Zeiss Biotar 58mm f2 vs Helios 44-2 58mm f2
Started Mar 4, 2017 | Photos
doctor ed New Member • Posts: 15
had 2 good turns of luck recently, and found myself holding 2 astonishingly good - and cheap - examples of a Biotar 58mm f2 silver (late 50s), and a Helios 44-2 58mm f2 (an earlier version with a serial starting with a single 0 (so: No. 0xxxxx)
i finally had an extra M42 adapter turn up today, and despite crappy weather, i dragged the kids out down to the water and did some lens swapping on the A7R
8 pics from each lens, wont say which is which. ootc the helios has a little less contrast and color than the biotar, but with -very- minor lightroom tweaking (which i do regardless) i find them incredibly hard to distinguish. from my first impressions, i thought the helios was going to be the better lens and my favorite, but now im not so sure. im calling it an even heat, though each does something a little different to the other making some shots from each clear winners.
curious to see what you folks think. can you see a diference? and if so, which do you like better?
i havent pushed too hard in PP. and definitely no sharpening. the colours were dull due to the miserable day, and photos were taken around 1 hours prior to sunset, so everything was pretty drab.
everything shot wide open at f2 on a 36Mp A7R
lens 1
lens 2
Comment & critique:
Sony a7R
Michel Gomez Forum Member • Posts: 91
Re: Zeiss Biotar 58mm f2 vs Helios 44-2 58mm f2
Hi Doc
These are great shots, and beautiful kids. Wish my daughters would follow me out in the cold and rain for a lens test....
Differences are subtle, but I think I prefer lens 2. To me the bokeh seems more creamy and it the lens shows less vignetting. Would love to see images in plain sunlight..
These are just my 0.02$...
 Michel Gomez's gear list:Michel Gomez's gear list
Canon EOS 5D Mark IV Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 2x III Canon EF 24-70mm F2.8L II USM Tamron SP 90mm F2.8 Di VC USD 1:1 Macro (F004) +2 more
barrym1966 Veteran Member • Posts: 3,517
I like lens 2 better
 barrym1966's gear list:barrym1966's gear list
Sony a7R Sony a99 II Sony 85mm F1.4 ZA Carl Zeiss Planar T* Sony 24mm F2 SSM Carl Zeiss Distagon T* Sigma 35mm F1.4 DG HSM Art +3 more
You should try to get hold of a Jupiter 3 lens 50mm 1.5
OP doctor ed New Member • Posts: 15
Yup, I'd agree #2 has the smoother bokeh... it's the Helios
back-story: my go-to lens in the 50s is a voigtländer 50 1.5 which renders a buttery smooth bokeh transition (plus is disturbingly sharp and quite quick to hit focus - keeper rate from the voigtländer is really good).
I was hoping for a bit of the 'biotar craziness' out of these two lenses in order to offer something new over the voigtländer. As far as I can discern, the biotar actually does 'being a biotar' better than the Helios does. And the Helios does better at being a 'generally good lens' than the biotar does... which i found a bit surprising. I was expecting the helios to be a bit softer and more vignette-y than it is.
from my 2 lenses... the biotar swirls more and has a more distracting bokeh (what I was looking for). It's very sharp in the middle wide open, vignettes and goes soft to the edges quite markedly (which doesn't bother me). The contrast and colour are stronger than the Helios ootc, but it's a small Lightroom nudge to equal them out. The Helios has much nicer softer bokeh which still induces a swirl with the right background elements, but isn't quite so busy and distracting as the biotar. It's quite sharp in the middle wide open, but (probably due to the contrast differnce) doesn't seem as sharp as the biotar.
Issue for me with both: the focus turn is enormous... 270deg from stop to stop. That's a lot of finger-work with two kids tearing around.
im keeping both lenses as they're both terrific examples, but for the time being, the biotar is the one mounted to the camera. Makes a slightly crazy image, and also oozes a bit of old-school cool in polished Aluminium.
another shot from the biotar (tldr; lens #1). No risk of a papercut from the sharpness in this particular pic, but I think is a great example of the look I was hoping to get from this Lens Duo.
DAVID MANZE Veteran Member • Posts: 6,390
I really don't know, I have the Helios 44-2 and I don't remember the swirly bokeh being as strong as the second lens. I don't know the Biotar at all, but the second swirls like a goodun!
