Wide angle conversion lenses
Started Feb 28, 2017 | Questions
Slyngej New Member • Posts: 1
Hey
Does anyonw have any experience with wide angle conversion lenses on the Canon 17-55 f2.8 lens?
Somthing like this: https://images-na.ssl-images-amazon.com/images/I/4113usm-rhL.jpg
The thing is, the lens have a 77mm diameter and im afraid it will further suffer bad vignetting.
Ive used one on a 18mm lens with a 49mm ring, and it surprisingly well.
Its quite expensive if its really crap.
Im a light backpacker and just came across this, and wondered if i could a few ounces of weight.
Sidekicker Senior Member • Posts: 1,771
Re: Wide angle conversion lenses
There is usually a market for anything if priced right, and there is an actual need.  Don't let a high or low price be an overriding factor in determining value and quality.
In regards to your question, no, except for a Canon close-up lens, I have never used an accessory of that kind on my SLR lenses.  On the other hand, I have used wide and tele attachments on a P&S.  The results were mixed at best.
If there is no downside to returning the product if not satisfied, I see no reason why you shouldn't give it a try however.  Be sure to give us a report later on.
 Sidekicker's gear list:Sidekicker's gear list
Sony RX100 VI Sony a6600 Sony E 35mm F1.8 OSS Sigma 56mm F1.4 DC DN | C (X-mount) Sony E 16-55mm F2.8 G +4 more
Peter Kwok
Peter Kwok Senior Member • Posts: 2,635
Not sure what this thing does, but it looks like a single element filter.
These types of screw on front elements are close-up lens. Like reading glasses or magnifier lens, they shorten the focal length of the original lens. The field of view is wider, but you cannot focus to infinity.
Wide angle converter needs multiple elements. They are usually designed for a particular P&S camera. I have never seen any generic 77mm diameter converter.
Anyway, why would you put a Coke bottle quality glass in front of a $800+ premium lens?
Peter Kwok
Click here for my PBase gallery
WYSIWYG - If you don't like what you get, try to see differently.
 Peter Kwok's gear list:Peter Kwok's gear list
Canon EOS 5DS Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 14-35mm F4L IS USM Canon EOS M6 +8 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
I can understand the attraction, but I can almost guarantee that conversion lens will be pretty nasty. Wide angles are already incredibly complex engineering marvels and a fair number already barely make the cut. Slapping another "iffy" lens on the front is bound to cause problems.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
