Old kit lens, new kit lens or a pro zoom?
Started Feb 7, 2017 | Discussions
Elmokki Regular Member • Posts: 276
Long story short, how good are the various kit lenses (Olympus 14-42mm R II and EZ, Panasonic 12-32mm and Panasonic 12-60mm) and how much would you pay for them?
I'm looking to buy GX80/GX85 or E-M10 mark II and need something short and probably zoom since I will be selling my E-PL6 with a lens - probably the kit lens. I am under the impression that the Olympus kit lenses are the worst out of the four with the EZ being slightly worse than the R II, which I personally have found usable if a little soft on corners and with annoying mechanism of requiring manual extension before you can shoot even at 14mm.
If I were to buy a camera right now at the quoted prices I'd be paying around 170€ extra for the 14-42mm EZ on top of E-M10 mark 2 and 240€ or 250€ extra for the two panasonic kit lenses respectively on top of GX80 (though that GX80 is a single store selling the silver body for 449€ while others sell at 549€ at cheapest). The other option would be to seek an used 14-42mm R II for 60-80€, though in reality I'm waiting for sales and cashbacks and hoping that a sale puts a kit closer to body only prices, preferably during a cashback.
Now, I also did think of getting the Olympus 12-40mm f/2.8 briefly. They go for 600€ used here which is way cheaper than what you can get the Panasonic 12-35mm f/2.8 for. This, however, seems like a bit steep investment for my photography needs I think. The Panasonic kit lenses have 12mm at f/3.5 with hopefully good enough optical quality, but the current ~250€ price premium on them compared to body only made me think that 350€ extra wouldn't be that horrible. I'm not even sure how awful handling a big pro zoom on the two fairly small bodies I am thinking on would be.
I did briefly also consider primes, but they're generally fairly expensive apart from the Panasonic 14mm f/2.5 so I think I'm better off with either paying a bit more for a pro zoom or a substantially less for a kit zoom.
The price of new GX80 + used 12-40mm f/2.8 is around the same as the price for new G80 + new 12-60mm kit lens. The latter pair would be weather sealed, but that'd be only mildly convenient and I think optics are a better investment than bodies anyway.
 Elmokki's gear list:Elmokki's gear list
Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 12-35mm F2.8 +3 more
Olympus OM-D E-M10 Olympus PEN E-PL6 Panasonic G85 Panasonic Lumix DMC-GX85
C Sean Veteran Member • Posts: 3,423
Re: Old kit lens, new kit lens or a pro zoom?
Hello Elmokki
The 2.8 pro zooms give the 'photographer' the option to shoot in limited light and that's about it. In my opinion, their main benefit is their weather sealing and normally I shoot around F4.
I believe it's better to have a weather sealing body and lens so when it does rain on the trips, the camera is safe and more importantly you can use it. For example on a trip it was pouring with rain and I was the only one using my camera because it was weather sealed.
mshine
mshine Regular Member • Posts: 195
12-40 will be front heavy on m10ii. It's an excellent lens, but rather bulky in mft terms. Do you mind that? I did, generally too much to carry for my purposes...
12-32 is an ok lens, and can be had very cheaply from ebay, just over 100 €. Physically totally different with almost the same zoom range. Unbeatable value/price. So light that it easily goes always with you, just in case.
I would forget buying the rest standard zooms (or save for the superb 12-35?) separately.
Can you see a difference? Compare lenses by searching for photographs by lens:
http://www.flickriver.com/search/m.zuiko+12-40mm/
http://www.flickr.com/photos/elahtine
You see things, not as they are, but as you are.
Barty L Senior Member • Posts: 1,850
Get the 'pro' zoom (nt)
BartyL
www.facebook.com/barty.lobethal/photos_albums
john isaacs Veteran Member • Posts: 8,442
I have the 14-42 R II, came with an E-PL6 that I converted to IR; haven't used it, may never.
I have the 14-42 EZ, got it to make an E-M5 pocketable.  I don't like the power zoom control.  Unlike the 12-50, it is a toggle type (you twist the zoom ring to engage the power zoom and hold it until it goes past where you want it, then twist it back the other way quickly a couple of times to nudge it back until it goes past where you want it, and so on.  With the 12-50 (and 45-175), you turn the zoom ring like a normal mechanical zoom and stop where you want...done.  At any rate, I use the lens rarely.
Basically, I am not a fan of kit lenses; they are slow with limited range.  I do have the full range zooms (Panasonic 14-140 I and II, Olympus 14-150 II).  My wife uses the 14-140 I, but it's bigger and heavier than the 14-140 II.  I like the mark II versions of these lenses, especially the Olympus because it is sealed.  I usually recommend getting one of those and a prime of choice for low light interior.
