Your choice of Fuji's Trinity prime kit ?
Started Feb 20, 2017 | Discussions
OwenJ Junior Member • Posts: 49
We all know that a lot of Fuji users move down from high end full frame DSLR kits for the reason of downsizing. No exception, I moved from a nikon D800E, and i'm a prime shooter mainly at 24mm, 35mm and 85mm. I used to own a 300mm f2.8 but I am not using it that often.
Considering IQ + weight,
Would you prefer:
-14mm f2.8 + 23mm f2 + 60mm macro
or
-16mm f1.4 + 23mm f2 + 56mm f1.2
I really need a 35mm equivalent focal length, so 23mm always has a spot in my kit. Considering the weight f2 is a much better choice for me personally.
The question comes down to the wide end, i would prefer a 24mm equivalent light lens, i.e., 16mm f2/f2.8. However, 16mm f1.4 is almost double the weight of 14mm and f1.4 isnt something i would need for a wide angle lens.
At the tele-end, again, 56mm is the ultimate portrait lens ( i wont consider 90mm due to its weight). However, 60mm seems to be a steal lens at half of its weight and price. I understand its slow focus and relatively slow aperture, but dual purpose lens is always a plus.
what do you guys think if u can only have 3 primes ?
 OwenJ's gear list:OwenJ's gear list
Nikon D800E Fujifilm X-Pro2 Nikon 85mm F1.8G Sigma 35mm F1.4 DG HSM Art Fujifilm XF 23mm F2 R WR +1 more
Rod McD Veteran Member • Posts: 8,589
Re: Your choice of Fuji's Trinity prime kit ?
5
Hi,
I came from APSC DSLRs.  I have a good number of the Fuji primes and they're all good.  I have trouble choosing between kits, but these days, as a landscape and  nature enthusiast, my 'trio' kit is (usually) either
  • the 14mm, 23/1.4 and 60mm, or
  • 16mm, 23/1.4 and 60mm.
I find the 23mm FL indispensible too.  I bought the 23/1.4 before the 23/2 became available.  Light weight and small size appeal to me, and so does sealing.  I don't use f1.4 at all.  However, I haven't been convinced to change over purely from an IQ perspective.  If  ever do buy a 23/2, the old one won't go until I've compared them side by side.  I'd be keeping the one with the best IQ.
I have both the 14mm & 16mm.  Too very fine lenses with no clear winner.  I actually prefer the 16mm for landscape because it doesn't compress the backgrounds and exaggerate the foregrounds quite as much.  And it's sealed.  OTOH, I sometimes prefer the 14mm, especially for architecture.  It's smaller and lighter.  It's better corrected,  takes in more interior space and can be used slightly more effectively for cropping to get parallel verticals.  It takes 58mm filters which more easily double on other lenses.  It's also more flare resistant.  I never actually decide to sell off either......
I find the 60mm a really useful, small, light and sharp lens.  It doubles nicely as a general short tele, portrait and close-focusing lens.  Yes it's AF is a bit slow in low light, and if it hunts,  it hunts a long way like the macro lens it is.  That and fiddly little 39mm filters aside, the more I use it, the more I like it.
I take a 55-200,  an adapted 90mm macro or an adapted 300mm as the fourth lens in my trio depending on what I'm doing.  And if I'm traveling overseas, I take the 18-55 only.
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
dv312
dv312 Veteran Member • Posts: 9,214
Would you prefer:
or
I'd go with 14mm 2.8, 23mm f2, 50mm f2
I 've already owned the 14mm , wider than the 16mm yet smaller; f2.8 does it for me
The 23mm f2 is a must lens , small, cheaper, and WR; I'm waiting for the silver one
Ditto with the 50mm silver; not quite long enough for most portraits but small and cheaper and WR
The alternatives are just too large and heavy
I may add the 35mm f2 to complete the f2 trinity ; however I can see it being used less often than the 23mm
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
blessingx
blessingx Contributing Member • Posts: 606
You didn't mention an importance of AF speed and accuracy. If it's not important choice A may be better with size/weight. If it is important go B.
Personally, my trilogy is 16/35f2/90.
 blessingx's gear list:blessingx's gear list
Sigma dp2 Quattro Sigma dp0 Quattro Leica SL (Typ 601) Fujifilm X-Pro2 Sigma sd Quattro H +15 more
(unknown member) Contributing Member • Posts: 578
If I was only allowed three primes and my budget was open it would be the, 14mm, 60mm and 90mm, of those three I own the 60mm. I cannot afford the rest, although I own the 18mm 27mm and the 60mm.
OP OwenJ Junior Member • Posts: 49
Would you prefer:
or
Thx for mentioning about 50mm f2. It would be a really interesting lens for me if it would have been a 56mm f2. I wont hesitate taking it.
Sadly, Im not really a fan of 75mm equv FL. I felt a bit awkward when I used nifty-fifty on my old apsc-dslrs. My preferred portrait lens range is between 85-135mm, the 10mm does make quite a difference. I dont know if there are people who agree.
