Able to see video on camera but file is not on SD card
Started Feb 20, 2017 | Discussions
edurbrow
edurbrow Junior Member • Posts: 32
Yesterday, I recorded a concert and I can see the movies on the LCD screen of my Panasonic Lumix DMC-G7. However, when I put the SD card into the SD slot on my MacBook Pro, they don't show up and the folder size is zero. I did unthinkingly upload some RAW files and then erase them from the card. I can still see the videos though. 14 GB are used on the card but nowhere to be found in the Finder. I looked for something like show hidden files but I couldn't find any command like that for a folder. Someone with a similar problem, but stills, wrote that the files were in the clipboard on the camera. I don't know anything about a clipboard on the G7 and 14GB sounds huge. Unfortunately, it takes a proprietary USB cable from the camera, which I didn't bring with me on the is sojourn to CA so I cannot immediately try from the camera.
So the question is how can I get my videos into my computer if they don't show up on the SD card?
 edurbrow's gear list:edurbrow's gear list
Panasonic G85 +1 more
Axroad New Member • Posts: 21
Re: Able to see video on camera but file is not on SD card
Hi Ed,
I can't offer you any help in getting the files out of the camera but if they are on the clipboard & you continue to use the camera, you could overwrite & lose them.
14gb is a monster of a clipboard!
tt321
tt321 Forum Pro • Posts: 13,854
Possible solution
Insert card back into the Mac, then look in the trashbin.
Whatever you do, don't empty the trashbin while the card is in the Mac. Nor should you delete the video and any photos in the camera.
Recover files as per the normal procedure.
FaFik
FaFik Regular Member • Posts: 147
6
Look in PRIVATE/AVCHD/BDMV/STREAM directory. Not in DCIM, where photos live.
 FaFik's gear list:FaFik's gear list
Panasonic Lumix DMC-G3 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital 45mm F1.8 +5 more
alcelc
alcelc Forum Pro • Posts: 19,006
AVCHD or MP4?
Agreed.
To OP: if you shot in MP4, it should be stored under DCIM/XXX and has a name of PXXXXXX.MP4 in the sequence of other photos.
If you shot in AVCHD, it should be stored under FaFik suggested and has a file name of XXXXX.MTS.
Albert
john isaacs Veteran Member • Posts: 8,444
Did you try connecting to the camera over wifi?
edurbrow
OP edurbrow Junior Member • Posts: 32
Re: Possible solution
When I do what you suggest, what I see in the trash are heaps of RW2 files, none of which are larger than 14.5 MB, but no mp4 or AVHD files.
edurbrow
OMG, Thank You!
In Private, there was an AVHD file that was 12.8 GB. Inside Premiere Pro, I could import MTS files which were buried a few folders deep. So the footage is there. No audio, but I recorded audio with two other devices, so I'm okay there. I certainly don't know how they ended up there, as I always record MP4. Phew!
Thanks so much.
Ed Durbrow
Saitama, Japan
http://www.youtube.com/user/edurbrow?feature=watch
https://soundcloud.com/ed-durbrow
http://www9.plala.or.jp/edurbrow/
3dwag
3dwag Veteran Member • Posts: 4,674
Have you tried looking in other folders, as Albert summarized at the bottom of his post here?: https://www.dpreview.com/forums/post/59156223
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +19 more
edurbrow
Re: AVCHD or MP4?
Agreed.
My friend was operating the camera, so maybe he changed it.
I only see DCIM, MISC and PRIVATE at the top level of the card. Nothing at all inside MISC. Inside PRIVATE there is AVCHD and PANA_GRP. Inside PANA_GRP there is PAVC which only contains LUMIX, which appears to be empty. This is all alphabet soup to me.
Ed Durbrow
Saitama, Japan
edurbrow
That is another great idea I never thought of. I have never experimented with wifi. It is probably easy if you know how.
Ed Durbrow
Saitama, Japan
edurbrow
Yes. I got the AVCHD file. Much relieved.
dazecutr New Member • Posts: 3
I have the same problem only i use a PC.  Nothing in the trash bin
alcelc
Why you are looking for the Trash Bin (the Recycle Bin actually, on the card?)?
Have your tried to use a card reader, and launch Windows Explorer (the native file manager if Windows) to go through your SD card?
Or do you have FastStone etc free image viewer software installed on your PC. Again these software can also navigate through the SD card to look for image files (RAW, Jpg, video files) etc.
Look for the DCIM folder, everything created by G7 will be stored inside sub folders inside it.
Albert
** Please feel free to download the original image I posted here and edit it as you like **
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Panasonic and Sony have the habit of keeping video files buried deep in the PRIVATE folder and not in the DCIM folder.
It's all to do with making cards look like DVDs so their TVs and other gadgets can use them.
alcelc
MTS only, not MP4? 🙂
Albert
Siewwah Regular Member • Posts: 155
Try this:
Where does the camera store the video files on the SD card?
Motion Jpeg = /DCIM/100_PANA/
The number in front of PANA may increase; this is the same location as the still images. The file extension of the videos is .MOV
MOV files
AVCHD = /PRIVATE/AVCHD/BDMV/STREAM/
AVCHD Files
The file extension of the video files is .MTS
hope you can find them...
SW
Henry Falkner
Henry Falkner Forum Pro • Posts: 15,901
Usually, this means that your OS does not have the CODEC for the particular video type that you are shooting.
The camera installation on your computer (for your computer to talk to the camera, and vice versa) should have done this for you.
Henry
Henry Falkner - E-M10 Mark II, SH-1, SH-50, SP-570UZ
http://www.pbase.com/hfalkner
 Henry Falkner's gear list:Henry Falkner's gear list
Olympus SP-570 UZ Olympus SH-50 Olympus Stylus SH-1 Olympus OM-D E-M10 II Olympus OM-D E-M10 IV +1 more
Guy Parsons
Re: MTS only, not MP4? 🙂
Basically on my Sony compact, if I go looking for the video files I get lost, so....
I always use FastStone Viewer for downloads from cards and if I point to the DCIM folder I get stills and no video, if I point it to the root of the card then it manages to find all stills plus videos, wherever Sony has hidden the darn things. No problems.
When I look at a card from Sony I see this mess.....
The videos are in there somewhere. Lotsa luck!
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
There are two hurdles.
First you have to know to look in the correct folder, per Guy's diagram above, also this post
Second, I have seen that Windows Exporer in Windows 10 doesn't show media files for which you have no codec.
Cheers
Eric
(Any image that I post in a DPR forum may be editted and posted in a DPR forum)
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
