What is the difference between CBR, VBR 1 pass and VBR 2 pass?
Started Mar 20, 2017 | Questions
DMKAlex
DMKAlex Veteran Member • Posts: 6,484
Can someone explain this please?
Thanks.
 DMKAlex's gear list:DMKAlex's gear list
Panasonic GH5 Panasonic Leica Summilux DG 25mm F1.4 Samyang 7.5mm F3.5 Fisheye Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Leica DG 50-200mm F2.8-4 +2 more
Vesku Senior Member • Posts: 2,964
Re: What is the difference between CBR, VBR 1 pass and VBR 2 pass?
Thanks.
CBR = constant bitrate
VBR = variable bitrate (more bitrate when lots of sharp motion, less with static scene)
2 pass =  First pass anylyses how much bitrate needed and second pass renders the video. Needs twice the time to render.
DMKAlex
OP DMKAlex Veteran Member • Posts: 6,484
Vesku wrote:
Thanks.
Since 2 pass requires twice the time to render, is there any distinct benefit over 1 pass?
And what benefit that VBR over CBR, or vice versa?
DMKAlex wrote:
Vesku wrote:
Thanks.
2 pass optimizes bitrate so it makes smaller file with about the same quality as 1 pass.
VBR makes also smaller file than CBR because it uses only the bitrate it needs. Static scenes uses very low bitrate with VBR but CBR uses max all the time.
DMKAlex
Vesku wrote:
DMKAlex wrote:
Vesku wrote:
Thanks.
Thank you very much. I think I am going to stick with the 1 or 2 pass VBR then.
Osman Vielma New Member • Posts: 1
I tried all 3 options (VBR 2 pass, 1 pass, and CBR) all, more or less, took the same time (5 minutes to recode a long video) and got the, more or less, the same file size (18 MB), the only difference was, VBR 2 pass was definitively better quality. And the second pass, I think, was faster than the first one.
Sean Nelson
Sean Nelson Forum Pro • Posts: 15,944
If your footage was relatively static then you wouldn't expect very much difference between them.  You're more likely to see differences if the footage contains a lot of motion, especially if it's a lot of random motion like the whole frame filled with leaves rustling in the wind or reflections on undulating water.  Or if it contains a lot of cuts to difference scenes.
sludge21017
sludge21017 Veteran Member • Posts: 3,746
CBR probably wasn't turned up high enough.
Entropy512 Veteran Member • Posts: 5,977
In general, the main use case for VBR 2 pass is where you have a very strict limit on file size (such as "must fit on a DVD") and want to get the maximum possible quality for that specific file size.
Otherwise, constant rate factor (one particular method of VBR rate control, there are multiple) is usually best as far as size/quality tradeoffs.  However it's not always a good idea if the goal is streaming, because it allows significant bitrate spikes.  Other rate control schemes don't offer quite as good of a quality vs. rate tradeoff, but avoid large spikes in rate that can be problematic for a stream and some hardware decoders.
Context is key. If I have quoted someone else's post when replying, please do not reply to something I say without reading text that I have quoted, and understanding the reason the quote function exists.
 Entropy512's gear list:Entropy512's gear list
Sony a6000 Pentax K-5 Pentax K-01 Sony a6300 Canon EF 85mm F1.8 USM +5 more