I use the faster zooms most of the time.  Probable the 12-40 f/2.8 the most, although the Pansonic 12-35 pairs well with the Panasonic 35-100 (they both take 58mm filters).
I do like the 12-60 range (I had the Zuiko 12-60, and use frequently the Nikon 24-120).  But the kit version is slow, and the new one is not much faster and a lot more expensive.
If you mostly shoot outdoors, get the full range zoom.  Add a fast prime (I like the 17mm f/1.8) for low light shots in or out.
If you shoot a lot indoors, get the faster PRO zoom.
For me, I like to have the PRO wide angle zoom, plus an ultra wide (9-18 is very small), full range (14-150 II is my choice now), plus the 17mm f/1.8.  I'll add the 45 f/1.8 if I plan to shoot concerts/theater/dance.  That kit fits in a very small bag, great for travel.  Most shots are with the PRO wide angle zoom.
sean000 Veteran Member • Posts: 7,727
Generally the pro zooms and primes will offer better sharpness and contrast (especially towards the corners and edges)... and maybe other bells and whistles depending on the lens. The 12-40mm has some added perks like weather sealing, an excellent manual focus ring with distance scale, the ability to focus quite close, and (at least a perk for Olympus cameras) a programmable L-Fn button.
Some of the variable aperture zooms have the advantages of being smaller, lighter and less expensive. The question is how much do you give up in terms of IQ? For some not that much at all. I used to have a Panasonic 14-45mm that was probably the sharpest kit zoom I've ever owned. I put it up there with the Nikon 18-70mm f/3.5-4.5. The 14-45mm compares quite well against a lens like the 12-40mm f/2.8 or Panny 12-35mm f/2.8. In good light the pro zoom doesn't offer much advantage except for 12mm being MUCH wider than 14mm. I also had an Oly 12-50mm kit zoom that came with my E-M5. it wasn't as sharp as the Panny 14-45mm, but I ended up using it more because of it's wider wide end and it's close-focusing capability. Whatever sharpness it lacked compared to the Panny was not that obvious for most photos unless you pixel peeped. Well... it had some flaws at the corners and edges, but the center was really nice. Great for some photos, but not for others.
I shoot primes quite often... the Panasonic 20mm f/1.7 pancake is the lens that brought me to m4/3, and I still shoot with it a lot. I also shoot with the Oly 45mm f/1.8 and a Rokinon fisheye quite often. The 45mm not as much since I bought the 12-40mm f/2.8. The 12-40mm is my most used lens, but it's a beast compared to the typical m4/3 kit zoom. That said it's really light and compact compared to my old Nikon 17-55mm f/2.8 for APS-C, and it's a better lens in every regard. The 12-40mm f/2.8 is a wonderful lens, but a variable aperture kit zoom might do quite well for daytime walk-around use. I often use the slower Oly 9-18mm zoom as my walk-around go-to, but I like wide angles.
Ultimately it depends on what you shoot, where and what the lighting conditions are. Primes are great and compact, but the zooms sure are nice when I'm out with the family... or anytime when I need to shoot quickly from a variety of focal lengths. The new Oly 12-100mm f/4 sure has a lot of appeal for a general use lens as well.
Sean
 sean000's gear list:sean000's gear list
Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus OM-D E-M5 +6 more
OP Elmokki Regular Member • Posts: 276
I may have framed my question badly: I already have primes
I may have framed my question a bit badly. I own a few primes: Panasonic 25mm f/1.7, Olympus 45mm f/1.8 and the Olympus 60mm f/2.8 macro. I mostly use the 25mm prime on my camera, but there are two reasons I currently occasionally use the 14-42mm R II: 14mm is substantially wider than 25mm and as long as there's enough light or my camera is on a tripod the image quality is good enough that the only reason to switch to 25mm or 45mm primes is the shallower depth of field available. I also have the cheap Olympus 40-150mm for longer focal lengths and as much as I'd love either of the cheap 300mm zooms, that's a question I don't need help with. It's more of a question of when I'll get whichever is the cheapest (or Panasonic if I have Panasonic camera by then)
I'm pretty well covered for anything except the wider focal lengths, which is where I just simply need a new lens of some kind. If I wanted to truly shoot wide in low light I'd just get the Olympus 12mm f/2.0 even if it's quite expensive. The pro zooms at f/2.8 aren't really that fast anyway, less than a stop faster than the kit zooms at their shortest focal lengths. Currently, without proper image stabilization, even f/1.7 sometimes feels slightly too slow indoors.
I suppose the full range zooms might be an alternative, except that they feel a bit too expensive for what I feel like they are. I generally don't mind swapping to the 40-150mm if I need the extra reach, though of course it might lose me some shots and I'd thus rather buy something more specialized or cheaper. That said, if I did buy a body with weather sealing that would be very interesting.