Sfowler Regular Member • Posts: 138
Hi,
i'd choose the 16, 23 and 56 but don't ironically don't have any of those lenses. I had the 14 before the 16 was released and it is such a good lens I didn't feel the need to upgrade. 23 is covered by my x100t. I have the 60 but prefer the 90 for any portrait work as it is spectacular.
When I go out I usually stick to 14, 18-55 (or x100t) and 90 as they give me options in terms of focal length and speed.
cheers
Sam
 Sfowler's gear list:Sfowler's gear list
Fujifilm X-T1 Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +3 more
(unknown member) Forum Pro • Posts: 16,732
Mine is 14, 23 F1.4, 56 right now.
The F1.4 is that much more useful in low light, and I find the resolution spectacular.
the 56 provides nice isolation, even for objects that are not that close. Very nice for street.
If I was travelling light, then it would be 14, 23 F2, 60.
Reporter: "Mr Gandhi, what do you think of Western Civilisation?"
Mahatma Gandhi: "I think it would be a very good idea!"
j0sh
j0sh Regular Member • Posts: 450
Would you prefer:
or
I've got 14, 23 1.4, 60 and I think it's a very good kit for traveling, landscape and everything else 😊
My pictures and social media accounts: http://www.pixael.com/pictures
 j0sh's gear list:j0sh's gear list
Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +5 more
Shredcow Junior Member • Posts: 41
I'd go with something like... 18mmf2, 35mmf2 and the 90mmf2.
Or... if non-Fujis are okay, I'd prefer something like a Samyang 12mm, 18mmf2 and 35mmf2.
I really enjoy getting up close to the action and I do a lot of street photography.
Cheerio!
Daniel
 Shredcow's gear list:Shredcow's gear list
Fujifilm X-T5 Fujifilm 16-55mm F2.8R LM WR XF 90mm Fujifilm 50mm F2 R WR Fujifilm XF 50mm F1.0 R WR +2 more
Pixnat2
Pixnat2 Veteran Member • Posts: 5,767
Why only a Trinity?
7
My choice would be a "Quaternity" :
14mm f/2.8 + 23mm f/1.4 + 35mm f/1.4 + 56mm f/1.2
Why?
Because personally, I love both 35 and 50 mm equivalent, and I don't see why one should exclude the other
 Pixnat2's gear list:Pixnat2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Fujifilm X-T2 Nikon Z6
Simon Elwell Contributing Member • Posts: 560
Made that choice...
I went for 14mm 2.8; 23mm 1.4; 56mm 1.2
I also have a 35mm bought before the 23mm came out.
 Simon Elwell's gear list:Simon Elwell's gear list
Fujifilm X100S Fujifilm X-Pro1 Fujifilm X-Pro2 Fujifilm X-T4 Leica Macro-Elmar-M 90mm f/4 +8 more
yardcoyote Forum Pro • Posts: 15,754
I can tell you my trinity choice: 23mm f/2 (on X100T), 35mm f/1.4, 60mm f/2.4 (on X-T10). This saves me one potential lens change, and gives me a little variety in shooting experience. I think the small size/light weight and fun factor of the X100 series is well suited to the 35mm FOV, and often carry that camera alone for street and walk around.
In a hypothetical perfect world, I would have another camera body and never have to change lenses at all.
(Oh,  and no 14mm because I am not a landscape shooter and have close to zero interest in anything wider than 35mm equivalent. My personal trinity has always been 35-50-85 (or 90), and I shot with just 50 and 85 for years on film.)
 yardcoyote's gear list:yardcoyote's gear list
Fujifilm X10 Fujifilm X100T Fujifilm X-Pro1 Pentax K-5 IIs Fujifilm X-M1 +20 more
Samuel Jessop Regular Member • Posts: 150
Sorry to be difficult, but I don't find the 23mm to be either long or short enough for how I shoot.
My pick would be 18/2, 35/1.4, and 56/1.2, and I hopeful that eventually I am able to have an 18/1.4 that is good as the other bright XF primes.
 Samuel Jessop's gear list:Samuel Jessop's gear list
Fujifilm X-E3 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm 50-230mm +3 more
Adamant Contributing Member • Posts: 797
16
35 1.4
90
Touraine Contributing Member • Posts: 515
If I had the money, I would get the following.
16 mm (Landscape)
18 mm (street)
56 mm (Portrait)
The 18-55 mm can do everything else in between.
vagari Senior Member • Posts: 1,036
mine is 23/2, 35/1.4 , and 56/1.2
might add a 16/1.4 and 60/2.4, when they go on sale again
but that's as far as I'm going in Fuji-land
never take more than 2-3 out at a time...
dacms Regular Member • Posts: 236
16mm,35mm f/2,90mm
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 9,169
The three primes I carry when traveling light: 14/2.8, 23/2 and 35/1.4. Small, light and extremely good!
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Sony RX100 IV Fujifilm X-Pro2 Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R +7 more
(unknown member) Veteran Member • Posts: 4,084
14/2.8, 23/1.4, and 90/2
I'd keep my 32/1.8 and 50/2.8 macro Touits for the in between.
http://jamesmbailey.com
Stop Whining, Start Shooting
