M5 + Linux
Started Feb 23, 2017 | Discussions
xsnrg
xsnrg Forum Member • Posts: 67
M5 + Linux
Hi friends, if you run Linux instead of MacOS or Windows, keep reading.
Historically, I have had a conundrum to deal with. I am a Linux user, and have been for 20+ years. I am also very fond of Canon equipment. This has been a good bit painful, as you could imagine. Canon really has no direct support for anything Linux.
Tonight I set out to connect to my M5 with my Fedora laptop. My goal, to use wifi to download all pictures to the laptop. I am here to report success.
There is an application that was written to work with DSLRs from Canon, Nikon, and Sony, and it can be found here: airnef . Yes, it also works with Mac and Windows. It does not work out of the box, or at least I was not able to get it to work. I did a bit more digging and found a change that was needed to remove a probe command. The change is to v1.1 of airnefcmd.py. Comment out the line so that it looks like this:
# mtpwifi.sendProbeRequest(g.socketEvents)
Proper credit found in this thread: http://testcams.com/blog/forums/topic/canon-eos-m5-connection-refused/
Once that is changed, here is the commandline I use:
./airnefcmd.py --ipaddress <M5 IP> --outputdir ~/Pictures/
It downloads full size images on my wifi at about 4M/sec.  There are many options to download different sizes, just certain types, certain date ranges, etc.
No more removing from scope, tripod, SDcard wear, etc.  Enjoy!
 xsnrg's gear list:xsnrg's gear list
Canon EOS M5 Canon EF-M 22mm f/2 STM Canon EF-M 28mm F3.5 Macro IS STM Canon 70-300 F4-5.6 IS II Canon EF-M 18-150mm F3.5-6.3 IS STM +1 more
Nikon 1 V1
Alan Sh Senior Member • Posts: 2,374
Re: M5 + Linux
Thanks - very useful. Now, I just need it to work with the Windows image. I dnon't suupose you have the tools to fix that, do you?
Alan
 Alan Sh's gear list:Alan Sh's gear list
Canon EOS 6D Canon EOS M5 Canon EF-M 55-200mm f/4.5-6.3 IS STM Panasonic Lumix DMC-ZS40 (TZ60) Canon EOS M100 +14 more
xsnrg
OP xsnrg Forum Member • Posts: 67
Re: M5 + Linux
The same should apply.  Download the source, edit the line, and install python 2.7 for windows to run it
Re: M5 + Linux
I've edited the line, installed Python 2.7 and tried to install Py2exe - which fails because it is asking for Python 2.5.
I am grappling in the dark here.
Alan
xsnrg
Re: M5 + Linux
you could try python 2.5 then, but if you downloaded the source, there won't be an exe.  You would run python.exe with the airnefcmd.py at a command prompt.  I dont have a windows box here, but imagine it would look something like:
c:> python airnefcmd.py --ipaddress <ip>
On the camera, you need to start the connection with the connect to mobile device option
Re: M5 + Linux
I finally got python installed. V2.5 wouldn't run the app (got syntax errors). 2.7 runs it but I get
Camera's date/time set to 02/23/17 01:17:24 PM
Camera reports no user-selected images/movies to transfer or not-supported
There are images to transfer - I selected "All images" when asked.
So, maybe this isn't for me.
Alan
xsnrg
Re: M5 + Linux
You are actually really close then.  When I got to that part, I had to add a flag for it to ignore the dates on the files.  Maybe it has to do that the first time.  If you run it with just -h you can see all the options.  One of them is for it to ignore the dates.  Give that a go.
Re: M5 + Linux
Wow - got it. I used "Select on Computer" rather than "Select in Camera" and it started downloading (1595 files - so I did abort it).
Thanks for your help on this
Alan
xsnrg
Re: M5 + Linux
Good work, so now we have a way to download from Linux and Windows directly.  Not sure why Canon didn't give us software for that in the first place.
EmBeeWee New Member • Posts: 3
Re: M5 + Linux
I can't get it connected to my M6, I'm on windows 10 with latest python (3.7.4) and I put the camera in 'connect to smartphone' mode. I can ping the camera at 192.168.0.1. Any ideas?
73Instamatic
73Instamatic Regular Member • Posts: 408
Re: M5 + Linux
It should get easier in the future. Canon is switching over to a different API (CCAPI) over WiFi. The RP is one of the first to support it. The just announced M6 II should as well.
The protocol is a REST-ful API run over HTTP, which is 100% OS agnostic.
Tutorial Introduction to Canon’s Camera Control API
You could even take some of the samples written in C# and run them using Mono on Linux.
