I just want to confirm... (Panasonic 100-300 II)
Started Mar 8, 2017 | Discussions
Spacedebree
Spacedebree Regular Member • Posts: 201
Hello.
I just want to confirm that the focus ring on the Panasonic 100-300 *version II* is as stiff or almost as stiff as the ring on the precursor. For me, it does not matter if it has better AF motor or weather sealing. If I can't use the MF on this lens, then it's not worth buying. I'm just curious - why did not Panasonic fix this issue from the first version? I'm so disappointed. It actually get worse as the temperature outside decreases. I guess this is the exact same problem as Panasonic had with the first version. Yay...
I have seen many questions regarding this issue. Now you all know. If any one of you have found an example of this lens with smooth focus ring - please let us know.
I guess I'll go for the 100-400 Leica instead.
Fredrik, and his G80.
 Spacedebree's gear list:Spacedebree's gear list
Panasonic Lumix DC-G100 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Lumix G 25mm F1.7 ASPH
Panasonic 100-300mm F4-5.6 II Panasonic G85
Hatstand Senior Member • Posts: 1,623
My 100-300 II MF ring is not stiff
Manual focus ring on my Panasonic 100-300 II is not stiff at all.
It turns slightly more easily than my 100-400.
Both offer a small amount of resistance so they don't feel "twitchy", "uncertain" or too easily disturbed... but they both turn easily, and smoothly.
I definitely can't describe either as "stiff"...
Albert Valentino Veteran Member • Posts: 9,762
Re: I just want to confirm... (Panasonic 100-300 II)
Perhaps it needs some use to break in. If it doesn't get better i would return or exchange.
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
Astrotripper Veteran Member • Posts: 8,676
How stiff is stiff?
I have no idea how stiff the first version was.
But comparing it to my other lenses, it is less stiff than my 20/1.7 and a lot less stiff than Tokina 300mm Reflex. Almost all the old legacy manual lenses I have are significantly stiffer (except for one Russian Mir which is silky smooth). Samyang 7.5mm is by far the stiffest one.
It is however nowhere near as smooth as the PanaLeicas I have, which are simply the best of all the lenses I own. It is still stiffer than my other primes, like Oly 45mm or Panasonic 25mm.
What I can feel might be an issue is that it might be stiff enough to make it hard to do large rapid movements with it. I mean, if you want to turn it just slightly, it takes very little effort and there is no stickiness of any kind, so precise manual focusing is very easy. But if you try to rapidly make a 1/4 rotation, you're gonna have some significant friction to fight against. It is not effortless like with the Leicas.
On my 10 point scale with 1 being silky smooth and 10 being a "I need a lever to rotate it" it is a 4.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Ranlee Senior Member • Posts: 2,258
Re: How stiff is stiff?
The problem with mine (orig version) is that it is just stiff enough that you want to squeeze it more to gain better purchase on the ring.  In other words I feel if I don't give it a good squeeze my fingers will slip on the ring.  Unfortunately, the more you squeeze the tighter it gets so basically it requires a lighter touch on the ring which is slightly unnatural considering the stiffness to begin with.  I always though it strange that people complained about the zoom ring on the 100-300 and not the focus ring.  The zoom ring on mine is just fine.
Randy
 Ranlee's gear list:Ranlee's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix DC-S5II Canon EF 200mm f/2.8L II USM +10 more
Spacedebree
OP Spacedebree Regular Member • Posts: 201
The two only examples I have tried so far (both brand new, should be added) had a very stiff focus ring to move; both the older and the newer lens. My guess is that the ring, materials and construction is the same, with some weathersealing added on the newer version. I've used all sorts of lenses - as most of us have - and I can say that no other lens is giving me such a....well...bad felling of the focus ring. It's also too easy to press too hard on the ring(s), making it even harder to work with. It feels a bit cheap in that matter (for it's price, especially the second version). BUT -  If I have been unlucky to find lenses with this problem, and if there are better working copies - that's perfect since I have not bought any telezoom yet.
I'm very curious to hear what owners of these lenses are saying.
Regards
Spacedebree
Hello, Randy!
I'm glad to hear that your seem to function well. I guess there might be different batches of this lens. I hope I can a copy of the lens that works to my likings, before I go too hasty and get the 100-400. Have yours been working well the whole time? Witch version do you own?
Regards
Spacedebree
Hello Albert!
Please tell us more about your example; is it the first och second version, and was it like this from the very beginning? Maybe it needs som use as you say - then one I have tried was brand new.
