FF & APS-C: How to justify the A7RII purchase
M
mcslsk
Guest
My Sony experience started with the NEX3, then the NEX 6, the A6000, A6300 and A7. Last year, I was agonizing over the question whether to stay APS-C and FF, or just APS-C, or just FF. At one point, I was sure APS-C is all I need. In fact, I sold my A7 which was not bad but behind the a6300 in image quality and speed. The A7 II only added IBIS. Then came the A7RII. When I saw the price tag, I immediately promised myself do not even think about buying it. No way. 42MP are way more than I need.
That promise didn't hold long. Intrigued by the additional IQ I took the camera for a test - and never returned it. There have been plenty of reviews that tell you about the good, the bad, and the ugly. For me, it is 90% complete satisfaction. What needs to be improved in the next model is operating speed. What could be fixed with a firmware update is the configutration of the menu, in particular AF assist behavior so that one can chose the highst magnification to be displayed first. I find it difficult to MF at the lower magnifaction even with focus peaking. But even more important would be an option to assign FF/Super 35 to a function button. Why? The fact that the A7RII doubles as an APS-C camera is for me one of the most important features. Resolution in Super35 mode is more than enough. When I am not out with all of my gear, I can take the E18105/4 as an alrounder, or can use only two or three FF lenses to cover a wide range from 15mm to more than 200mm. My favorite travel set up is the Voigtländer 15mm (23mm), the FE35/2.8 (53mm) and the Canon EF 100/2 (150mm). With the Loxia 21mm (32mm) and the FE55mm (83mm) you can travel even lighter yet cover a focal range wider than most standard zooms offer at better IQ. Of course, on could also always crop in post, for which the A7RII offers plenty of headroom. But I prefer seeing on location how the framing works out. If you combine the price of an a7ii with that of an A6300 (or A6500), all of a sudden the price for the A7RII starts to look reasonable :-)
Hope this helps some of you make a decision.
I rent an A7RII when I feel the need for FF for a particular job.
How many megapixels does the A7r2 have?
What do galaxy hitchhikers in the know answer when asked about the meaning of life?
Bingo!
...Bob, NYC
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
http://www.flickr.com/photos/bobtullis/
http://www.bobtullis.com
Bingo!
You nearly got me there ... it is hard to resist such number magics ... but I will stay with my A7 for a while until there is a not too expensive full frame camera with much better tracking autofocus.
Sure, I sometimes miss in-camera stabilisation and I would be better served with a less reflective sensor, but for now the A7 is my camera! ;-)
The last full moon this spring before the midnight sun enters the sky in Svalbard at 78 degrees north - my A7 does an excellent job even at night in the icy cold polar climate. Panorama from four frames. 21 mm lens. Plenty of detail for close inspection of a 2-3 meter wide high quality print!
Huh?
Or better, if true for you, you don't need FF...
Obviously, you like cropping :-)
Strange that the A7 did not deliver for you, it did for many of us.
Sure, it can double. It is also double the bulk, and triple the cost.
You are a videographer?
Yes, cropping in the A7rII using APS-C lenses is an idea that more and more people are open too. It does allow for much lighter travel, while not giving up the FF when needed or desired.
Rather (used?) A7ii + A6000. Still cost half that of a (used) A7rII.
Or better, one camera (A7rII) versus four cameras (A7ii, A7ii, A6000, A6000).
With as many lenses as you outline, the A7ii would be a fine camera.
If S35 is important, why not look at the A7sII? The A7rII is a compromise for video, although it is the 'next best' in the Sony lineup of FF cameras.
Huh?
There is a significant difference in how teh a6300 senor and software work vs. A7 and A7II. The a6300 is closer to the A7R2.
Yes
Problem 1: AF with adapted lenses. Problem 2: Less image quality than A6300.
It doesn't double bulk. In fact, the A7RII with the FE35/2.8 is rather compact. So it depends.
No, I mean APS-C
But A7II and A6000 don't work well with adapted lenses, and have old sensor technology. But of course, this post was not about saving money.
