Next PLM lenses
Started Feb 11, 2017 | Questions
Sir Autofocus Regular Member • Posts: 225
Next PLM lenses
Having heard many positive comments about the autofocus performance of the 55-300 PLM lens, what are you hoping the next lenses will be to receive a PLM upgrade?
I'd like to see a PLM version of the FA 150-450mm f4.5-5.6ED DC AW where I'm thinking that the improved AF would be a big plus for wildlife photography. I'd also like to see a PLM version of the FA 70-200 for the same reason, although that would mainly benefit K-1 owners at this point. A lower priority for me, but still on my wish list, would be a PLM version of the DA 16-85 lens, which I don't usually use for wildlife but sometimes use for portraits.
(unknown member) Senior Member • Posts: 2,206
Re: Next PLM lenses
From what I've gathered through other forum posts, PLM isn't designed to drive heavy lens arrays.. it is more adept at the smaller type lenses such as the 55-300mm.
I think, for FF we might see some primes though with this technology.
For DA* I'd like to see the 16-50mm and the 50-135mm both get PLM (or at least a decent DC motor).
siva-kumar Regular Member • Posts: 233
Re: Next PLM lenses
I am interested to see any information (official) which says PLM is for light lenses only. I have read only 'maybe' posts. Thanks
 siva-kumar's gear list:siva-kumar's gear list
Pentax K-3 Sony a7 IV Pentax HD DA 560mm F5.6 ED AW Sony FE 200-600 F5.6-6.3 Panasonic Lumix DC-G9 +3 more
miles green
miles green Veteran Member • Posts: 7,827
Re: Next PLM lenses
The FA* 300mm f/2.8!
(and compatible FF TCs)
The 70-200, 150-450 and 560mm should be as fast as possible...
But the TOP priority should be to upgrade all the DA* lenses.
Miles Green
Pentaxian with chronic LBA since 1997
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
asahi man Senior Member • Posts: 1,060
Re: Next PLM lenses
8
Official it's only made by Olympus.
They told that the 2.8 35-100 is using 2 ! AF motors,because the lens group is to heavy for the current motor.
And the Olympus motor is the same type.
I had the focus group of the 150-450 in my hand.....
Compare to the Olympus group with 2 motors,I think Pentax needs 4 motors or a complete new type of plm.
The next is,the mechanic around the focus group is completely different in every plm type lens against the Pentax DC or Canon or Nikon ultrasonic lenses.
The focus groups are in a absolutely durable and massive leading construction.
The plm type groups are in a loose leading.
It's not a secret that all these new motors are not made for heavy weights.
The new way is to use more than one motor.
Best regards
walgarch Regular Member • Posts: 331
Re: Next PLM lenses
Just to add more data to the mix. Roger Cicala or LensRentals fame also came to the same conclusion (although he admits he's speculating):
https://www.lensrentals.com/blog/2016/04/a-look-at-electromagnetic-focusing/
Why more motors? There must be a good reason because three or four motors has to be more expensive than one or two. I assume the most likely reason would be more power to move a larger element. If my understanding is correct, LEM motors are fast and silent, but not as powerful as a DC motor.
It appears, at least for right now, that single LEMs are most suitable for small, light, focusing elements that don’t have to move very far. Bigger elements probably need multiple motors. LEMs may use less electrical power than USM motors, but I don’t know if this would be significant enough to extend battery life
Will
http://www.flickr.com/photos/walgarch
 walgarch's gear list:walgarch's gear list
Pentax K-1 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO HD Pentax D FA 24-70mm F2.8 ED SDM WR Pentax FA 15-30mm F2.8 Fujifilm X100S +9 more
petebfrance Contributing Member • Posts: 757
Re: Next PLM lenses
I think the most important for the brand as far as getting good reviews (and thereby appealing to more buyers) is to produce a good standard zoom, an 18-55WR or what-have you.  If they'd had something like that around it could have been offered with the KP as a rather enticing package.