My two favourite pics are the B+W girl under the bridge, nice background blur just enough without going OTT, and the girl pulling the miserable sad face....great pics!
Dave's clichés
 DAVID MANZE's gear list:DAVID MANZE's gear list
Nikon D750 Nikon D500 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 28mm f/2.8D +17 more
James Larsen
James Larsen Veteran Member • Posts: 4,500
Both look really nice. The last shot is a really great shot!
I love Photography & Cinematography.
Follow me on 500px: https://500px.com/jameslarsenmi
Follow me on Twitter: https://twitter.com/JamesLarsenMI
My YouTube Channel: https://www.youtube.com/channel/UCglBlmPTAGoV29E-nyRcbDw
 James Larsen's gear list:James Larsen's gear list
Canon EOS 6D Canon EOS 80D Canon EF 85mm F1.8 USM Canon EF 24-105mm f/4L IS USM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
with slight pp adjustments for contrast and colour to make the comparison in rendering a little clearer. the difference in contrast captured by the biotar remains evident though:
Biotar (lens #1)
Helios (lens #2)
just thought id update this with some random images from both lenses. not so much a 1:1 copmparison, but a commentary on things worth mentioning
firstly - helios, shot straight into the sun, and kept it together. flare to the left of frame and through the bottom has dulled contrast and actually helps the subject in the middle to pop a little more. certainly not bad performance in really bad conditions. a bit of a push in pp, but nothing particularly hard nor selective. the helios is proving to be quite a 'reliable' lens... sharp, creative bokeh but not crazy nor dominating, and seems to land me decent keeper rates.
and today (and actually the reason for this post)... the biotar...
Im having a real love hate relationship with this lens. i want to love it. i want the shiny aluminium finish and beautiful machining to actually make pictures as good as it itself looks, its letting me down most of the time though
the bokeh is picky, sometimes it works, some time it doesnt. sometimes theres a massive amount of glow in in-focus highlights, sometimes not and its suddenly sharp as nails. i cant pick it yet, and im not sure when i want to use it. i took it out today, and have maybe a 5-10% keeper rate. its definitely not a 'shoot what ya got' style of lens.
that said, for todays pile of crap images, it comes along and pulls this hat out of the bag! i suddenly forgive all its misdemeanors, and it can stay! what amazing separation, and for f2?! just wow, freaken wow...
(not a whole lot of pp in this one either! a little bit of levels and contrast, but really nothing much... thats more or less how it looked ootc!)
Raymond Wave Senior Member • Posts: 1,023
Nice pics, like the candid style, but "little" pp only? Looks very processed to me, strong faded effect, must be 10-15% cut off from the blacks?
 Raymond Wave's gear list:Raymond Wave's gear list
Nikon Z6 II
original without processing
i pushed the blacks as you rightly observe, but as you can see it doesnt change the character of the shot dramatically - hence 'little' as i dont think it really 'altered' the nature of the shot as captured that much. that background washout is 100% lens. (i batch processed it as one of a series from todays outing - i didnt really do anything specific to this particular image per se)
edit - or are you talking about the pics from the first post? yeah, theyve been pp'd too with a similar curve. wasnt an exercise in colour though, more in render, bokeh, sharpness and feel. i took two lenses, went shooting with the kids, played with the images as i saw fit, then simply stood back and asked myself which lens i liked more.
doctor ed wrote:
original without processing:
Yeah, meant all the pics in this thread. All seemed a bit washed out / faded and in the cold side (?) of white balance, or maybe magenta tint or something. But I see now that it's partly due to the lens(es).
I know this is a bit off topic already, but is that your own preset or VSCO or something? Would be interesting to see how a vintage lens like these would behave with some VSCO presets :). I have a feeling the combo might work quite well.
Nikon Z6 II
UGPRO Contributing Member • Posts: 615
Lovely shots
 UGPRO's gear list:UGPRO's gear list
Nikon D700 Nikon D810 Nikon AF Nikkor 85mm f/1.8D Nikon AF Nikkor 180mm f/2.8D ED-IF Sigma 50mm F1.4 EX DG HSM +8 more
