"Check status of a lens" error—how common is this?
Started Feb 21, 2017 | Discussions
mmmartin Junior Member • Posts: 28
I just found out that my kit lens (Olympus 14-42 II R) is pretty much dead. A "check status of a lens" error occurs whenever I zoom past around 25mm. Hums plenty, too.
A good long Googling reveals that it mostly happens to the kit lens, but the 9-18 isn't safe from it either. I could either DIY it (haha nope) or send it for repairs, which would cost almost as much as buying a new lens.
How common is this issue? Granted, my copy's ~4 years old now, but I barely used it (I got the Pany 20mm, and has almost never left the camera since). You could dismiss it as usual cheap kit lens quality , but it's still pretty disappointing. Especially since image quality was quite okay.
erichK Veteran Member • Posts: 6,661
Re: "Check status of a lens" error—how common is this?
I had the same happen with the 12-50 that I initially bought with my OM5.  Luckily I was able to replace it with a new one, at a very moderate price, from Japan.  (I need this lens because its power-zoom function is very handy for video.
The message apparently indicates an electronic short or broken connection in the lens.  Not usually worth trying to fix, especially on cheaper - and usually less servicable- lenses.
erichK
saskatoon, canada
Photography is a small voice, at best, but sometimes one photograph, or a group of them, can lure our sense of awareness.
- W. Eugene Smith, Dec 30, 1918 to Oct 15, 1978.
http://erichk.zenfolio.com/
http://www.fototime.com/inv/7F3D846BCD301F3
underwater photos:
http://www.scubaboard.com/gallery/showgallery.php/cat/500/ppuser/5567
 erichK's gear list:erichK's gear list
Olympus C-5050 Zoom Olympus E-1 Olympus E-620 Olympus E-5 Olympus PEN E-PL5 +26 more
apathyman Veteran Member • Posts: 4,151
I had this happen with an early version 40-150 (not 'Pro') lens that I bought second hand. It worked OK when I got it but the dreaded message appeared after a slight drop of maybe 300mm onto a carpeted floor.
I bought a new one.
It would be nice if messages like this were worded in such a way that they make sense to a user.  What does 'Check the status of a lens' mean anyway?  Maybe a better message would be 'Your lens is cactus - take it to a repairer'.
Cheers
Brian
OP mmmartin Junior Member • Posts: 28
Good thing you were able to replace it. Looks like I'm sticking with primes from now on.
JosephScha Veteran Member • Posts: 7,249
I realize the OMD EMI is smaller and cuter than a roughly equivalent Panasonic camera (G80 ). But I've never heard of such a thing happening on with Panasonic (or Sigma, or Voigtlander) lenses on a Panasonic body.  Does it take more than this ...  ?
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
I bought a new one.
Ouch. What really gets me is that the glass is fine, it's just the electronics.
Yeesh, I know, I had no idea what it meant when I first saw it. Then again, the way Olympus designs their menus, you can't expect much from their error messages.
shinndigg Veteran Member • Posts: 4,690
Last year, I had the same thing happen to my then 5 year old 14-42 RII lens. I bought another one used. If the same thing happens to this one, I'll likely purchase a different lens in the same range.
I should qualify that I bounced it on two different occasions.
shinndigg
www.pbase.com/shinndigg
 shinndigg's gear list:shinndigg's gear list
Panasonic Lumix DMC-FZ35 Olympus E-510 Olympus PEN E-PL1 Olympus E-M1 Olympus OM-D E-M10 +9 more
hindesite Veteran Member • Posts: 4,893
Quite common
I have a friend who had this happen on their original 14-42 m.Zuiko (you know, the really ugly floppy one With the rotating front element).
Other reports of the same with the later 14-42, as well as the 9-18 m.Zuikos have appeared in this forum. Apparently the problem is caused by the failure of a flexible ribbon cable.
I'd be upset if my 9-18 developed this problem, but if it happened on the 14-42 I'd just go and buy another 14-42 Panasonic, they are cheap as chips on ebay.