Regards
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Here's odd -- my focus ring isn't too stiff, maybe just a little more than "stiff enough", but it's not quite smooth. I haven't used it much. I also haven't noticed a lot of complaints about the focus ring on these lenses. Maybe I wasn't looking.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
Almagest Contributing Member • Posts: 561
Regards
I have both lenses, and I must say that the focus ring on both my lenses are quite easy to rotate. I can move the focus ring on either lens with just my index finger. When using one finger to operate the focus ring the new lens may be a tad bit easier, but the difference between the two is negligible.
It might help us, if you listed the m4/3rd lenses you have that meet the ease of focus criteria you require, then we might be better able to assist you.
Warren
Hello Albert!
Regards
Sorry. I do not have this lens but was speaking in general terms. I can say this. I purchased a 12-40 f/2.8 with my EM1 last Nov and the lens was wonderfully smooth throughout the range. However, the camera had problems and I had to exchange it. BH Photo asked me to return the lenses as well since they were sold as a set. Anyway, after the swap my new 12-40 f/2.8 lens was noticably stiff in the center zoom range. Over the next month it seemed to break in and the stiffness softened to a more acceptable level.
However, a stiff zoom, especially a long zoom is not tolerable. As a side note I did play with the PL 100-400 lens at a trade show. It seemed good but then the zoom got unacceptably stiff during my five minutes of playing. Turned out the culprit was the zoom lock which if not turned fully will not lock but stiffen the zooming. Fortunately i figured this out while playing with it as I had read about this issue in a few places. I also remember the Camera Store video review of this lens which cited a very stiff zoom - I suspect he did not have the lock turned fully off, which is easy to do.
I don't my post was succinct...
Sorry Geoff.  Since you and Space both misunderstood me a bit I take it it's me.  I haven't seen a lot of complaints about the focus ring either.  The vast majority I have seen have been about the zoom ring and there have been quite a few.  The zoom ring on mine has always worked very well (again, the original version of 100-300).  My focus ring is stiff but not overly unless I squeeze it too hard when it can become very stiff.  I also rarely use the focus ring so I never really cared enough to complain.  I was just explaining why mine can become stiff.
Randy
One finger operation test
I figured I could run a more reletable test. I tried operating the focus ring just using my thumb. Like, having a camera to my eye, holding the lens from the bottom and trying to change focus with just my thumb. It is doable, but there is enough friction to the ring that I don't feel comfortable doing it that way. It has this feeling that I need to put more force into it or that my thumb will slip on it. With two finger operation, I have zero issues. I can rotate it freely and precisely and while it is not silky smooth, it is perfectly usable.
Egregius V
Egregius V Contributing Member • Posts: 538
My 100-300 II arrived yesterday. The focus ring was a bit stiff at first - I couldn't turn it with the tip of one finger. It got easier to turn after a while - now I can one-finger it. It is comparable to the 20mm prime and some other lenses I have. But it is cheap compared with the rest of the lens. It's mostly smooth - just a little scratchy now and then. Unfortunately, mine has some play in it, too. The ring makes a little click when I change its direction of rotation or gently rock it back and forth. And like others have said, squeezing it even a little makes turning it harder.
I probably won't try to exchange the lens. I tried that road before with another lens and ended up keeping the original.
 Egregius V's gear list:Egregius V's gear list
Olympus E-M5 II Panasonic Lumix DMC-GX85 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 +17 more
nw42 Forum Member • Posts: 60
mine works perfectly smooth on the focus ring, exactly like the 14-140.
I got a very early lens in february.
The zoom ring could operate a bit smoother, but then lens creeping would start to become a problem.
 nw42's gear list:nw42's gear list
Panasonic LX100 Leica Nocticron 42.5mm Panasonic Lumix G Leica DG Summilux 12mm F1.4 ASPH Panasonic 100-300mm F4-5.6 II Huawei P10 +1 more
Fineshriber Photography New Member • Posts: 1
Regards
I just received a used 100-300 II. It’s in beautiful condition, but one of the first things I noticed was a “stickiness” in the focus ring operation. Large quick turns seem very smooth, but slow, fine adjustments are very difficult. It helps a little not to squeeze the ring as you turn, but it is impossible to be really precise as it sticks-jumps-sticks. I will keep it, because I will RARELY use manual focus on a long zoom like this, but potential buyers should be aware.
katastrofa Senior Member • Posts: 1,034
... as the actress asked the bishop
 katastrofa's gear list:katastrofa's gear list
PowerShot SX700 Olympus E-M1 II OM-1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +4 more
