Leica SL Sensor Measurements Published at PhotonsToPhotos
Started Mar 2, 2017 | Discussions
OP bclaff Veteran Member • Posts: 6,718
Re: Leica SL Sensor Measurements Published at PhotonsToPhotos
Jared_Willson wrote:
bclaff wrote:...
At any rate, here are the values I got assuming an SNR of 10 dB constituted the noise floor:
ISO 50: 11.3 EV 13.1 / 10.81 (EDR / PDR)
ISO 100: 10.9 EV 12.2 / 9.88
ISO 200: 11.1 EV 13.3 / 10.10
ISO 400: 10.7 EV 12.4 / 9.14
ISO 800: 9.6 EV 11.5 / 8.15
ISO 1600: 8.2 EV 10.5 / 7.17
I have added my values in BOLD next to yours.
The are from Read Noise in DNs versus ISO Setting
And I also added the PDR values from Photographic Dynamic Range versus ISO Setting
I doubt we actually have any disagreement here.
No disagreement; just discussion.
1) I'm sure you are right about the Leica changing things up during firmware revisions. No reason to doubt--you've looked and I haven't.
2) I agree that engineering dynamic range is fairly well defined--DR = 20 log (Full Well / Read Noise). I, like you, do not find those values particularly realistic for photographers. I was reporting out my version of Photographic Read Noise, and we don't quite have the same assumptions for that. For example, you use a SNR of 20 as the noise floor. I was using 10. That's why I reported out a DR that is slightly larger than you did in your original post. I wasn't trying to contradict your values--just show that the trends I found were in agreement with the trends you were finding. It's on the definition of a useful photographic dynamic range that I don't believe there is a strong consensus.
I didn't even realize your intent.
FWIW, PDR is SNR 20 normalized over the Circle Of Confusion (COC), not per pixel like EDR.
3) You're right that I was jumping the gun in assuming the lack of linearity near the clipping point is because Leica applies a curve. It could just be the anti-blooming gate kicking in.
4) Like you, I am confused why DXO isn't showing a blip in their data, even if Leica have changed the ISO for the crossover point. I definitely see it--just as you do. I've run the tests twice now on my camera, and it is definitely there. It's not huge, but it's definitely too big to just be a simple measurement error.
Bill ( Your trusted source for independent sensor data at http://www.PhotonsToPhotos.net )
Jared, thank you for this. Unfortunately for me, I don't do night landscapes necessarily, in fact I mostly do very long exposures during the day; and as you said I do them for expressive reasons, so for me - taking your example as an example - if I need, say, 8 minutes at ISO 100 for the clouds to be blurred just so, going for 1 minute at ISO 800 is not an option.
So in short - you are saying that exposure time being equal I am better off using ISO 200 rather than ISO 50 or keeping noise down? Thanks!
Yes, if exposure time isn't an issue going to ISO 200 is a "no brainer".
Jared_Willson Contributing Member • Posts: 542
bclaff wrote:...
Can you point me to a reference on this?  Like you, I agree that something like your Photographic DR is a more useful indicator of the useful dynamic range of a camera, and that it is significantly different from engineering DR  which simply assumes that the noise floor is where the read noise and the signal value are equal (SNR 1).  I also understand that the Circle of Confusion is the blur size for a given format that will still appear to be point-like on an 8"x10" print at a viewing distance of 10" (at least traditionally).  I'm not sure how/why the two concepts are related.  Just that you measure your SNR of 20 across a different number of pixels, depending on the pixel pitch and overall size of the sensor.  Again, I'd love to see a reference if you can point me to one.  I'm curious how you developed this process and particular set of standards.
- Jared Willson
Try the links under "Further Reading" on the PDR Chart page.
vbd70
vbd70 Veteran Member • Posts: 6,027
vbd70 wrote:
Jared,
thank you for the comprehensive explanation - much appreciated indeed.
I see both white-ish speckles AND black, bigger ones; I thought either appeared randomly, but now I have a better understanding of the phenomenon.
Would making the back frame shorter than the actual exposure help in limiting these? Some manufacturer use to have a black frame shorter than the actual exposure, and I thought this might be the reason why.
