Who's more reliable/less prone to malfunction? - Olympus vs Panasonic
Started Mar 6, 2017 | Polls
Inkheart
Inkheart Regular Member • Posts: 473
I guess one of the worst things that can happen to a photographer is a camera failure.
I am regularly using an Olympus E-M5 and Panasonic GX7, and when it comes down purely to shooting experience I would choose Olympus without hesitation.
But it has happened two or three times that the E-M5 would refuse to focus, or wouldn't turn on. So far those were isolated cases, and hopefully the camera will continue to function for the years to come, but all those small things make it that less reliable.
Also, there have been many reports of Olympus cameras malfunctioning in various ways: strap lugs falling out, the shutter curtain lock up, dials falling off.
Strangely, I can't recall reading about any Panasonic cameras failures.
Does that mean Panasonic might be more reliable? Do they have better quality control?
Which brand is more reliable in your experience? Please take part in the poll and share you experiences in the comments.
 Inkheart's gear list:Inkheart's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus E-M1 II Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye +4 more
POLL
Olympus is more reliable (less failures)
15.8% 12  votes
Panasonic is more reliable (less failures)
84.2% 64  votes
  Show results
Jorginho Forum Pro • Posts: 15,370
My Em1.2 stalls every now and then
Yesterday I changed from C1 to C2 and nothing. Tipped the AF. Nothing. Set it to C3...it just did not change a bit (while it is a vastly different setting). Turned the cam off, then on and started at C1 (while starting up). Fine. Than to C2...stalled...Okey..hmm. Didn't need it, just was checking.
Came home. Took out the battery...inserted it again. Switched from C1 to C2..and it worked fine. It has stalled on other occasions as well but somehow it rarely happens and taking out the battery always solved it
No C2 is set to do C-AF at autoISO with burst mode. Fine. But why is the batteryindicator now no longer 39% but instead 36 minutes?? It isn't set for video??? Did look in it too well, but will do whenever I have time.
Did my Panasonics ever stall on me (G1, GH2 and Gh4)....I have to say: no.
Is that worth something? No. 1 Oly and three Panny cams are meaningless. I would add however that I have the impression that for both cams I am not the only one, so may be indeed the lack of complaints about stalling Panny cams or other problems might be a sign of some better QC.
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +8 more
luisflorit
luisflorit Veteran Member • Posts: 8,514
Re: Who's more reliable/less prone to malfunction? - Olympus vs Panasonic
Very nice poll!
My only 2 Olympus 43rd lenses, 12-60swd and 50-200swd broke 3 times. My oly FL50 flash is not working. My EM1 EVF has sunburn. And many more problems with Olympus gear... Even my very expensive 300F4 makes a strange noise while focusing (!!??).
My oooold Pany FZ50 is working as perfectly. My 100-300 (absolutely silent, even after rains, dust, and 23000 pictures), my 20mm, perfect, never a problem.
L.
 luisflorit's gear list:luisflorit's gear list
Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro Venus Laowa 7.5mm F2 MFT Olympus E-M1 +3 more
gary0319
gary0319 Forum Pro • Posts: 10,540
Re: My Em1.2 stalls every now and then
That has happened to me also, but then I realized that I must have inadvertently hit the video button while in C-AF ( at least the audio level bars were on).I also have the video button repurposed to the "magnify" feature so that may have something to do with it.
I don't consider this to be a malfunction,  though.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
Soulhand Senior Member • Posts: 1,467
18
luisflorit wrote:
Very nice poll!
Not really. The question asked for a definite answer about the brands generally, and no one responder has the knowledge to assess that. So all you'll get is people's subjective opinion on what brand is more reliable, based on experience with, at most, a few bits of kit they personally have had.
A better poll would be
  • I've owned both Olympus and Panasonic Kit and have had more reliability problems with Panasonic
  • I've owned both Olympus and Panasonic Kit and have had more reliability problems with Olympus
  • I've owned both Olympus and Panasonic Kit and have equal reliability problems with both
  • I've owned both Olympus and Panasonic Kit and have no reliability problems with either
  • I've owned only Olympus but I have had reliability problems
  • I've owned only Panasonic but I have ha more reliability problems
  • I've never owned either brand, I'm only here by mistake
Then if we got a lot of answers, we could consider drawing a conclusion. Although even then it's statistically dodgy - I have had more Olympus quality issues, but then I have only one bit of Panasonic kit and that's a prime lens so less to go wrong.
But the poll as it stands is only usable for assessing what people believe about quality of the two brands.
Paul
 Soulhand's gear list:Soulhand's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus E-PL7 Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
JDLaing50 Veteran Member • Posts: 3,169
Olympus and their service is more reliable.
 JDLaing50's gear list:JDLaing50's gear list
Sony RX1R II Leica SL (Typ 601) Olympus PEN-F Leica M-P (Typ 240) Leica CL +12 more
leggeron Senior Member • Posts: 1,077
My em5 mk1's shutter had black frame issues at speeds higher than 1/2000th starting every once in while since new and constantly past ~7000 (8th month of ownership) actuations - had to have the shutter replaced under warranty. Sold it right after receiving it from servicing.
Owned an em10 mk1 for 2 weeks - no issues lol. Owned an epl7 for 3 months - no issues.
Owned e410 and e510 for a total of 4 years - no issues.
Owned two gx7 bodies for a total of about 9 months - one stall in the second body fixed by removing battery. Used second body in rain (my bad) - the evf started flickering, after drying it worked without any issues. And no other issues.
Owned gm5 for 6 months - no issues.
Now I have a week old gx80 - no issues.
I'm inclined to say that Panasonic may turn out to be more reliable. This is also based on threads on this forum even taking into account that for every Panasonic body owned by someone there are at least 2 Olympus bodies.
