Three Lens Prime Travel Set, does this work?
Started Feb 27, 2017 | Questions
DP13Photo Veteran Member • Posts: 6,307
Re: Three Lens Prime Travel Set, does this work?
FirewaterSun wrote:
I have the 12, 17, 25 and 45 Olympus primes - I'm trying to pare down lenses to reach a three lens set for travel.
I love the 25 and 45 for street shooting and portraits, but the 17 and 12 don't gel with me. The 17 seems not wide enough to capture environments, especially in tighter areas, and is kinda a half-hearted 25 - if I only had one lens, this would probably be it, but with the 25 I feel it's not really useful as it's so close.
The 12 I find super wide and can only really see a few possible uses for it. Additionally, I also own the 12-32, so if I REALLY need 12 I can also use that.
Do you think it would be quite silly to replace the 12 and 17 with a Panasonic 15 f1.7? I feel like the extra 2mm width (which is not insignificant) brings a lens that can be used as a wider photojourno-esque lens, while not being as difficult to compose with as the 12.
I have decided I'm definitely looking for either a Panasonic/Olympus prime, and ideally f2 or brighter.
TL:DR; is a 15, 25, 45 prime set feasible for travel, or am I missing out on a wider-angle lens?
I sort of think you answered your own question.... you want three and the 12 only has a few possible uses.... for you!
The standard three might be 35mm, 50mm, and 85mm for wide, normal, and portrait uses. Some prefer 28mm, 40mm, and 90mm. It's personal preference for your shooting style.
Dave
 DP13Photo's gear list:DP13Photo's gear list
Sony a7 IV Sony a7C Sony a7 III Sony FE 24mm F1.4 GM Sony FE 50mm F2.5 G +15 more
Paulmorgan Veteran Member • Posts: 9,499
FirewaterSun wrote:
Paulmorgan wrote:
FirewaterSun wrote:
So I'm not quite sure how replacing 2 lenses with a lens that is cheaper than 1 of them = GAS. I got the 12mm on a great deal and will earn money on the resale.
Because you already have a bunch of lenses your not happy with.
Gassy people do this.
14mm at f2.5 & 60mm f2.8 I wouldn't really say is better than 1.7/1.8 at night. Especially for street.
If you shooting at f4 to f5.6 at night why would a faster lens be better, remember you still need dof ?
On top of which 45mm to 60mm is a bit of a waste of buying a lens for the few extra steps forwards.
Additionally this is an all round travel set as well, and I do like a bit of bokeh sometimes
but thank you for your 2 cents. happy shooting!
Like I said. Got em at a deal. Don't like em. Love the other two lenses and won't change em for anything. I guess if that means GAS in your book instead of grinning and bearing it, sure.
Shooting at f4 at night? for walking people or snap facial expressions? You must live in really brightly lit areas, or always have the background panned out.
The light is not to great where I am, if its dark and I need and I need dof it simpler enough upping the ISO a little, I mean there is barely any difference these days between ISO 200 and ISO 400 concerning noise, these newer sensors are pretty good and it can save you a hole heap of money.
Take the 75mm and 60mm, the difference between the two is one stop but the 75mm cost 5 times as much as the 60mm, the 75mm has a tiny advantage at a high price.
All I`m saying is that you could save yourself a whole heap of money and at no cost in quality.
In addition to which, it's an m43 sensor. At a 15mm focal length, 1.7 gives enough dof if you get the subject even close to in focus.
For street portraits or street candid`s shallow dof and fast lenses are fine but not so good when your telling a story and including other parts of a scene (Very often there is not enough dof with the lens wide open)
I go out shooting at night with the 45 wide open and like the results. The high-end primes are amazing at autofocus in low light.
Either way it seems our philosophies are vastly differing, which is fine. You'll forgive me if I say that I probably wouldn't shoot the same way and therefore wouldn't buy the same lenses - no offence intended!
OP FirewaterSun New Member • Posts: 15
At ISO 400 you are either taking shots at extremely slow shutter speeds - thus completely negating any moving subjects - or as I suspected, live in Las Vegas or somewhere with spotlights at night. I have a handheld image taken a few days ago that is f1.8, 1/8s, ISO 6400 (it was even underexposed!), and would love to see that at ISO 400.
Not sure why we're on the 75mm vs 60mm when the original post was about replacing a 12 and 17 with a 15.
I will give you that a 500% price difference of the 60 and 75 don't really make sense for 30mm and a stop extra.
