Is this the best sharpness I can get with the 35 F2 WR @ F2?
Started Feb 3, 2017 | Questions
SimonV Regular Member • Posts: 333
Just recently got an X-T1 and a 35 F2 WR, and I'm a bit disappointed in the sharpness of the lens and the contrast wide open. Some reviews said it was a bit soft wide open, yet others said it was very sharp. Images online did too seem pretty sharp at F2. Having used the XF35 1.4 extensively before I knew what to expect, and this is supposedly even sharper, so I'm confused. Looking through those old images the sharpness seems better even at F1.4.
I took this today:
XF35 F2 WR, 1/100, ISO 250, F2
I can't see any good sharpess at any point of the image, and it's got this ugly haze like the X100 used to do with close up shots. This is what I'd call soft, not sharp.
I see the same problem with the 35 F2 WR in several images, this is only one example. In some conditions it seems "ok" but I'm yet to be even nearly as impressed as most reviewers I've seen. Right now the image quality doesn't feel a lot better than the first X100.
Is this really the best I can expect? I can still return the lens if it's faulty and get another identical one or a different lens.
Any insights?
Thanks!
Fujifilm XF 35mm F1.4 R Fujifilm XF 35mm F2 R WR Fujifilm X-T1
progo Regular Member • Posts: 238
Re: Is this the best sharpness I can get with the 35 F2 WR @ F2?
6
It's sharp but the dreaded spherical aberration strikes again! Basically you'll get this softness on the picture if you focus very close with big apertures. Close your aperture by a stop and/or back off few feet from the subject. It'll be much better by then.
Ken Rockwell demonstrates the same issue, other resources too. I don't think your copy is particularly bad in this regard.
 progo's gear list:progo's gear list
Canon PowerShot A530 Leica M-P (Typ 240) Pentax KP Leica Summicron-M 35mm f/2 ASPH Panasonic Lumix G Vario 35-100mm F4.0-5.6 ASPH Mega OIS
WalterH Senior Member • Posts: 1,280
Simon this is not a good foto to judge image quality. Actually it is close to a worst case I would not draw any conclusion from this image.
Your focus may be in front of your object. It is hard to see if it is because focus is on or in front of the front edge.
Take a flat object and focus properly then you can see image quality in the centre as well as in the edges. Have the camera parallel to the plane of the object.
Use a flash or a very stable tripod (with self-timer and electronic shutter) or both. This will eliminate any possible shaking that could blur your image.
Cheers
Walter
OP SimonV Regular Member • Posts: 333
Ah, I see! Thank you.
I don't how I missed the one issue that would've made me not get this lens :). I've read tons of reviews and none of them mentioned the spherical aberration as far as I remember (aside from the Ken Rockwell one).
Probably gonna have to return this then. That spherical aberration is a huge downside for me since I wanted a lens that can focus close and still be sharp. Still can't believe I missed that specific feature.
Thanks for the valuable info!
Vic Chapman Forum Pro • Posts: 10,694
I've not read that the 35 f2 is supposed to be sharper than the 35mm f1.4. F2 center sharpness doesn't catch up until f5.6 when they are even but by f11 the f1.4 is ahead again.
However, It looks to me that you have either mis-focused or have focused too close. The 23mm f2 is known to have issues if focused at closest distance wide open and maybe there is some of this in the 35mm f2 also. Step back a little or close the aperture by a stop or two and it should be fine.
The only reason to swap from the f1.4 is sound AF speed and shape/size. Likewise, the only reason to swap from the 35mm f2 is faster aperture and central sharpness wide open (at an aperture not available of the f2 model).
Click the link in this thread. https://www.dpreview.com/forums/post/59066041
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan. Writer, comedian, poet, Goon. 1918 - 2002
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
Birdmanfriday Regular Member • Posts: 441
I agree, it seems that both these f2 lenses show this characteristic when wide open / focussed close. If you plan to do a lot of close work you're probably better off with a lens optimised for that.
 Birdmanfriday's gear list:Birdmanfriday's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
(unknown member) Regular Member • Posts: 400
get the 16/1.4 then
Mirrorless Dan Regular Member • Posts: 101
If you need close focus I would recommend the Zeiss Touit 32/1.8. Its focusing speed is somewhere in between the very fast XF 35/2.0 and the slow and noisy XF 35/1.4. It is very sharp at any distance with aperture almost fully wide open.
You can see a comparison by Rico Pfirstinger on his X-Pert Corner
http://www.fujirumors.com/zeiss-touit-vs-fujinon-xf/ .
 Mirrorless Dan's gear list:Mirrorless Dan's gear list
Fujifilm X-Pro1 Fujifilm X-M1 Fujifilm X-H1 Carl Zeiss C Sonnar T* 1,5/50 ZM Fujifilm XF 18mm F2 R +8 more
BrettDR Contributing Member • Posts: 511
I agree. My buddy has the 35/2 and we've tested them against each other. Up close, the Touit is sharper.
 BrettDR's gear list:BrettDR's gear list
Fujifilm X100T Fujifilm X-T1 Sony a7R II Fujifilm X-T2 Fujifilm X-T3 +9 more
jaapjaap New Member • Posts: 19
I think my 1.4 would be sharper judging the example.
stevo23 Forum Pro • Posts: 24,759
Yep, this is consistent with my results too.
 stevo23's gear list:stevo23's gear list
Fujifilm X-Pro2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F1.4 R +3 more
This is a known issue with the 35 f/2 that I've been able to test out but others have documented it as well.
bob bacon New Member • Posts: 2
walie007 wrote:
get the 16/1.4 then
Yeah, brilliant idea, because a wide angle would substitute a normal field of view! Wait, in which bloody universe?
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
bob bacon wrote:
walie007 wrote:
get the 16/1.4 then
Please do note that you're commenting on a thread that is nearly 3 years old.  You should also know that someone listed as "(unknown member)" will not be in a position to respond to your post as that designation means that they have been banned.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
Cagey75
Cagey75 Senior Member • Posts: 1,347
walie007 wrote:
get the 16/1.4 then
Why would he need to do this? it's a completely different lens ... Just return the F2 and get another 35 1.4!  I don't know why Fuji messed up so much on these F2 variants, the 1.4 originals were stunning - apart from a little noise, which only bothers those into video.  Photographers shouldn't care - the lenses have also been updated that improved AF and along with, the 'chatter' noise.
 Cagey75's gear list:Cagey75's gear list
Fujifilm X-H1 Fujifilm XC 35mm F2 Venus Laowa 65mm F2.8 Macro +1 more
