People are very wrong about the advantage of larger sensor
Started Feb 2, 2017 | Discussions
yfan Regular Member • Posts: 330
5
You often hear people say that the low light performance is better with larger sensor. Manufactures and retailers all advertise saying something like “The low light performance is great due to camera's large sensor.” etc.
From physics point view, sensor size actually is irrelevant in low light performance. In the low light situation, the performance is dominated by lens which is independent of sensor. The bigger the lens, the more light it gets, the better IQ.
The true advantage of larger sensor is in the other end of the case, i.e. when light is abundant, one can shoot with base ISO and small aperture. The larger pixel, in this case, can hold more photons and less likely to get saturated, therefore it gives more dynamic range and better color depth etc. The analogy is like this, you drive a 4 tons truck (large sensor), the other guy drive a 2 tons pickup (smaller sensor) to get, say sand (photons). If there is only 1 ton of sand (photons) available, which is limited by supplier (lens), your bigger truck will not have any advantage.
The actual advantages of larger sensor lies in two areas:
1. Resolution - the large sensor can simply fit more pixels.
2. Base ISO performance.
Then why people get the misconception that large sensor has better low light performance? This is simply because the larger sensor camera is often come with larger lens and it is often referred to FF camera, which has many large and bright lenses to select. However, this can not be extrapolated to MF cameras. For example the latest Fuji GFX 50S does not have equivalent bright lens as FF. Therefore, the Fuji GFX 50S does not have any advantages in low light performance in comparison with FF.
So for those who want to “upgrade” to larger sensor cameras, I have a few advices for you:
1. Get as high pixel count as you can. Forget about 24MP FF camera with a f2.8 lens since a 24MP APS-C camera with a f2 lens can match you pixel by pixel.
2. Get fast lenses and use them. Lenses like f1.4, f1.2. Or you just carrying extra weight for nothing.
3. Shoot at base ISO and print image large. You will appreciate the IQ and enjoy the fact that smaller sensor cannot truly match.
Happy Shooting Everyone.
 yfan's gear list:yfan's gear list
Fujifilm X-Pro1 Nikon D800 Nikon D3200 Nikon D7100 Nikon AF-S DX Nikkor 35mm F1.8G +15 more
Dennis Forum Pro • Posts: 21,546
Re: People are very wrong about the advantage of larger sensor
So the idea here is that in low light, you're shooting maybe a 35/1.8 on APS-C and a 50/1.8 on FF ... maybe ISO 1600 on each and you're seeing less noise with the FF image.  Whatever you want to attribute that to - lens size or sensor size - it's a valid point that you only exploit that benefit when you have a lens with the same f-number (and you will get shallower DOF as a result).
I've seen threads in which people say they're going to move to FF for better low light and then, to afford it, buy the f/3.5-5.6 kit lens.
Yes, if you compare lens lineups for FF and APS-C, you'll find that both systems offer f/3.5-5.6 consumer zooms, f/4 midrange zooms and f/2.8 premium zooms.  Both systems offer f/2.8 primes and f/2 or f/1.8 primes and f/1.4 primes.  And prices aren't too dissimilar, so it's reasonable to upgrade from APS-C to FF and end up shooting equally "fast" lenses, allowing you to exploit the larger sensor for low light shooting.  Assuming you don't mind shallower DOF (most people are okay with it when looking to push the limits of low light shooting, but it's something to consider ... if you have to stop down for DOF, shooting handheld urban landscapes, for instance, then you won't see an advantage with FF).
Anyway, outside of some newbies who might think that the low light benefit of a FF sensor is automatic (with any lens) I don't think people are wrong about the advantage of larger sensors.  It does get talked about a lot in terms of low light, but I certainly see it being used a lot (and recommended a lot) for base ISO studio and outdoor photography.
- Dennis
Gallery at http://kingofthebeasts.smugmug.com
Camley Senior Member • Posts: 1,832
22
yfan - They say that because larger sensors have better noise performance than smaller sensors due the increased amount of light collected.
There are hundreds of posts explaining the reason for the noise advantage of large sensors. Great Bustard can tell you why you are wrong.
 Camley's gear list:Camley's gear list
Canon EOS 6D Sony a7R II
Mike - Senior Member • Posts: 1,069
Yea...not so much (op comment)
I currently own (in order of preference) -
Canon full frame and APS-C cameras. Similar capability / era cameras.
Sony full frame and APS-C cameras. VERY similar capability / era cameras.
Nikon full frame and APS-C cameras. Similar capability / era cameras.
I've tried this little unspecific experiment WAAY back after buying my Canon 6D. Used the same lens, VERY similar lighting, same subject, same distance on both full frame and APS-C versions of each brand noted above. The full frame cameras pictures won every time...ISO related noise wise. Set the aperture manually, let the camera pick the ISO and shutter speed. Why this method/camera setting...because this is the same way I capture most all of my photo's.
