G3X lens hood stuck on the filter adapter
Started Feb 3, 2017 | Questions
skiwidon
skiwidon New Member • Posts: 2
After importing a G3X lens hood and filter adapter, I attached the adapter to the lens and the hood to the adapter.  Worked fine, so I reversed the hood into the storage position, no problem.  Next I tried to remove the reversed lens hood; big problem.  Only comes off with the adapter ring and impossible to separate the two whether on or off the camera.  Anyone had this problem and how did you solve it?  Pressing the release catch does nothing and it seems like the hood must only fit on the adapter one way, which doesn't help me now!
I believe the hood and adapter are also used on SX60, SX50, SX40, SX530, SX520, SX30, SX20.
I am a semi-retired professional photographer and enjoy the G3X as a great travel camera when used with the electronic viewfinder.
Regards--
skiwidon, New Zealand
 skiwidon's gear list:skiwidon's gear list
Canon G3 X Canon EOS 5D Canon EOS 5D Mark III Canon EOS M3 Canon EF 24-105mm f/4L IS USM +4 more
Canon G3 X Canon PowerShot SX520 Canon PowerShot SX530 Canon PowerShot SX60 HS
Geodude Contributing Member • Posts: 596
Re: G3X lens hood stuck on the filter adapter
Could we have a few photos please?
 Geodude's gear list:Geodude's gear list
Panasonic Lumix DMC-FZ50 Canon PowerShot G1 X Canon PowerShot SX50 HS
Howard S Senior Member • Posts: 2,212
Mine mounts facing forward and back and releases by pressing the button.
 Howard S's gear list:Howard S's gear list
Canon G3 X Canon EOS 7D Canon EOS M Canon EOS M50 Canon EOS M6 II +12 more
skiwidon
OP skiwidon New Member • Posts: 2
I've consulted the instruction manual P171-172, (after the event) which makes what should be a simple operation quite obtuse!  The overseas supplier has kindly offered to send another.  I've replied that if they want to just send the FA-DC67B filter adapter ring, I could cut through the existing one with a pair of side cutters and attach the lens hood the correct way.  I'll probably then buy a 62mm rubber lens hood to attach to the adapter ring and make life a whole lot simpler!  Watch this space.
