctly and close enough to my subject it will nail focus 8/10 times.
I've used the 20mm F1.7 II in the past and it is very good image quality but for that lens I chose to zone focus. If you are using the screen/EVF then AF will be okay with newer bodies but a little sluggish with older cameras.
Some samples with 15/1.7
 norman shearer's gear list:norman shearer's gear list
Nikon Coolpix A Sony RX1R Samsung EX2F Canon EOS 5D Sony a7R II +10 more
beameup
beameup Regular Member • Posts: 367
I use the 15mm body-cap lens.
However, I'd like to get the 20mm f1.7 II
 beameup's gear list:beameup's gear list
Olympus E-M1 Olympus E-M5 II Olympus E-510 Olympus E-PL10 Olympus Body Cap Lens 15mm F8.0 +7 more
Paul Amyes Senior Member • Posts: 1,907
I vacillate mostly between the 17 and the 25 and every now again use the 45. At the moment I've got a hankering for the 15mm. There is no right lens it's all a matter of how you view the world and how close you want to get to it.
 Paul Amyes's gear list:Paul Amyes's gear list
Voigtlander 35mm F2.5 Color Skopar
JDLaing50 Veteran Member • Posts: 3,170
None of the above.
17.5mm f/095 Voigtlander.
 JDLaing50's gear list:JDLaing50's gear list
Sony RX1R II Leica M-P (Typ 240) Olympus PEN-F Panasonic Lumix DC-S1R OM-1 +12 more
ahaslett
ahaslett Forum Pro • Posts: 12,662
Without knowing your style, it's a bit hard to say.  My street lens would be the 12-40mm f/2.8.  The 20mm f/1.7 I comes next, after which the Sony FE 55mm f/1.8 is good for shallow DoF and a bit more subject compression.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
jeffharris
jeffharris Forum Pro • Posts: 11,411
I find 25mm or 20mm for street shooting kind of MEH. Try 17mm or 17.5mm (better!).
OR the 15mm f1.7, as mentioned by others. (I'm thinking of selling my 20mm and 14mm f2.5 an getting a 15mm.)
OR go long with a 42.5mm f1.7 or 45mm or an inexpensive adapted 50mm.
No. It's just a little slow to focus on some Olympus bodies. Newer Panasonic bodies it's not really an issue.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Voigtlander Nokton 42.5mm F0.95 Panasonic Lumix DMC-GX8 +26 more
jeffharris
Thx,
Mo
Exactly. Use anything you like. How you see is more important than which lens you're using. Limitations are creative stimulants.
The list of my favorite street lenses is pretty random… 35mm f1.4, 17.5mm, Jupiter 8 (50mm f2), 42.5mm f0.95, 75mm f2.5, 7-14mm f4. In New York, I prefer longer lenses, while traveling, wider.
Robert Evagelista
Robert Evagelista Veteran Member • Posts: 3,448
For All around Street 25mm is more versatile.
For Street Portrait I like the 45mm 1.8 more.
But Using the 25mm 1.8 is still a joy for Portraits.
samples below on my 2nd day of taking it out.
This was Street Shoot organized Olympus Malaysia Robing Yesterday.
My attempt of recreating Robin Wong look
I Shoot most the Participants
 Robert Evagelista's gear list:Robert Evagelista's gear list
Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Samyang 85mm F1.4 Aspherical IF Canon Pixma Pro-100 +11 more
(unknown member) Veteran Member • Posts: 7,274
All are good but 20mm is best as it is widest.
All are required to be used at f/4-5.6 to get enough DOF and "smell the street" experience and being in manual focus. So what ever you want works.
Skeeterbytes Forum Pro • Posts: 23,186
Yes, I'd look at the 15 if this were an area of interest, as it's a very good lens and forgiving WRT composition and focus. The 20 focuses too slowly to be a good reaction tool, so of your list I'd go with the 25/1.8.
The 12-32 is discreet for times the light is good.
Rick
DP13Photo Veteran Member • Posts: 6,307
Thx,
Mo
I prefer the 20/1.7 which is about 40mm equivalent. Little bit wide and a little bit normal.
My very first camera, a film camera, the Kodak Instamatic was 43mm so I am very used to this focal length as a very nice balance between the two classic focal lengths, 35mm & 50mm.
Dave
 DP13Photo's gear list:DP13Photo's gear list
Sony a7 IV Sony a7C Sony a7 III Sony FE 24mm F1.4 GM Sony FE 50mm F2.5 G +15 more
The Mad Kiwi Senior Member • Posts: 1,074
Of those I'd go the 20mm 1.7, but as with others I prefer something wider for street photography I'd go the 15mm PL or the  17mm Oly
 The Mad Kiwi's gear list:The Mad Kiwi's gear list
Panasonic Lumix DC-G9 Sony a7 III Sony a7R IV Olympus M.Zuiko Digital ED 60mm F2.8 Macro Sony FE 85mm F1.8 +9 more
captura Forum Pro • Posts: 27,478
I most often use the Lumix 20/1.7 or the 14/2.5. The 14 really "pops."
 captura's gear list:captura's gear list
Sony a7 Sony Alpha NEX-7 Olympus OM-D E-M10 Canon EOS Rebel SL1 Canon EF 50mm F1.8 STM +3 more
Thx,
Mo
Upon further reflection I would like to add the 75mm f1.8 for discreet street shots, especially if they are playing the guitar.