I guess the main question I wanted to ask is whether I should pay the prices I quoted to get a kit instead of body only or whether I should try to buy a second 14-42mm R II cheaply. That'd obviously depend on which kit lens was available, which is why I wanted opinions on the Oly 14-42mm EZ and Panasonic 12-32mm and 12-60mm kit lenses.
It's really annoying to have to think about this. I thought I could get one of the newer kit lenses for under 100€ as part of a kit. The only kit I've seen where the price premium from having a kit lens is under 100€ is G80, which has the weather sealed Panasonic 12-60mm for 70€ more than just the body. As alluring excuse as that and the weather sealing are to buy a G80, I really don't think I should buy that over GX80 or E-M10 mark 2 with the price difference they have.
As I stated on another post, I framed my question badly: I have 25mm, 45mm and 60mm primes. What I need is a wider lens to replace my 14-42mm R II. The question is whether that should be another 14-42mm R II or some other kit lens offered with whatever camera I end up buying or something else like the pro zoom. The kit lenses seem to cost substantially more than I thought they would which makes this hard. If they were less than 100€ compared to body only I would just get whatever.
Currently I don't think the 12-40mm f/2.8 would be fast enough for low light since I find f/1.7 to be almost too slow and that's 1.5 stops faster. That said, when I buy a new camera, maybe the proper IBIS compared to the near worthless 2 axis IBIS in E-PL6 would compensate that much for anything that doesn't move. That said, the size does intimidate me, considering I plan on buying GX80 or E-M10 mark II, even if I haven't truly experienced anything like it, so maybe I'd better just scrap that off the list.
The 12mm f/2 would be neat too but I feel like that's too expensive and I think I can deal with using flash, tripod or a longer focal length in low light.
Re: I may have framed my question badly: I already have primes
In my opinion, getting to 12mm is significant, so I would try to get the 12-40 or 12-60.
The 12-40 is a really good lens, but so is the 12-35 f/2.8.
Neither has the range of the 12-60, but the 12-60 is slower.
My preference is faster zooms.  But if you don't mind slower, then the 12-60 might be a good choice.
Here, you can get a G85 for $900, and a G85 w/12-60 for $1000.  That's $100 for a lens that sells alone for $550.  Quite a bargain.  If that kit meets your needs, I would say go for it.
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Depends on what you're looking for: Good all-around IQ or large aperture. If you need large, it will cost you dearly for the Panny 12-35 0r Oly 12-40. If you want good versatility and IQ and also have large-aperture  pimes, a used Panny 14-45 or 14-42 Mk II  will certainly do the job. I am quite amazed by the fact the 14-45 I bought new in 2011 is even costlier now! Still a great  basic zoom lens after all these years.
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
Here G80 is around 970€ alone and 1050€ with 12-60, which probably makes it about the same cost compared to other models. I find it a bit hard to justify getting that when GX80 alone is 450€ and even with the 12-60 699€ (curiously it's 690€ with 12-32), though it's far less useful without weather sealing.
I do kind of doubt the lens actually sells much at $550 though. If it did, that GX80 + 12-60 would be an amazing bargain for the lens alone.
Since you already own a trio of primes, unless you want 12mm covered then the 12-40mm f/2.8 might not offer you much more than the convenience of having a zoom that rivals your primes for IQ.  If I don't need to shoot quickly I will switch to my primes for indoor stuff. I use the 12-40mm f/2.8 for indoor shots as well, but usually only when there is enough light or when I don't have time to switch lenses (or when I'm shooting with a flash gun). The 12-40mm excels at event photography where the fast AF and zoom are handy. I also use the L-Fn button to temporarily switch from my flash preset (with an external flashgun mounted) to my available light Auto-ISO preset. I sometimes also use the MF clutch to toggle between MF and AF.
The size of the 12-40mm f/2.8 is not that significant to me coming from my previous DSLR shooting experience, but it is significant when compared to many m4/3 lenses and the smaller m4/3 bodies. Carrying and shooting with a GX80 or E-M10 with a 12-40mm attached is a different experience from using one of those cameras with a smaller/lighter zoom or prime. The center of gravity shifts to the lens more than it did when I shot a Nikon D200 with a 17-55mm f/2.8. It doesn't bother me while shooting because I always support the weight of my kit with my left hand under the lens and operate the camera controls with my right. It's not a lot to carry, but you won't carelessly hang an E-M10 with a 12-40mm attached around your neck as comfortably as you would with a lighter and smaller lens. This is one reason I enjoy using the 20mm f/1.7 and the Oly 9-18mm as walkaround lenses. I look like a tourist, but the camera is resting comfortably around my neck and is always ready to shoot. When I walk about with the 12-40mm attached, I usually carry the camera in my hand while not shooting, or in my camera bag. With the 12-40mm f/2.8 my m4/3 kit is still way more portable than my old DSLR gear.
