Preview software for EOS 300D (DS6041) then taking photos MAC-USB
Started Mar 13, 2017 | Discussions
MrAgnwik
MrAgnwik New Member • Posts: 4
Hi,
I have a iMac with USB-cable to my EOS 300D, but I don't get any connections? I would like to see the photo, on my iMac, appear in the software, then I have been taken the photo -but I don´t get it to work. Should I change software?
What do I miss?
Thanks!
Magnus
Digital Photo Professional 4 4.5.20.0
EU 3.6.10
ImageBrowser EX 1.5.2.8
MacOS 10.12.3
iMac 2013
A good place to find software and firmware:
http://support-th.canon-asia.com/?personal&lang=EN
Canon EOS 300D (EOS Digital Rebel / EOS Kiss Digital)
mocha123 Senior Member • Posts: 2,497
Re: Preview software for EOS 300D (DS6041) then taking photos MAC-USB
Hi MrAgnwik,
This could be the answer to your problem, check out link below, also getting a CompactFlash Card reader should do the trick.
https://annaporterartist.com/blog/83636/how-to-import-photos-from-a-canon-dslr-camera-to-mac-os-x-1010-yosemite
 mocha123's gear list:mocha123's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EF 100mm f/2.0 USM Tamron SP 70-300mm F4-5.6 Di VC USD Sigma 17-50mm F2.8 EX DC OS HSM +3 more
MrAgnwik
OP MrAgnwik New Member • Posts: 4
Thanks Mocha123,
Now the camera appears, great!
But, the Canon software dosen´t work.
Is their any other software out their, that could help me? Then I take the photo, I want i to appear, in the program (on iMac Screen), and then I can keep it or dismiss it.
The camera is to old and don´t work with Lightroom, as have the function I was looking for. End of story.
Thanks!
Magnus
Hi,
From the Canon Website listings for Canon 300D
Unfortunately your device is no longer supported under the selected operating system. Please feel free to view our current range of available products.
For non-supported cameras, images may still be transferred by inserting your memory card directly into your computer/device or via a memory card reader.
This product is compatible with the following operating systems -
Windows XP (32-bit), Windows XP (64-bit), Windows Me (32-bit), Windows 2000 (32-bit)
Mac OS X 10.5 (Leopard)
______________________________________________________________________________________
If you can now see the connected camera and the pictures on your camera, select all the pictures and drag them into a folder you have created on your Laptop.
From there start up DPP 4 navigate to the folder where you put them on your computer and you will see all the pictures. You can edit, delete and save pictures with this utility.
Also ImageBrowser should do what you want as well.
Good Luck.
Stan in NH
Stan in NH Senior Member • Posts: 1,898
Using a card reader, or the built-in SD card reader on the Mac, is the simplest way of transferring photos.  Your pictures will open in either the Image Capture utility, Preview, or iPhoto depending on how the computer is configured.  Not all non-Apple photo apps will read iPhotos directly so, if you just want to view your pictures and/or do some minor editing, the easiest route is to stay with iPhoto.
 Stan in NH's gear list:Stan in NH's gear list
Sony a6400 Sony a7R IV
Hi,
It is possible that DPP4 will not be able to see your 300D photo's because of compatibility issues, I would install DPP3 instead if this is the case.
MrAgnwik
Hi Stan,
I contacted Tether Tools and here is theirs answer:
Thank you for contacting Tether Tools.
Please check with Canon on whether that model 300D is capable of tethering. The information I am seeing is that it is not capable, which is why it's not on our list. I see that that camera was introduced to the market in 2003.
Please let me know if I can be of further assistance
The conclusion is that the camera is too old. So, now I have decided to buy a used camera house of Canon 70D, and Lightroom from Adobe.
Many thanks!
Magnus