Mike
P.s. - Sold my Pentax, not  good choice of lenses..!
 Mike -'s gear list:Mike -'s gear list
Sony a6300
OP yfan Regular Member • Posts: 330
In low light case, the SNR is dominated by statistics noise i.e. photon counting, other noise sources such as device's reading noise are negligible.   It is this post's point that those hundreds posts are wrong.  They are still misleading many people like you.  I know what I am talking about.  I have a Ph.D degree in Physics.
JALComputing
JALComputing Contributing Member • Posts: 800
My experience* is that FF digital has better performance at ISO 6400. I shoot 1 inch, m4/3 and FF digital. I have a number of indoor portraits at high ISO in my gallery. Here is a shot done with a FF camera held overhead shooting over a crowd.
OOC Jpeg
DXO from RAW
*I do not have a PhD in Physics. I have shot sports, news, commercial, done my own b&w negatives, b&w prints, color slides, color prints. I have shot 35 film, 6X6 film and 4X5 film.
 JALComputing's gear list:JALComputing's gear list
Sony RX1R II Sony a7R II Fujifilm GFX 100 Sony a7C Sony FE 35mm F2.8 +10 more
Re: Yea...not so much (op comment)
Mike
I am not surprised you get that conclusion.
You do not know how to interpret your data correctly.
Your FF is getting twice light than your APS-C.  Therefor at the same f-number, ISO the FF is always one stop better.   You have to control the ISO/aperture making sure they get the same amount of total light.
sportyaccordy Forum Pro • Posts: 20,930
This is mostly right, except it's not the bigger pixels, but rather the bigger sensor. Each pixel is a little photon bucket, and image quality is proportional to the total number of photons you can catch in all the buckets combined.
I think the real advantage of larger sensors though is the amount of lens per dollar you can get. I don't think there's a bigger value for the money than something like a 50 1.8G.
Sometimes I take pictures with my gear- https://www.flickr.com/photos/41601371@N00/
 sportyaccordy's gear list:sportyaccordy's gear list
Sony a7 III Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Tamron 28-200mm F2.8-5.6 Samyang AF 35mm F1.8 FE Samyang AF 45mm F1.8 FE
AwesomeIan Senior Member • Posts: 2,309
in my limited experience full frame always comes away with cleaner pictures at high ISO (i.e. 6400-12800).
 AwesomeIan's gear list:AwesomeIan's gear list
Nikon D500 Pentax K-1 Pentax smc D-FA 100mm F2.8 Macro WR Tamron SP 150-600mm F5-6.3 Di VC USD HD Pentax D FA 24-70mm F2.8 ED SDM WR +7 more
Your experience is right. But you don't really understand the reason.
To be able to shoot at ISO6400, the FF has to gather twice the light than APS-C, The ability to gather that much light is due to larger lens (not sensor). Otherwise, for the same sized lens, APS-C can always shoot at one stop lower ISO to match the IQ. For the same sized lens, APS-C lens is always about 1-stop faster.
That's irrelevant.  You can be a great artist but not an engineer or scientist.
dwalby Veteran Member • Posts: 5,895
There are many other variables in the discussion, that can, and have been debated to death on these forums, but the basic premise is this:
If you have an APS-C sensor with X MP and a FF sensor, also with X MP, the FF pixel area will be roughly 2.5x the APS-C area. This means the FF pixel will count 2.5x the number of photons as the APS-C pixel, when both cameras are set to the same exposure. You correctly state that the SNR would be dominated by statistics noise (photon counting) so the FF will have inherently better SNR (with similar sensor technology) because it has a larger number of photons arriving in each bin (pixel).
Or, if you have the same pixel pitch on each sensor, the per pixel SNR will be the same, but the greater number of pixels on the FF sensor can be post-processed to improve the SNR by bin averaging, while retaining the same resolution as the APS-C sensor.
techjedi
techjedi Veteran Member • Posts: 4,216
Moot point if you cant get the same results with available bodies+lenses
5
They say that because it is observed in measured controlled testing as well as a massive concentration of anecdotal experience. Observation is more fundamental to science than calculation.
Yes, in theory, but there are a lot of factors in body/lens design that might impact the end result. The larger sensor bodies may simply afford engineering in them that smaller sensor bodies do not have. You could be correct in not attributing this to the sensor size itself, but at the end of the day, when you buy a camera+lens in the store, the end result matters more than which component is specifically responsible for those results.
Not going to agree/disagree on this because its beyond my training, but it sounds reasonable to me.
If I cannot buy the equivalent larger lenses for the smaller sensor, then why does this distinction matter when I am making a purchasing decision? When I use the largest/brightest FF lenses on an APS-C body, I still get measurably lower IQ (particularly in lowlight) than a FF sensor. So is it a misconception?