The 14 is also only about 100 more in exchange for a full stop and negligible focal length and size differences. For a lens that will last for years, I'd rather spend the extra, even if only for resale value in future if needed.
I admire your fervent commitment to ascetism, but if noone had any need for large apertures, I'd imagine all those lenses were design follies. The 12-32 stopped down is a pretty nice lens as well, that doesn't mean we all run around with kit lenses.
As I said, what you value seems to be different to what I value in a lens. Luckily, the glut of choice in M43 means neither of us has to compromise.
Thank you for the refresher course on depth of field and how it changes an image.
Not sure how much experience you have with the f1.8 primes, and I don't want to assume, but if you haven't, do shoot with them a little, and note how much dof one can obtain wide open in the 12-45 range.
Felice62 Veteran Member • Posts: 5,079
I would definitely add a longer focal prime (75, perhaps?).
At the same time I wouldn't certainly remove 12 from my bag.
Likewise I will keep 17 and get probably rid of 25 (provided I must choose to scrap one).
People who think they know everything are a great annoyance to those of us who do.
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Tough TG-3 Olympus Stylus Tough TG-850 iHS Panasonic ZS100 Olympus E-M5 II +36 more
EnriqueFreire
EnriqueFreire Forum Member • Posts: 80
This is what I did. I am really happy with that decision. Panny 15mm is a wonderful lens with a wonderful focal
_________________________________
Enrique Freire
http://www.flickr.com/enriquefreire
http://www.enriquefreire.com
 EnriqueFreire's gear list:EnriqueFreire's gear list
Sony RX100 III Olympus OM-D E-M10 II Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Lumix G X Vario 35-100mm F2.8 OIS +9 more
Awesome, thank you! I am glad it worked out for you, and I hope it will for me too - It's strange how many people insist that their focal length preference is correct and nothing else will work, it really made me doubt my idea for awhile...
Definitely thinking of a longer prime, maybe 60 or 75, but I do have the 45-100 for now.
The thing with the 12 is I'm finding it hard to justify the cost/use scenario especially when I have a 12-32 anyway! What about the 12 do you find so indispensable, may I ask?
jeffharris
jeffharris Forum Pro • Posts: 11,409
That's a good objective. I was carrying way too many lenses and gradually whittled it down to 4 lenses; 7-14mm, 17.5mm, 42.5mm and 75mm f2.5 (primes are Voigtländers).
I think that make perfect sense, if the 12mm and 17mm don't do it for you.
Before I got the17,5mm, I was trying to make peace with a 12mm (too wide for my eye) and 25mm (too narrow). The 17.5mm was a perfect fit for me. I stopped carrying the 12mm and 25mm entirely.
To add another twist 😱, for travel I'll often use a 12-40mm and leave the 42.5mm behind.
For me the 7-14mm f4 solves that problem. We'll see how all the different upcoming ultra-wide primes change that. Laowa 7.5mm f2 and SLR Magic 8mm f4. There's a recent thread with a number of gorgeous shots from the Kowa 8.5mm f2.8, that add to the suspense. 😄
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Voigtlander Nokton 42.5mm F0.95 Panasonic Lumix DMC-GX8 +26 more
I like the 12/2 so much I may get the 12/1.4. For me it is indispensable for restaurant, tavern type shooting or for live bands indoors. Here are a few that I would have to use flash with the kit lens and that doesn't give results that I like or is not practical.
Tiramisu
My favorite cowboy tavern
Dave
First off, I'd like to declare I do not have this prime lens. I have the 12-40 Pro and the 12-50 which in good light is a quite under estimated zoom.
Secondly, I am more of a wide-angle traveller as I often find myself  visiting small churches, museums and the likes which impose use of  wa lenses. with my other system (Sony ILCs) I often use 20mm or less for this scope. The widest I can go, for now with m43 is my 12-40 (or 12-50 for that sake).
The 2/12 is well reputed AFAIK and the extra light you get, in addition to its reduced weight over the fairly big 12-40, make up for the least flexibility when compared to the zoom.
Your mileage may (of course) vary
Felice
FirewaterSun wrote:
Definitely going to pick up the Laowa if it's not crazy expensive - my issue with the 17 and 12 is they kinda feel not extreme enough, either too wide/long for every shot I'm trying to do (and yes, I do zoom with my feet, I'm just limited in some streets )
with a 7.5mm for ultrawide, 15mm for moderate wide and 25 for normal 45 for short tele (although maybe I will seap that for a 60/75) that gives me a 1.8ish multiplier between lenses, which does seem, I dunno...kinda neat?
