Re: Moon zoom - go big or go home?
framedinspirations wrote:
Serguei Palto wrote:
This is the average of 3 shots after resampling by 200%, so the effective resolution of the sensor is enhanced.
Can you describe your software/process whatever for how you "averaged" 3 shots? Thanks!
I have used Adobe PS v.8.1.
The general process includes the following steps (I have used the Russian version of the software, so my translation of the menu items can be not accurate).
1. Loading the group of the RAW files as a stack (File->scenarios (script)->load into stack).
2. Crop all the images to the same useful size if necessary (select all the file items in the stack and apply the crop) .
3. Resize all the images by 200%. (image ->image size->200%)
At this step you increase the quantity of the virtual pixels by a factor of 4. PS makes interpolation for each of the images. You can use different interpolation methods . If you have more than 5 images than the simplest pixel interpolation should be used. In case of small number (2 - 5) of the images the "Auto" method is better.
Interpolation does not enhance the resolution. But it creates a container for the new information which exists in the different images. The real enhancement of the sensor resolution will appear later - after the averaging.
To do the averaging you continue as follows:
4. Align all the resized images (Edit->Automatically align layers->Auto->OK).
5. Create the smart object from all the aligned images (Layers->Smart Object->Convert to Smart Object)
6. Make averaging (Layers->Smart Object->Stack Mode->Averaging.
7. Apply sharpening if necessary. Typically if we average many images then the dynamic range is significantly increased, so a strong sharpening can be applied without increasing the noise.
8. Save as JPEG.
To get the best results the following conditions must be satisfied:
1. A sensor should be without AA-filter.
2. A lens should be very good (diffraction limited). And the apertures larger than f/8 are highly recommended if the pixel size ~4um or less (the f/8 as in my case is not the best , but I had no choice; the Pana 100-300 at the long end and at f/5.6 is not the diffraction limited lens; my copy is sharperst at f/8).
3. In all the images an object should be projected onto different parts of the sensor (my shots are done from hands) .
Below is a testing example. The first image is the single shot. The second image is the high resolution image.
Click "View: Original size" to see the detailes.
Image#1. Single shot
Image #2. The high resolution image. The average of 8 shots after resizing to 64Mpx.