NJYang New Member • Posts: 1
Yes, it's common. Happened to my EPL3 with 14-42 lens as well
Hi, I just joined dpreview because I have the same problem on my EPL 3 and this 14-42 ll lens. I startled having this problem 2 days ago. I first saw this "please check lens status" message on my friend EP3 with the same lens. I wasn't sure about it, then after a few weeks this problem came on my EPL3 as well. It pops up 19 out of 20 times I zoomed pass 30mm. It's not that the lens is broken or anything, the autofocus still works and i still can snap a picture if that message doesn't pops up. I few method I found to get rid of the message, is to either off then on back the camera below 30mm or press the shutter release button below 30mm. I don't know whether should I get a replacement lens or get a new camera instead, but now if I want to take pictures above 30mm zoom, I'll have to use manual focus so that the message won't pop up.
Re: Yes, it's common. Happened to my EPL3 with 14-42 lens as well
It's a shame about this lens. Mine actually got worse and started showing the error at about 20mm. If you get a new camera, you do new get a new kit lens for $50 above the body-only price…
The Jacal
The Jacal Senior Member • Posts: 1,273
Re: Quite common
A couple of years ago I sold my seldom used EPL2 with the 14-42II to a colleague, shortly after she had this lens problem, luckily I had another to give her. Then, a few weeks later, I was in Cambodia, around the temples at Angkor with my EM10 with my wonderful 9-18 attached.....then the same thing happened to me. Upset isn't the way I felt, it was a bit stronger! Now it's a 9-12. If I stray into 13mm territory, I have to switch the camera off, press the lens release button, and twist the lens.
EDIT: Also, my 40-150 (original) just stopped working, no 'check status of a lens' message or owt. Luckily it was free with my EPL1. Last year though I found an EPM1 at a camera fair with a battery and a 40-150 for 40 Euros, which was nice.
 The Jacal's gear list:The Jacal's gear list
Olympus SH-50 Olympus PEN E-P1 Olympus PEN E-P2 Olympus PEN E-PL1 Panasonic Lumix DMC-G5 +14 more
The Jacal
This happened to my 9-18mm. I spoke to Olympus about it and was told categorically that it wasn't a short or a broken connection, the guy said that 'something has probably broken inside' and that it would be very expensive to replace, but they could give me 'some' discount on a new one...... They hadn't taken it apart, and my lens was out of warranty.
My BS detector was working quite well I think.
The Jacal
This happened to me too, sucks, yes?  The thing is, I've been lusting after the Oly 17mm f1.8, but I'm concerned this will happen again....
I believe this only happens to the zooms. More incentive to stick with primes, I guess…
thubten New Member • Posts: 18
me too.14-40. never dropped barely used.it is not so cheap as to be disposable like this.not happy
The Jacal
Sure, but the focus clutch thing, while it works great, seems like the possibly weak link.
Nulla incognatio New Member • Posts: 1
This is my first post, please be patient if i state the obvious: same issue with a lens on a backup camera i just acquired. What i want to know is, has the specific issue been identified? On one site, a stripped down set of images shows what appears to be a lever acactuated linear potentiometer. Am i right? If so, the fault sounds consistent with a wear fault, whether the contact arm or resistance, one could not say.
Anyone out there in aperture land have an answer? The corrollary would be a non dealer fix?
So, Now, a second 14-42IIR lens goes bad in just over a year... Sucks, Man! Options?
shinndigg
PWsykes3 New Member • Posts: 1
Same problem on 14-42 Obviously a design fault. Not been used a lot. Not too good for the Olympus reputation. Would love a diy video. Anybody game to give it a go?
Jim Vincent Veteran Member • Posts: 3,034
Re: "Check status of a lens" I had it on 12-40Pro
Last summer my then 4+ year old 12-40Pro developed this issue.  Worked fine at the short end but when zoomed beyond 28mm it would give the "Check status of lens" error and not work.  Sent it in to Olympus for repair.  They turned it around quickly and it's worked fine ever since - but - I got it back less than a week before a 3 week trip to Italy - was nervous about trusting it so picked up a 12-100 Pro which worked great for the trip and has been a wonderful lens, so, the 12-40 doesn't get near as much use anymore.
 Jim Vincent's gear list:Jim Vincent's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 7-14mm F2.8 Pro Olympus 12-100mm F4.0 Olympus 100-400mm F5.0-6.3 IS