If you're not budget limited why not carrying one of the holy trinity zoom members in your bag? Of course I am talking about the 7-14 Pro
Ulric Veteran Member • Posts: 4,559
Definitely neat.
 Ulric's gear list:Ulric's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GM1 Olympus PEN-F Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +13 more
No not great lighting were I am, its just a small town, at ISO 400 at f2.8 or f4 shutters speeds drop to somewhere around 1/40s, sometimes a little less sometimes a little more but I do like my darks dark and my lights light.
Some just assume that all histograms need pushing to the right (not saying you do this)
Hehe that is low, blast the street with flash.
Someone else was on about the 75 here.
Plenty but I tend to use full frame when I want really wide apertures, m4/3 makes you pay through the nose.
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
you have the perfect tester in that 12-32 lens
that should be your best guide.
I have the pancake 14 mm and that does well on the wide end for me, so the 15 may work for you.
the main reason to have the 12mm wide is to give you the biggest width you can get.
my primes are 14,17,25,42,60 and a cheap 50mm manual.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-3 Panasonic G85 Pentax K-7 Olympus E-M1 II +3 more
erichK Veteran Member • Posts: 6,661
SpinOne wrote:
You could use just the 25mm if you wanted.
Anyway, seems to me like 12-32, 25mm, 45mm is the best option here.
The difference between 15mm and 17mm is pretty small. 65º vs 72º.... not huge.
The 12mm prime is a better lens, but if you're not going to use it often, and you find it too wide, then you might as well use the zoom.
Either way, I've always found that having a 12mm prime or zoom that starts at 12mmm (or the old 11-22) along to be absolutely essential.  Mainly for interiors, but also for narrow streets and jammed venues, and also the occasional land/sky scape.
The 75mm f1.8, OTOH is a great lens, but also a fairly big one with a but too much tele/ too narrow a field of view,  Find the little 45 much more useful.
erichK
saskatoon, canada
Photography is a small voice, at best, but sometimes one photograph, or a group of them, can lure our sense of awareness.
- W. Eugene Smith, Dec 30, 1918 to Oct 15, 1978.
http://erichk.zenfolio.com/
http://www.fototime.com/inv/7F3D846BCD301F3
underwater photos:
http://www.scubaboard.com/gallery/showgallery.php/cat/500/ppuser/5567
 erichK's gear list:erichK's gear list
Olympus C-5050 Zoom Olympus E-1 Olympus E-5 Olympus E-620 Olympus PEN E-PL5 +26 more
adrian1988
adrian1988 Regular Member • Posts: 128
The laowa one seems to be around $500 price mark according to their latest disclosure in Fb.
http://www.facebook.com/venuslaowa/
 adrian1988's gear list:adrian1988's gear list
Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Voigtlander 35mm F1.4 Nokton
That's four to five stops brighter than this shot.
Edit: exif was apparently stripped, but that's 1/50 s, f/1.4, iso 1600. Pushed half a stop in post.
Oh nice, thank you for the heads up - damn, that will mean 500 euros/pounds in Europe, and that's pretty steep for that lens - you're into 7-14 territory there...
Have indeed been using the 12-32 as a test, and I do like what I'm seeing - I guess I was just asking more for people with experience in tighter areas etc. Although I will still have my 12-32 for those areas, and/or a 7.5mm.
C Sean Veteran Member • Posts: 3,423
Really anyone visiting foreign cities on holiday should only be taking one lens which either is a 28mm or a 35mm. You don't need another lens unless you're planning to shoot a specific landmark with a different focal length or visiting museums.
I use the 15mm 1.7 because it focal length almost match the 14mm 2.5 and almost a stop faster. This gives me not only a wide focal length but allows me to shoot landmarks in low light as well. So the 15mm 1.7 in my opinion, is a good travel lens for any Micro Four Thirder.
In the past I used to travel with the 14mm 2.5 and the 20mm. One was used for wide shots and the other was for low light. The great thing about 15mm it captures both lenses strength except for shooting friends indoors. However, you can take the 20mm with you or the 25mm.
Here is my current travel set.
15mm 1.7 - Low light and wide shots which basically has me covered.
25mm 1.4 - For people shots which I'm not going to use often.
45-150mm - Compact telephoto zoom
