Button customization for B+W
Started Feb 21, 2017 | Discussions
barbakane Regular Member • Posts: 110
So I've had my K-3ii for a couple of weeks. Have the DA HD 16-85 ED DC WR and the 55-300 ED PLM WR lenses...the Tamrac 3444 to carry it all in...seems I'm good to go.
Heading to Colorado for a music/ski festival soon, and I want to try my hand at B+W while in the mountains.
Is there a way to customize one of the user settings, or perhaps a button, so I can switch to B+W/monochrome quickly?  I don't want to go thru the numerous menus to change it on the fly.
Being of the "old school" age bracket, I can pretty much visualize how something will look in B+W. I know I can convert later, but I don't want to do that. The less processing the better.
Anyone have a setting for that, or any real world experience with this? I'd appreciate the help, and others may benefit as well.
Thanks in advance.
Pentax 16-85mm F3.5-5.6 WR Pentax 55-300mm F4.5-6.3 ED PLM WR RE
SoCalWill
SoCalWill Veteran Member • Posts: 6,299
Re: Button customization for B+W
You should be able to assign a U mode with the Monochrome custom image setting.
Be aware that doing your own B&W in post allows you to make specific colors darker/brighter so that you can dial in how you want the finished product to look, giving the task to the camera just means you get what you get.
Digital Camera and Adobe Photoshop user since 1999.
Adobe Lightroom is my adult coloring book.
 SoCalWill's gear list:SoCalWill's gear list
Sony RX100 III Nikon D810 Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 50mm F1.4 DG HSM | A Apple iPhone XS Max
James O'Neill Veteran Member • Posts: 6,117
I shoot raw, but I think in B&W most of the time.
I don't use the user modes on the K5 or K1 - I just toggle it mono on or off via the 4 way controller. Depending on my mood I'll have it one click to cool tone, or one click to warm tone, and typically have one of the milder filters (e.g. Yellow - Red is too strong).
Because I have the DNG codec on Windows I can copy the preview out to a JPEG file if I want the "straight from the camera" image
When  I load the DNG into lightroom, it disregards the preview setting and I can blend colours , set contrast / levels and curves as I want (and obviously process the image as colour! ) , I've created presets  to mimic the in-camera settings. I can adjust from there.
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-5 IIs Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 18-250mm F3.5-6.3 Pentax smc FA 43mm F1.9 Limited +3 more
Paul_R_H Senior Member • Posts: 1,166
Hi
Set up the camera exactly as you want it - B&W, and the settings for the B&W jpeg including contrast and filtering and auto DR. Also set your preferred Settings for shake reduction, exposure program, ISO range and so on. Then save all as a user setting (U1 or U2 or U3). You can label it so you can find it easily. Then just swing the left-hand-top dial around to the U1, U2 or U3 when you want to shoot B&W.
Personally I'd make it save a RAW file as well as the B&W jpeg, so if I wanted a colour image or a different style of B&W conversion I could do it with post-processing.
Paul
OP barbakane Regular Member • Posts: 110
Thanks for the replies. I VERY new to this system, with LOTS to learn. That's why I'm here, asking the awesome knowledge base.