** I usually post from my phone so please excuse any typos, inappropriate punctuation and capitalization, missing words and general lack of cohesion and sense in my posts...
______
http://www.flickr.com/photos/leggeron/
Just so you know how good/bad I am at this.
 leggeron's gear list:leggeron's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GH1 Panasonic Lumix DMC-GF1 +14 more
6
Soulhand wrote:
luisflorit wrote:
Very nice poll!
Exactly which is why I did not answer it.
DP13Photo Veteran Member • Posts: 6,307
I heard of lenses from both having problems. Not as much with bodies.
There was a large thread when that Olympus 12-40 had a cracked mount.
I have had far more Olympus bodies and Panasonic lenses and all have worked with no problems that I can recall.
Dave
 DP13Photo's gear list:DP13Photo's gear list
Sony a7 III Sony a7C Sony a7 IV Sony FE 28mm F2 Zeiss Batis 85mm F1.8 +15 more
alcelc
alcelc Forum Pro • Posts: 19,003
No option suitable for me to vote
I have 4 compacts, 5 mirrorless and 10 lenses all from Pany and the 1st one was bought 14 years ago. Non of them fail me and the 1st one can still be shot as new today. The only repairing cost I paid was a few US$ to replace the lossen silicone belt covering the zoom ring of 14-45 and 45-200 a few years ago.
Even my G1 and 7-14 f/4 had been dropped into a river, came out like water tank and after dried they worked again. Pany Service Center told me it would be a total lost (due to serious oxidation inside and no worth to repair) and should expect sudden death anytime. They were kept on using a few years more until G1's retirement last year. 7-14 is still my main lens today.
So, if there is an option, I would vote Pany is very reliable (instead of "more") and never failure (instead of less failure).
Albert
spencergf Contributing Member • Posts: 641
I have never bought/used anything made by Olympus.  I have been using Panasonic cameras/bodies since the GF1.  I've never had a failure.
 spencergf's gear list:spencergf's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Leica D Summilux Asph 25mm F1.4 Leica Nocticron 42.5mm Panasonic Leica DG Summilux 15mm F1.7 ASPH +2 more
tgutgu Veteran Member • Posts: 4,134
With such kind of post, you can never achieve a reliable and representative answer. Nor can you prove, if all posts are valid.
All I can say that both, my Olympus and Panasonic products have had failures. And products of both brands have shown instability issues (for example my GX8 hangs from time to time).
What I can say is that Olympus has the edge regarding functional firmware updates, and has the more responsive support and a generally fast repair service.
On the other hand, I would choose the product, which I prefer regarding handling, features, performance, and price.
It is unpredictable, which product might fail at which time. I may happen to any product from any vendor.
Thomas
 tgutgu's gear list:tgutgu's gear list
Panasonic Lumix DMC-GX8 Olympus E-PL7 Olympus E-M1 II Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +31 more
Well, this was a quite exaggerated disussion, based not completely clear reasons, which actually caused the problem, with the sample. Since then, the "issue" was never raised again.
Thomas
sapporodan Regular Member • Posts: 128
Just yesterday my EM-5 refused to turn on
Plus it had the well know screen bezel crack that got worse and worse until I had it fixed. Also my old EP-3's command dial fell off, and that needed fixing.
I've had 4 Panasonic cameras, treated them just the same and not had any issues with any of them!
Strange as I always felt Panasonic feel cheaper and less well made!
As for lenses, the rubber grip fell off my Panasonic 14-140 (Mk1) and I somehow got fungus in an Olympus 14-42 R.
Nemo0815 Contributing Member • Posts: 866
The only thing that failed out of my gear was the Olympus FL-LM3, only used it very seldom but at some time the capactior broke and the (expensive) thing was a piece of rubbish.
That is the only Oly product I had longer than 6 months, the rest was Panasonic gear that never failed on me by now.
 Nemo0815's gear list:Nemo0815's gear list
Panasonic Lumix DC-S5 Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 85mm F1.8 Sigma 35mm F2 DG DN Panasonic Lumix S 50mm F1.8 +1 more
PhotonX30
PhotonX30 Regular Member • Posts: 179
I have only Panny equipment, and it has all been reliable.  The only issue has been the swollen rubber zoom ring on one lens.  It remains to be seen if Panny will cover it on their 3- year warranty.
I do feel Panasonic is less trustworthy than Olympus.  Oly seems to regularly update firmware for their cameras and lenses.  Panny, on the other hand, promised to release an update for the original 14- 140 lens to support Dual IS, so, together with other incentives, I decided to buy the ver 1 lens.  They seem to have forgotten the update was scheduled for Feb 2016.
 PhotonX30's gear list:PhotonX30's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS Rokinon 7.5mm F3.5 UMC Fisheye CS +4 more
5
Well judging from the reports on various forums (not only here), this poll seems VERY representative to me.
RSSrsvp Veteran Member • Posts: 3,251
Jorginho wrote:
Soulhand wrote:
luisflorit wrote:
Very nice poll!
If I am not mistaken Olympus sells more cameras worldwide than Panasonic. Therefore how does that get factored into the response. IMO this type of poll really serves no purpose.
 RSSrsvp's gear list:RSSrsvp's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +1 more
Gary from Seattle Veteran Member • Posts: 7,852
Soulhand wrote:
luisflorit wrote:
Very nice poll!
Paul
And you will likely get multiple replies and defenses from a few people who have strong bias and love to hold a grudge.
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +7 more
davob Forum Member • Posts: 84
I can't compare, but will say that when I had my Minolta repaired in 2012, I asked the repairer which were the most reliable brands in his experience. He said "Canon and Panasonic". That did influence me in buying a Panasonic, which hasn't misbehaved in the 4.5 years since.