If you can try the lens out before you buy. It's a beautifully engineered and built lens that will tempt you, but try to envision where it fits in your lens lineup and where/when you might use it over your other lenses. It is a beautiful chunk of lens, but it's definitely a chunk compared to featherweights like the 9-18mm and 45mm f/1.8.
Sean
jalywol
jalywol Forum Pro • Posts: 12,301
C Sean wrote:
Hello Elmokki
I would strongly disagree with this.  I've used both the 12-40 and 12-35mm, and both had significantly better output in terms of contrast, microcontrast, and fine detail sharpness.  I had been using the 12-32mm on my GM5, and had been very pleased with it overall, but when I got the 12-35mm, the difference was actually striking.  Images had a more realistic feel and much more "pop" to them.
In the US, the 12-35mm is on sale for quite a bit less than it originally went for, so if there was any way to find one of those, or even find a used one, that's the one I'd recommend over the other lenses mentioned.
Failing that, the 12-32mm is a very good kit lens.
-J
alcelc
alcelc Forum Pro • Posts: 19,003
Dual IS, size and zoom range
As you have the fast primes for the low lighting, I suppose the only consideration is:
  1. Size; or
  2. versatility of zoom range.
Before that, if it will be used on a latest Pany body (like GX85 or G85 or GH5), I would be in favour of a Dual IS I/II supported lens (or you might be disappointed by the still relatively less effective IBIS only of Pany bodies comparing to EM5 I/II's standard). Upon that terminology, all Oly kit zooms would be ruled out.
For size, 12-32 wins. For zoom range, 12-60 wins. I don't think their IQ (very good in terms of their price) would differ much from each other. 12-35 f/2.8 would be no doubt winning on every aspect to the 2 but heavier/larger, cost much more, and yet not as long as 60...
Albert
Ulric Veteran Member • Posts: 4,559
I see that you have the Panasonic 25/1.7 and Olympus 45/1.8 primes and that means that you don't really need the "fast" 12-40/2.8.
You also already have a kit zoom. IMHO you should just sell the PL-6 without lens.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
I'd do that, but it's a fairly close relative I'm selling it to so I'm going to sell it with a lens and cheaply so they can actually use it.
In that case, getting the new camera in a kit including lens would be the way to go. I see at B&H that body+lens is only $50 more than the body alone.
Geekapoo
Geekapoo Senior Member • Posts: 2,832
Get the 12-40 f2.8 Oly
I've owned the Panasonic kit lenses (14-42 and 14-45), the Pan Leica 25mm and the Olympus 45mm. All of them pale in comparison with the 12-40 f2.8, an exceptional lens. The 12-40 is one of my favorite lenses and one of the best I have used.
You often heare photographers recommend you buy the best glass possible..there is a reason. The clarity for the 12-40 is exceptional (really shines when cropping). Purchasing the 12-40 was easily the best m43 decision I've made.
Richard
 Geekapoo's gear list:Geekapoo's gear list
Sony RX10 IV Fujifilm X-E3 Sony a7R IV Sony a9 II Sony 35mm F1.4 G +15 more
Update: Bought GX80 and 12-35mm f/2.8
Yeah. This really hurt my wallet but I ended up getting GX80 and 12-35mm f/2.8. I did say 12-35mm f/2.8 isn't sold at affordable prices, but it's for sale for about 600€ on Ebay from Europe brand new without warranty (grey market). In my books that's about as good as a near mint used one from Finland without warranty. It's about 3.5 times as expensive as I probably could've gotten the 12-32mm kit lens for used which does kind of sting, but I feel like the 12-35mm will probably keep its price well enough in case I end up regretting it for some reason. Who knows, maybe I'll even end up selling my 25mm f/1.7 if f/2.8 feels enough with dual IS which would bring the price down further.
GX80 body was 440€. It's been 399€ on a Black Friday sale and obviously the recent UK double cashback would've been even cheaper had I been ready to pull the trigger and found a trustworthy seller to ship it to Finland. I figured it's unlikely there's going to be some amazing cashback deal that brings it down much further any time soon since even that 440€ is 110€ cheaper than the next cheapest retailer.
Rich K
Rich K Senior Member • Posts: 1,006
A very nice kit - enjoy! (NT)
Rich in Reno
 Rich K's gear list:Rich K's gear list
Sony RX100 III Olympus PEN E-P5 Olympus E-M5 II Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic 12-35mm F2.8 +5 more