Thanks again, best
Vieri
Vieri Bottazzini, Leica Ambassador, ABIPP EP
https://vieribottazzini.com
https://vieribottazziniworkshops.com
I haven't seen anyone scaling their dark frames, but it is certainly possible to do. It's a little more process intensive. Here is the standard process:
Take a light frame, for sake of argument 5 minutes duration
Take a dark frame, the same five minutes
Subtract the dark frame from the light frame. That's your new final exposure.
Here is what you would do for a scaled dark:
Take a light frame
Take a bias frame (shortest possible exposure with the shutter closed--just read noise)
Take a shortened dark frame, say half the length of your light
Subtract the bias from the dark frame
Multiply all values in the dark frame by two
Subtract the bias from your light frame
Subtract the new 2x dark from the light
The result is your new, final exposure
Scaled darks work fairly well as long as the exposures aren't long enough for hot pixels to be clipping.
I'm not certain how best to address them aside from what you are already doing. In astrophotography, most people choose to use master darks (which will create a better result than a single dark frame) and dither their images--each image is slightly mis-aligned from the last, and then they are averaged together using a statistical method such as "sigma clip" to completely remove hot and cold pixels. That is technically possible with a terrestrial image as well. You could take five separate two minute exposures or so with the tripod moved ever so slightly between frames, then use a sigma clip combine to average the frames. Of course, Photoshop and Lightroom don't have sophisticated stacking algorithms so you'd have to use some astronomy software for that, and most astronomy software doesn't do a great job on aligning terrestrial images since it expects point sources to be available, but it is definitely doable. I have done it occasionally. I wouldn't recommend it, though, unless you just can't accomplish what you want to with the techniques you are already trying.
Perhaps an incremental solution would be to cut your exposure duration significantly (to lower the thermal noise), boost your ISO to compensate, then take multiple exposures and average them together in Photoshop without any re-alignment. You wouldn't get the benefits of dithering, but you would start out with lower thermal noise. This comes at the cost of higher read noise in your image, but I bet you could find a reasonable balance. For example, instead of one single 8 minute exposure at ISO 100, try 8 separate one minute exposures at ISO 800 averaged in Photoshop as separate layers. You can do this with the "smart object" tool. That should give you an overall cleaner result without requiring any more time when shooting. I'm not quite sure what it will do to the clouds, but it might work quite well. Give it a shot.
Jared Willson
Thank you Jared, most informative as always. My Pentax 645z used to take a dark frame slightly shorter than my exposure.
About your last point, as I answered below to another of your previous posts I do long exposures for expressive reasons, so for me - taking your example as an example - if I need, say, 8 minutes at ISO 100 for the clouds to be blurred just so, going for 8 times 1 minute at ISO 800 is not an option, unfortunately.
Best,
Vieri
 vbd70's gear list:vbd70's gear list
Leica SL (Typ 601) Leica CL Leica APO-Telyt-M 135mm f/3.4 ASPH Leica SL 90-280mm F2.8–4 Leica Summilux-TL 35mm F1.4 ASPH +4 more
vbd70
Bill,
Thank you. Two more questions.
1. You definitely say that if I get, i.e., 8 minutes @ ISO 50 I'd be better off adding one more ND and go to 8 minutes @ ISO 200 for less noise, correct?
2. Help me understand this - from your graphs it shows that ISO 50 is better for photographic dynamic range, but that ISO 200 is better for read noise. I was under the impression that the two were linked: the better the read noise, the better the DR. Is it not so?
Thank you very much - between you and Jared I learned quite a lot so far with this thread, much appreciated! Best,
Vieri
Bill,
Provided you have apparent noise then it will be lower at ISO 50 than ISO 200.
The chief advantage of any lower ISO is having the option to gather more light (your NDs affect this).
If you're unable to use a longer exposure or larger aperture then in your case you may see no difference.
Read noise and dynamic range are loosely correlated but lower read noise doesn't necessarily mean higher dynamic range.
As you raise the ISO setting you increase internal amplification (gain) and highlights get clipped from the top end.
So, although you get better shadows by raising ISO, you lose highlights; it's a trade-off.
