Q compared to RX1Rii - especially for miro3
Started Feb 28, 2017 | Discussions
brick33308
brick33308 Veteran Member • Posts: 6,563
5
I opened the box on the used, mint condition RX1Rii yesterday for the first time and snapped a few pics. Below are 2 of them.
Here are my thoughts comparing it to the Q. Image quality is of course excellent with much higher resolution than the Q, allowing for better cropping than the Q. And although I didn't shoot in low light/high ISO conditions, I expect that the RX1Rii will likely also best the Q in that regard. Also I love the tilt out LCD on the RX1Rii and wish it was on the Q (much to the horror and dismay expressed by others on this forum when I dared suggest such heresy).
However, I've come to prefer the Q's 28mm length over the RX1Rii's 35mm length for street work, and I prefer the look of images shot on the Q at f1.7 versus on the RX1Rii at f2. Also, surprisingly because I expected the opposite, the RX1Rii is almost too small (even though it's solid, has heft and feels well made), so I prefer the size/weight/feel of the Q over it. Also, let's talk auto focus. It is brilliantly implemented on the Q and puts the RX1Rii to shame in that regard. Also, the Q is uncluttered, reeks of simplicity and inexplicably is just more fun to shoot with - don't ask me why, I'm not sure I can articulate it. Perhaps I've bought into the Leica hype, but whatever, it manifests into enjoyment that puts me in the moment of just snapping pics without thinking about the gear that produces them.
Verdicts for me: Q wins over the RX1Rii, so I'm going to box it up and put it up for sale on FM. There are people lined up to buy a used RX1Rii.
Panasonic Lumix G 42.5mm F1.7
Dr. Ulrich Rohde Senior Member • Posts: 2,519
Re: Q compared to RX1Rii - especially for miro3
I have both cameras and agree with you on all points. The 28mm is a good choice and 35 is a bit close to 50. On the M 10 I have used the 28 mm frequently and there is no M and M lens combination which produces the same quality picture as the Q. And yet I would really like to have a Q-Plus ( with a 2.5, better 2.8 ) zoom 28 > 50mm optical and then 75 maybe 90 mm electronically but using as max a 36 MP sensor , similar to the Sony.
The Sony users interface is must be an acquired taste , or simply said : cumbersome .
 Dr. Ulrich Rohde's gear list:Dr. Ulrich Rohde's gear list
Leica X Vario Leica Q Leica Q2 Leica M8 Leica M9 +14 more
athensGA Contributing Member • Posts: 778
Nice brief comparo.
I had the Q for a year and agree with your assessment. In particular I really came to appreciate 28mm for general use. But when 28mm is not appropriate it's just REALLY not appropriate. That made it hard to swallow being wedded to a $4000 28mm camera.
Plus i hated having to be 'worried' about it all the time, dropping it, scuffing it etc. For example, i just went to Hawaii and my xt1 got abused with hiking, sand, etc. I would have had to leave my $4000 camera at home for a photographic dream trip, which I just couldn't justify doing.
I ended up selling the Leica, but oh do i miss it.
 athensGA's gear list:athensGA's gear list
Leica M10 Fujifilm X-Pro3
miro3 Veteran Member • Posts: 3,048
Thank you very much!
Is the AF on the Q that much faster than on the RX1Rii?
Those are nice shots from the RX1Rii.
Yes, a Q Vario with a zoom will be a very desirable camera for me.
I would prefer a 25-50/2.8 zoom.
Touch tiltable LCD, 4K video, improved low light performance.
brick33308
OP brick33308 Veteran Member • Posts: 6,563
Yes much faster, no hunting. Makes a difference when peeling off multiple shots when shooting from the hip. Q's image quality is as good as the RX, just not as many megapixels
Irakly Shanidze
Irakly Shanidze Veteran Member • Posts: 6,570
I fully agree on 28mm limitations, but not on your logic of not using the camera due to its high price. When I was a kid, my tennis coach said "always take good care of your racquet, but never protect it when you play". As simple as this: if you are busy protecting your racquet, you lose.
Irakly Shanidze
www.shanidze.com/en
www.artphotoacademy.com
 Irakly Shanidze's gear list:Irakly Shanidze's gear list
Leica M9 Leica S2 Leica SL (Typ 601) Leica M10 Panasonic S1 +17 more
Nice thoughts, sir, thanks. I just really struggled with the concept of owning a $4000 camera. Not that it wasn't worth it and not that i wasn't totally smitten by the thing. It's a shame because i have a $8000 trail bike and i abuse that thing like it was stolen.
brick33308
Buy a lightly used Q from a reputable place like Fred Miranda if one comes up for sale. I did that and got a great one- saved lots over buying new.
brick33308
Oh, and my trail bike is a $3K Trek Superfly 8 that also gets abused regularly : )
Irakly Shanidze
See? My point exactly. Once you bought it, it is not a $4000 fetish anymore, but a tool, a device that you use to reach your higher goals
Irakly Shanidze
www.shanidze.com/en
Touch tiltable LCD, 4K video, improved low light performance......