Incidentally, the question was also asked in these threads which may interest you:
https://www.dpreview.com/forums/post/59030496
https://www.dpreview.com/forums/post/59017096
regards,
Pete
 petebfrance's gear list:petebfrance's gear list
Canon PowerShot SX50 HS Pentax K-50 Pentax smc DA 18-55mm F3.5-5.6 AL WR Pentax smc DA 35mm F2.4 AL +4 more
FantasticMrFox
FantasticMrFox Regular Member • Posts: 210
Re: Next PLM lenses
I seem to recall that Ricoh stated as much in an interview, but I am not 100% sure.
In any case they are making a big fuss about the focusing group in the new 55-300 being 93% lighter than the last one. Which makes it pretty unlikely that the PLM technology could achieve similarly fast results with lenses such as the 70-200 or 150-450.
Portfolio, travelogues and reviews on my website: http://www.thefoxtakespictures.com
 FantasticMrFox's gear list:FantasticMrFox's gear list
Pentax K-r Pentax K-3 Sigma 17-50mm F2.8 EX DC OS HSM Pentax smc DA 18-55mm F3.5-5.6 AL WR Pentax smc DA 35mm F2.4 AL +3 more
zakaria
zakaria Veteran Member • Posts: 6,556
Re: Next PLM lenses
Best regards
Hi Asahiman
CP+is near the horizon
Do you think we will see the rest of the 10 things you mentioned before?
We have seen KP with the 4 grips. There are still 5.
pentaxian .
 zakaria's gear list:zakaria's gear list
Fujifilm X-H1 Pentax K-1 II Fujifilm X-T3 Nikon D780 Pentax smc FA 31mm F1.8 AL Limited +8 more
Re: Next PLM lenses
10???
zakaria
Re: Next PLM lenses
asahi man wrote:
10???
Yes I think I read it here or in other forum.
Maybe I am wrong.
pentaxian .
Michael Perham Senior Member • Posts: 1,349
Re: Next PLM lenses
Amen.
 Michael Perham's gear list:Michael Perham's gear list
Fujifilm XQ1 Fujifilm X70 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Pentax smc DA 12-24mm F4.0 ED AL (IF) +3 more
Re: Next PLM lenses
zakaria wrote:
asahi man wrote:
10???
Maybe I am wrong.
I talked about 10 lenses on the old internal road map.
4 till 5 are still open of this list.
No cameras,I have only very low information about new camera possibilities.
Not really heavy enough to talk about.
Best regards
LightBug Senior Member • Posts: 2,818
PLM lenses are focus by wire
I just learned today that many of the mirrorless system lenses and the PLM 55-300, have no mechanical linkage for focusing, so they cannot even be focused manually on an older body or another system via adapter.
Is it possible for a lens that adopts PLM to also include mechanical linkage for focusing?
 LightBug's gear list:LightBug's gear list
Pentax 645Z Pentax Q-S1 Pentax KP Ricoh Theta V Pentax smc DA 15mm F4 ED AL Limited +19 more
zakaria
Re: Next PLM lenses
asahi man wrote:
zakaria wrote:
asahi man wrote:
10???
Maybe I am wrong.
Best regards
Thank you so much my dear friend.
pentaxian .
Skip py Senior Member • Posts: 1,157
Re: Next PLM lenses
Thanks for these informations Asahi Man!
Do you think PLM motors could be used for TS lenses? AF motor in the front or rear part of the lens, shift and tilt motors to record and adjust with tethering, like the old Pentax powerzoom motors ?
Kind regards, fred
PS: any hints about a Powerzoom comeback, especially for video ?
 Skip py's gear list:Skip py's gear list
Pentax K-01 Pentax K-3 Pentax K-1 Sony a7R III Sony a7 III +6 more
FantasticMrFox
Re: Next PLM lenses
Asahiman, do you happen to be able to divulge anything on that elusive APS-C UWA zoom that has been lurking on the roadmap for years? Is any serious development going on with it?
OP Sir Autofocus Regular Member • Posts: 225
Re: Next PLM lenses
Hi Pete, I think that's a good suggestion about improving kit lenses.
