Bokeh with T4i
Started Feb 8, 2017 | Discussions
Crotonmark Contributing Member • Posts: 933
Bokeh with T4i
weird question since I don't know what I'm doing wrong
how can I ensure a blurred background ? Sometimes w same lens and settings the background will blur and sometimes it doesn't.  How can I guarantee blur?
Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
patticake Senior Member • Posts: 1,308
Re: Bokeh with T4i
can you post a couple such pics?
chances are they have very different apertures or the same aperture but at very different distances.  a faster aperture keeps less of the distance in focus, a smaller one keeps more in focus.  i believe that to have everything in focus, you'd need an aperture of f/16 or a little better whereas an aperture of f/1.8 will only have a little bit of the pic in focus - it'll give much more bokeh, but if you shoot a face, for example, maybe only the nose will be in focus.
 patticake's gear list:patticake's gear list
Olympus PEN E-PM2 Sony a6100 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +3 more
OP Crotonmark Contributing Member • Posts: 933
Re: Bokeh with T4i
OK Please see the two images below - both have same aperture
thanks
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: Bokeh with T4i
well, similar aperture (f/5.6 v f/5)
But very different focal lengths, 300mm v. 135mm. f/5.6 with 300mm will give much narrower depth of field and more background blur than f/5 with 135mm.
http://www.dofmaster.com/dofjs.html
thanks
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Re: Bokeh with T4i
Thanks again but there is no bokeh in the 135mm shot.
R2D2 Forum Pro • Posts: 26,551
Re: Bokeh with T4i
Be close to your subject.  Be far from the background.
R2
Re: Bokeh with T4i
thank you
I might  be able to remember that
R2
Digirame Forum Pro • Posts: 41,857
Re: Bokeh with T4i
You should be able to find a depth of field calculator on the internet (the last time I checked). Maybe that will help you understand it better. There's a lot of variables that determine the outcome, like for example the distance from the subject, the aperture and focal length. You can read many articles about it on the internet too.
Re: Bokeh with T4i
Thanks. I have done that. However reading is different than being in the field
Re: Bokeh with T4i
Yes, I believe in learning by doing. That comes with exploring different options. I'm constantly experimenting with different apertures or ISO settings etc.
So, in your case take pictures of the same things at the same distance and focal length, and change the aperture repeatedly. Then keep the aperture and distance the same  and change the focal length repeatedly.  There's other things you can do also.  That helps give you practical experience.  As someone that lives by doing, I take about 15,000 pictures a year.
Re: Bokeh with T4i
Thanks for the suggestion. Really helpful
jvc1 Senior Member • Posts: 2,202
Re: Bokeh with T4i
FYI. Bokeh isn't blurred background, it's the quality of the out of focus areas.
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
Re: Bokeh with T4i
Can you explain this more please
Re: Bokeh with T4i
I'm not the best person to clearly explain this but I'll give it a shot. Most lenses can give you a blurred background. Bokeh describes the quality of that blurring. If you've seen pictures with blurred lights in the background you can see that the rings those blurred lights produce vary in harshness and shape from 1 leans to another. Some of that is determined by how many blades the lens has, some by the quality of the glass. I'm sure there are other variables as well.
Your original question has nothing to do with the quality of the blurred background (bokeh), just depth of field (front to back area that is in sharp focus). Your 1st picture that has more background blur had the subject close to the lens with a lot of separation between subject and background. in the 2nd picture, the subject was far away from the lens and the distance between the subject and background was minimal.
There are others who frequent these forums who know far more about this than I do so if I've mangled the explanation, please jump in.
DP13Photo Veteran Member • Posts: 6,305
Re: Bokeh with T4i
Pretty much almost any lens on your T4i can make a blurred background.
For more "bokeh" do the following:
1. Use a smaller aperture
2. Use a longer focal length
3. Come closer to the subject
4. Move the subject farther from the background
5. Pay attention to background lighting
Dave
 DP13Photo's gear list:DP13Photo's gear list
Sony a7 III Sony a7C Sony a7 IV Sony FE 28mm F2 Zeiss Batis 85mm F1.8 +15 more
Re: Bokeh with T4i
And another one that doesn't know what" bokeh" means.
Re: Bokeh with T4i
https://en.wikipedia.org/wiki/Bokeh
Dave
Re: Bokeh with T4i
That's right, so you can't get "more bokeh" only better or worse bokeh.
Re: Bokeh with T4i
So what I was going for in reality was isolation
I was at a sporting event and I wanted the play - the athlete to be in focus and the background blurred.  I was using a 70-300mm lens on the T4i and the smallest aperture I could get was f5 from where I was sitting and the amount of light that I had to work with
Re: Bokeh with T4i
Yes, isolation or shallow depth of field.