TOUGH REQUEST !
RABphotoX New Member • Posts: 15
Re: Q with zoom? - especially for miro3
I had Sony Rx1 and now a Q. Yes like the Q more especially using the frame lines for 35mm and 50mm. They remind me of the M8 which would be a M10 if I could manually focus (bad hands). I believe 35mm image  is very good, the 50mm is OK for internet. If Leica could get a 42mm sensor, then all three FOVs would be great.
If you had a Q zoom, you would no longer have the frame lines, the camera weight would increase quite bit, the autofocus would slow down, and f1.7 turns into 2.8 or more. Also, the button for switching frame lines turns into a much slower twist of the lens. I believe that Leica should stay with the Q design basically as is, but add more Pixels and a drop down LCD. Then, add a Q plus with  more mega Pixels,  75mm lens with frame lines for 90mm and 135mm.
I love this small camera, but also need the Q plus for closeup street photography. I tried a T, but couldn't hold it or use the add-on viewfinder. I just bought an Olympus Pen F which fits my hands perfectly and uses the m.Zuiko 75mm that's on it and a Panasonic Leica 42.5mm f1.2 in the future. Pen F is nice, but would rather have a Q plus. Don't ruin the Q design.
brick33308
FYI, I'm not the poster above who wants a zoom lens, and frankly I have no use for them even on my Sony A7Rii. But I would however love an articulating LCD.
bosjohn21
bosjohn21 Forum Pro • Posts: 23,117
it is almost every day I hear something about the q with the 28 and most often lamenting its not the thirty five. I even saw one rather far fetch idea that leica made it 28 to limit sales.
for me the 28 is a stroke of genius giving the full frame 24mpx sensor you can get very excellent results cropping to even fifty mms but thirtyfive mm is a piece of cake, and to paraphrase the late ceo of Seiko watch with the twenty eight its very easy to shoot thirty five mm and you will not even have to change lenses oh wait I forgot you cannot but you would not need to anyway. I tested this idea out on my M240 and put a cosina 28 on it and blasted a way for a couple months or more before going to a fifty just for a different lens. the idea works spectacularly well for the market the camera is aimed at which is the well heeled traveler.  No nedd for interchangeable lenses and if you had a thirty five you could never uncrop to twenty eight. and all that in a camera thats comfortable to carry around all day
they are working on a new model and I sure do hope the do not change from the twenty eight
John aka bosjohn21
They are working on at least two new models: one with a fixed focal length, and another with a 25-50/2.8 zoom.
tinternaut
tinternaut Veteran Member • Posts: 8,141
Re: Had it been 35mm.....
I predict an equal number of punters would have lamented it not being 28.
 tinternaut's gear list:tinternaut's gear list
Olympus E-510 Panasonic Lumix DMC-L1 Olympus E-30 Olympus PEN E-PL1 Olympus PEN E-PM2 +13 more
Edward48
Edward48 Forum Pro • Posts: 10,562
I agree 100% John.
Some reviewers see the 35 & 50 crop framelines as a gimmick, but maybe they take themselves a bit too seriously. Us ordinary folk make mistakes and errors of judgement from time to time.
For instance:
You’re out on a photo walk with your favourite 35mm lens attached but nothing much is happening out there, it's cold, and your thoughts are beginning to wander away from the job in hand. Then, suddenly something is happening, right in front of you, and you have about three seconds to respond. Camera up, shoot, all over…done and gone forever. Very pleased with yourself, you trot off to the nearest cafe for a coffee and a review of your mornings work. So there you are chimping through your images, and up next is your best shot for a couple of months or so…rats you’ve cut the feet off! Bug*er! Time to go home
But shooting RAW with the Q set to 35mm crop you can enjoy your coffee knowing that when you get home you can move the crop to include the missing feet, make a larger or different crop or use the whole 28mm frame. Plenty of choices. Certainly doesn’t seem like a gimmick to me.
Mike
 Edward48's gear list:Edward48's gear list
Fujifilm X30 Fujifilm X70 Panasonic Lumix DMC-GX85 Panasonic GX850 Leica CL +1 more
bosjohn21
if the zoom is compact enough it may be interesting but I hate giving up the f1.7 lens
John aka bosjohn21
bosjohn21
yup,
John aka bosjohn21