Joe Pineapples II
Joe Pineapples II Senior Member • Posts: 2,490
Source of noise in long exposures
The tricky thing is that Bill's measurements are highly relevant to people doing "normal" exposures who want to extract the best performance from their cameras, while your images are being affected by thermal noise issues due to the very extended exposure times that are more like those encountered in astrophotography. Because you are blurring movement in your scenes, then the technique of stacking multiple images would be a possible approach. However, the aesthetic effect of say an 8-minute exposure vs a stack of 8 1-minute exposures would be a matter of personal taste.
In general, techniques by themselves are neither good nor bad - only photographs are good or bad!
J.
Robgo2 Veteran Member • Posts: 4,918
Re: Source of noise in long exposures
J.
It would be much appreciated if someone would summarize what is the best setting for DR and noise for those of us who do "normal" photography. I am not technically savvy enough to figure out whether it is ISO 50 or 200.
Thanks,
Rob
J.
The simplest answer is that it's always (some exceptions apply especially for the use of flash) best practice to use the lowest ISO setting that gets the job done.
In this case it turns out that using ISO 100 rather than ISO 200 doesn't help much; but it doesn't hurt.
janlu
janlu Veteran Member • Posts: 7,152
Bill Claff :
Hi Bill , a bit out of topic , but I see you are around here , can I ask if you can kindly explain why the M240 behaves so different in the graph below (input-referred noise )
It's the only one linear , what does it mean in practical terms ??
Thanks in advance and best regards .
Re: Bill Claff :
So, there a a few things going on there (link to interactive chart).
The large drop for the Q and the SL are due to dual conversion gain.
It's unclear why the M has such high Input-Referred Read Noise at higher ISO settings.
I double-checked the numbers and they appear to be correct.
Note how the Read Noise in DNs goes up with a slope a little more than 1 rather than a little less:
janlu
Re: Bill Claff :
Thanks Bill .... indeed I have seen only CCD sensor behave similar in your study like the old Leica S and the Nikon D200 , etc.... the New Leica S Type 7 that sport cmos in fact behave just different and more similar to the Q , SL and almost the same as the M10.
Quite unusual for the M240 indeed .
Reference Graph
Always interesting , thank you Bill .
Best Regards , Gianluca
J.
Bill, thanks for the clarification.
Rob
Joe Pineapples II
J.
Thanks,
Rob
There is no recipe AFAIK that applies to all cameras and all scenes.
The manufacturer hires a lot of technically savvy engineers to program different auto-exposure and "scene" modes in the camera that apply the best general setting for different broad categories of photograph. These are based on a lot of modelling and measurement. A "recipe" someone tells you on the internet is unlikely to be better.
AFAIK the only way to do better is the old-fashioned one: learn more about how the process works yourself. It isn't rocket science. You can get to a pretty sophisticated level of understanding of digital photography with no more mathematics than the square root of a number. The internet is a great resource for learning, and digital cameras make it easy to do experiments.
J.
The simply physics of photon noise make it universal advise to gather as much light as possible which means starting with the lowest (normal) ISO setting and raising it only after you have set aperture and exposure time.
Dr. Ulrich Rohde Senior Member • Posts: 1,862
This was a very good and educational discussion . According to Leica, the native sensitivity of the sensor is about 300, so to get to 50 there is attenuation used which reduces the S/N ratio and for higher ISO like 6400 there is gain which pushes up the signal and noise floor. Key is to maintain the best S/(S+N) ratio, not always easy.
Would be nice to find more science oriented discussions  here and fewer emotions.
 Dr. Ulrich Rohde's gear list:Dr. Ulrich Rohde's gear list
Leica X Vario Leica Q Canon EOS-1D Mark III Leica M8 Leica M9 +13 more
I'm wondering if you can cite any source for your ISO 300 figure.
According to DxOMark Measured ISO testing the native ISO is ISO 50.
According to my Photographic Dynamic Range (PDR) testing as well as Read Noise measurements it looks like the sensor has dual conversion gain that starts at ISO 200.
I know of no camera design that attenuates signal below native ISO; only exposure is adjusted and gain remains fixed as if at the native ISO.
Regards
Yes, it came from Leica'a sensor department
bclaff wrote: I'm wondering if you can cite any source for your ISO 300 figure.
Well, that's a bit hard to verify.
I know of no camera with a native ISO of higher than about 224.
In any case the ISO 300 figure makes no sense given the measurements.
So it's ISO 50 as far as I'm concerned.