Agree with this advice, and I am happy with my APS-C setup. That said, in a cost-neutral world, I would still aspire to have the largest sensor platform that also had lenses in the focal lengths and apertures that supported my creative goals.
 techjedi's gear list:techjedi's gear list
Sony a7R III Sony FE 70-200 F4 Sony FE 90mm F2.8 macro Sony RX100 Sony RX100 VA +21 more
MediaArchivist
MediaArchivist Veteran Member • Posts: 6,163
Regardless...
Regardless of the reason, in practice a larger sensor will give you more options in low light conditions. You can choose higher speed, or lower ISO, or narrower aperture than you can with a smaller sensor in the same environment; assuming you have the same threshold for image quality. If you don't care about image quality, than the discussion is moot.
The proposition that a larger sensor yields better image quality in low light conditions has been proven many times over.
Want a roXplosion!?
 MediaArchivist's gear list:MediaArchivist's gear list
Sony a7R V Sony 135mm F2.8 (T4.5) STF Sony 24mm F2 SSM Carl Zeiss Distagon T* Sony FE 20mm F1.8G Sony FE 50mm F1.2 GM +28 more
PhotoFactor Veteran Member • Posts: 4,239
Just no. Way too simplistic, riddled with assumptions.
 PhotoFactor's gear list:PhotoFactor's gear list
Sony a6400 Sigma 30mm F2.8 EX DN 7artisans 25mm F1.8 Sony E 18-135mm F3.5-5.6 OSS Sigma 56mm F1.4 DC DN | C +3 more
alanr0 Senior Member • Posts: 2,593
Re: Equivalent lens availability and micro-lens performance
6
What do you mean by the same sized lens?  Same physical aperture or same relative aperture?  Same focal length or same field of view?
If I am shooting with a 50 mm f/1.2 lens on FF, I need a 33 mm f/0.8 lens to capture the same amount of light in the same field of view using an APS-C sensor.
If it exists, the f/0.8 mm lens needs to be more complex to realise 1.5x higher spatial resolution across the frame at increased numerical aperture, so will be bigger, heavier and much more expensive for equivalent performance.
Furthermore it is unlikely that the same effective quantum efficiency would be maintained in current APS-C cameras at f/0.8.  Modern sensors rely on micro-lenses to maintain a high effective fill-factor, and these are typically less effective at apertures wider than F/1.4.
Alan Robinson
Re: Advantages of larger sensor
10
yfan wrote:
Camley wrote:
But you can't increase the aperture of the lens indefinitely.  There is a theoretical limit of F/0.5 (Numerical Aperture 1.0) for a lens in air.  For general photographic purposes, there are few lenses faster than F/1.2.
A large sensor allow one to use a large diameter fast lens which can capture more light than is possible with a smaller sensor.
Low light is the only regime where device read noise is significant.  At higher light levels, photon statistics dominates.
For equivalent exposures (same field of view, same physical aperture, same shutter speed), the total light collected is indeed independent of sensor size.  However a larger sensor allows one to use a physically larger lens whose equivalent either does not exist or is unaffordable for an APS-C sensor.
Cheers.
Alan Robinson
Iliah Borg Forum Pro • Posts: 29,605
exiled to PS&T
You are allowed to stir silly controversy everywhere on DPR forums, but this forum is the only place where you are allowed  to stir a clever controversy (not that facts agree with your view the way you put it, but it is definitely worth discussing).
John Sheehy Forum Pro • Posts: 27,198
Have you compared the Nikon D500 and the Canon 5D at ISO 12800? You did say "always".
The same ISO is not necessarily what you would use, though, to take the same photo. The fact is, you can't use the same ISO on FF with the same FOV and DOF; you must use a shallower DOF, and that requires A LARGER LENS. The larger sensor is not like a larger parabolic dish capturing a larger satellite signal; the aperture of the lens is what is like the larger dish. The larger sensor is just a larger canvas without the larger lens.
alanr0 wrote:
I don't see this conflict with what I said.
It's SNR matters, not absolute noise level matter.
No argument on this. I acknowledged this by saying that "normally large sensor come with large lens".
Cheers.
Alan Robinson
"same size" is a simplified/approximate state try to make point clear, however, I think it may did opposite.  In general, for equivalent lens on different sensor size, they will end up about the "same" size.   For example, FF 50mm f2.8 is about the same size as DX 35mm f2.    Yes, yes, you will argue that this is not always the case.   The point I try to make is that the low light performance is lens dominated, not sensor.  Going larger and larger sensor does not bring in advantages, MF or large format sensor (if exist) will not give you low light performance.  You need the right lens!  It is a misconception that large sensor equals better low light performance.
Don't get me wrong, I did not deny large sensor's advantages.  I just state that it's irrelevant in low light.  It is lens' that determine the low light performance.  Large sensor responsible for higher resolution and base ISO performance, etc.
Alan Robinson