No, because of adapted lenses and the older sensor technology
Again, misunderstanding. Don't do any video.
Henry
Huh?
Eh, no: https://www.dxomark.com/Cameras/Com...Sony-A7R-II-versus-Sony-A7-II___1127_1035_996
Check the SNR and DR graphs (under Measurements). You can also compare the Scores.
The A6300/A6500 is still a stop behind in ISO, but it matches the A7ii in DR at lower ISO values. It is not close to the A7rII.
In fact, the A6300/A6500 is very close to the A6000. The only change is the one EV increase in DR.
Mind you, this is downsampled to 8Mp, at full resolution the differences are more visible.
As to how the software works, the A6300/A6500 is ahead of the A7rII. It does incorporate the faster processor to enable third party adapters (A6000 lags here), but it has a faster PDAF grid and lower resolution. The A6300/A6500 is a much snappier camera than the A7rII.
The A7 got a firmware upgrade which makes it much closer to the A7ii in features, but the menus are slightly different. The A7ii in operation is close to the A7rII, not to the A6000. The A6000 was already a snappier camera. Some features (e.g. Eye-AF only existed on the A7 cameras).
Yes
No, I mean APS-C
The A6000 has restrictions, not the A7ii. It works fine with 'smart' adapted lenses.
Dumb adapted lenses always worked.
Expressed in cost (or dollars).
You keep saying this, but this 'older sensor technology' still delivers higher IQ. The graphs don't lie.
Bingo!
For what you do, and how you do it. . . you're a role model IMO.
42mp can be a crutch, too. I'm using it to avoid zooms, and just take advantage of the crop ability as is necessary. Well, for the on the go sort of practices, at least. And then there's the demand on computer resources, especially if using uncompressed RAW.
I can't quite express how much I admire work like this, and this particularly.
...Bob, NYC
You are right about the A7II and the AF with adapted lenses. But it still has a worse nosie pattern than the A7RII (check the comaprison tool here at ISO6400). And APS-C crop mode results in a low resolution image. Don't think that the A7RII crop mode is better than an image from the A6300/A6500. But it is just as good which makes me say that I have purchased two cameras in one.
A7 has a "less pleasing" noise pattern, arguably more noise. And it doesn't have uncompressed RAW, which leads to color shift in the shadows when pushing.
I am waiting eagerly for an APS-c sized sensor camera that has better IQ than A7. Maybe in a couple of years.
In the meanwhile, I am dealing with its UI shortcomings, but IQ is not a concern for sure.
Low shadow noise is the major advantage over APS-c bodies. It is simply in another class.
Which only means A6300 has more NR built-in that you can apply in software. You cannot separate details from noise such as in DPR lab test.
As compressed RAW, you will only see this issue in bright edges after aggressively pushing up shadows in evening photos especially. Otherwise it's not a big deal. I still own A7r which also only supports compressed RAW and don't find it's a big deal.
Nevertheless I am glad you could justify A7r II that is in a different league.
That would be too easy, wouldn't it? :-) I think in short, like you, I appreciate the option to "zoom" with my primes.
And then full frame is 2.3 x ahead of aps-c (the surface area of the sensors compared). ;-)
Depends a lot on how you use the camera and post process your work.
Agreed. And I do that a lot.
True.
False.
It may not be the compression but the 14 vs. 12bit file. All I know is that if you push shadows quite a bit on the A7 (and A6000), you get a purple color cast that is hard to remove.
Thanks a lot! I am just a person that enjoy using the camera, playing around a bit with post processing, and that love pictures and art (and all kinds of music)!
Thanks a lot again! ;-)
This happens when you push the files so much that you are close to the noise floor - close to the limits of where the sensor can differ between a useable signal and noise.
When exposing properly, this shound not be a problem, not even for low light scenes. Taking some HDR exposures might be helpful to avoid poor shadow data (tons better than any Canon camera, though!).
I am often taking images in low light with little time to porper set up and expose, high dynamic range. So being able to push shadows to the limits is important for me. But of course I agree in principle.
