Wide-angle weather-reistant lenses for Pentax?
Started Mar 1, 2017 | Questions
Sir Autofocus Regular Member • Posts: 225
Are there any wide-angle weather-resistant lenses for Pentax mounts, preferably DA since those are usually much less expensive than FA? I see that there's a Pentax 12-24 and a Sigma 10-20, both of which would probably work for me except that I want a lens that's weather-sealed so that I can take it out into rain and snow.
I have used my K-3 with the Pentax 16-85 lens in heavy rain. The photo quality was mediocre in the poor light, but the camera and 16-85 lens had no problems with the rain. I'd like a lens with similar weather resistance in something like a 12-24 or 10-20 range.
Pentax 16-85mm F3.5-5.6 WR Pentax K-3
MightyMike Forum Pro • Posts: 41,691
Re: Wide-angle weather-reistant lenses for Pentax?
After you get a few drops of rain on the front element the image quality will be worse than mediocre. Yes I'm aware that there are some situations where you want weather sealing on a wide angle lens that doesn't involve water on the front element but out in heavy rain is not one of them.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
OP Sir Autofocus Regular Member • Posts: 225
I probably won't try to shoot in heavy rain again, but I would like something that I can bring outdoors in mild rain or snow. Any suggestions?
over 10 years with Pentax and I've never owned a WR or (*) lens except for resale, I have no problems shooting in the snow, mild rain/mist is fine to a point... at that point due to water on the lens contacts the lens/camera doesn't exactly function correctly all the time, a quick wiping of the contacts usually gets it back to normal, prolonged exposure may require a longer drying out period. I've never got any amount of water in a lens and aside from the mount surface I've never had any water end up in the camera either. I prefer not to shoot in excessive rain and take care to minimize the water that hits the gear whenever possible.
Mike from Canada
OK, thanks for the advice. That Sigma 10-20 looks awfully tempting, and people seem to like it. I may get one.
Ptitboul Forum Member • Posts: 78
There are not many weather-resistant lenses with focal length shorter than 16mm.
There is the DFA 15-30, of course, but I won't recommend it for a K-3.
There are also the Irix 15mm f/2.4 and Irix 11mm f/4. They are for full frame too. The 11mm may fulfill your needs, but it is not available yet.
And I think that's all.
 Ptitboul's gear list:Ptitboul's gear list
Pentax *ist DS Pentax K-5 II Pentax K-S1 Pentax K-1 Pentax smc FA 50mm F1.4 +12 more
JohnXLondon Regular Member • Posts: 239
OpTech sell rain covers. Take a look at them. Covers lens and body in one go. Would be worth considering I suggest even with WR lenses, but gives you the choice of the 12-24 et al
 JohnXLondon's gear list:JohnXLondon's gear list
Canon PowerShot S3 IS Fujifilm X20 Panasonic LX100 Pentax K10D Pentax K-3 Mark III
miles green
miles green Veteran Member • Posts: 7,827
Only the 16-85 and DA* 16-50, that i'm aware of. And the 20-40 may have better IQ but is not as wide.
Unfortunately...
Of course there is also the 15-30/2.8 for FF.
I believe the metal IRIX 15mm is weather sealed (and FF)
So I'd second the rain-coat solution....
Miles Green
Pentaxian with chronic LBA since 1997
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
Rahto Senior Member • Posts: 1,605
I can confirm that the Sigma 10-20mm 3.5 works well on the K3 but don't know how it is in the rain as I'm not WR.
Bob
 Rahto's gear list:Rahto's gear list
Canon EOS D60 Pentax *ist DS Pentax K-7 Pentax K-3 Pentax K-3 II +72 more
(unknown member) Senior Member • Posts: 2,206
Does that protect against high humidity?
I doubt it, you'd probably want to store your lenses in a heated dry box with lots of silica gel and ventilation if high humidity is an every day thing for you.
Mike from Canada
Ari Aikomus
Ari Aikomus Veteran Member • Posts: 9,643
I would not count on WR much..
I like WR as some kind of additional proof, but I don't trust it as real weather-resistant feature.
If I want real weather-resistant for rain and snow, I use this:
...and silica-gel bags after wet/cold shooting session.
So - get Sigma 10-20 (if you like it) without any WR worries and maybe This my few dollars solution is very workable...for you too.
Ari
Mike from Canada
- Ari Aikomus -
'Why should I feel lonely ? is not our planet in the Milky way?'
 Ari Aikomus's gear list:Ari Aikomus's gear list
Sony a5100 Sony a7R II Pentax K-1 Panasonic GH5 Fujifilm X-A5
Petroglyph
Petroglyph Veteran Member • Posts: 6,096
You're using a K3 so the only WR options are *16-50 & 16-85 + the 15-30 is WR and can be used on a K3 for 23mm equivalent FOV but, as I'm sure you already know, it's big & pricey.
In FF land the 24-70 also counts as a WR wide, FWIW.
They have a DFA* wide angle on the lens road map.  It will likely only be wide angle FOV when used on a FF camera (around 35mm?).  It will be AW though, as star lenses have been lately.
 Petroglyph's gear list:Petroglyph's gear list
Sony a7R II Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Samyang 20mm F1.8
Tatouzou
Tatouzou Senior Member • Posts: 2,081
Bob
My son has the Sigma 10-20. It is not a rugged built, rather light plastic, and not WR at all.
By the way, my son and I, we both dont praise it much, and dont use it much neither.
 Tatouzou's gear list:Tatouzou's gear list
Panasonic Lumix DMC-LF1 Pentax K-3 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Pentax smc DA 17-70mm F4.0 AL (IF) SDM +24 more
I don't know which one you have but the quality of my 10 -20 F3.5 HSM is fine by me for both outdoor and interior shots.
Tatouzou
The compositions are nice.
But only the grass in front is in focus in the first two images, the trees and leaves which are the main subject are soft.
In the third image, only part of the bridge is in focus, the trees at the far end of the bridge, which are where the composition leads the eye, are soft.
Yet, all three pictures have been shot at 10mm f8: everything should be in focus and the contrast and clarity should be better.
IMO, this means the lens is soft at infinity, with under average contrast and clarity. Something very common in ultra wide angle lenses.
Which is exactly what I meant when I said it did not impress us.
Kevin Stephens Regular Member • Posts: 193
15mm f4 limited and waterproof bag, jacket
Built in lens hood to keep water off the front, small enough to keep in a small bag and take out when you need, protect with umbrella etc and still relatively tough to withstand weather if not actually sealed, fewer pas for the rain to get in than with a zoom, not forgetting excellent IQ
JNR
JNR Veteran Member • Posts: 4,652
Not to mention that a good wide rubber band or even sandwich baggie bunched up to seal off the mount area pretty well takes care of the problem at the mount. I do have the kit WR lens for the very occasional situation when I absolutely need to get a shot in the rain. Yeah, optically somewhat marginal, but these situations rarely yield an award-winning image. Not that this is good, but somewhat typical:
At left, circumspect Ira Block apparently wondering why would I bother.
JNR
www.jamesrobins.com
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
MightyMike wrote:
I doubt it, ...
My thought too.  I'll take the weather sealing, thanks.:-P
Greyser Veteran Member • Posts: 6,802
There are two more wide angle solutions not mentioned above:
  • Pentax 16-45/4
  • Sigma 8-16/4.5-5.6
They both good on APS-C. However, they are not WR and need rain sleeve or rain other protection.
 Greyser's gear list:Greyser's gear list
Nikon D500 Nikon D850 Nikon Z9 Sigma 24-105mm F4 DG OS HSM Sigma 500mm F4 Sport +3 more
