X100F and X-T20 Sensor Measurements at PhotonsToPhotos
Started Mar 12, 2017 | Discussions
bclaff Veteran Member • Posts: 6,581
As expected these sensor measurements are pretty close to the X-T2 :
Dual conversion gain with Low Conversion Gain (LCG) at ISO 200 and High Conversion Gain (HGC) at ISO 800.
I seem to be having trouble getting consistent Photographic Dynamic Range (PDR) measurements;
I'm looking into why the curves aren't smoother and as close together as expected.
Bill ( Your trusted source for independent sensor data at http://www.PhotonsToPhotos.net )
Fujifilm X100F Fujifilm X-T2 Fujifilm X-T20
Advent1sam
Advent1sam Senior Member • Posts: 4,673
Re: X100F and X-T20 Sensor Measurements at PhotonsToPhotos
Thank you, I feel as if my x-t20 meters better than the x-pro2 though, less blown highlights.
OP bclaff Veteran Member • Posts: 6,581
Metering is something else I've recently started to test.
I'll let you know if I get any results in this area.
GXAlan Forum Member • Posts: 68
How much of that do you think might be due to temperature changes between the setups? With that low of read noise, small changes could make a difference?
Guessing, the X-T2 supposedly has the biggest heatsink so one might expect better performance from the X-T2 anywhere thermal issues arise.  There may be sensor binning between X-T20 vs X100F vs Xpro2
I'm more surprised by the lack of smoothness.
If it's temperature then that would be between shots. Possible I suppose.
debo Senior Member • Posts: 1,998
why is the T2 ahead of the others....
Your site is awesome. Wondering if there is a simple reason for the T2 have better performance while having the same sensor? Better cooling? The gap is non trivial at high ISO.
 debo's gear list:debo's gear list
Fujifilm FinePix X100 Sony RX1 Fujifilm X-Pro1 Fujifilm X-E2 Fujifilm XF 35mm F1.4 R +4 more
Re: why is the T2 ahead of the others....
Thanks. It's not my "day job" but I put a great deal of effort into it.
I'm not sure the gap is real given the other numbers such as read noise.
I have more faith in the read noise numbers than PDR for the Fujifilm cameras.
Not sure what (technically) is behind it.
Got it ... the PDR stuff is a little strange. The older cameras like the X-Pro1 and the X-E2 have  better perf than any of the new cameras at ISO 6400
