Sigma 150-600 C with teleconverter?
Started Feb 2, 2017 | Discussions
Yorkmiester Regular Member • Posts: 109
Hi everyone,
Has anyone used a teleconverter with the 150-600 C? Looking for astrophotography / wildlife purposes. Would be used with a tripod, and live view focusing on my D500.
Are the sigma 1.4 and 2.0 teleconverters decent?
 Yorkmiester's gear list:Yorkmiester's gear list
Panasonic FZ2500 Fujifilm X100F Nikon D7200 Nikon 1 J5 Nikon D500 +12 more
Nikon D500
Manzur Fahim
Manzur Fahim Veteran Member • Posts: 4,071
Re: Sigma 150-600 C with teleconverter?
Yorkmiester wrote:
Hi everyone,
I've asked the same question some times ago and it seems that TC-1401 is the best bet for this lens, AF and IQ wise. TC 2.0 will not do AF I think. Not sure about live view. So I bought the 1.4x but haven't tested it yet.
 Manzur Fahim's gear list:Manzur Fahim's gear list
Fujifilm GFX 100S Fujifilm GF 110mm F2 Fujifilm GF 23mm F4 Sigma 105mm F1.4 DG HSM Art Sigma DP2 Merrill +5 more
Alan Dewey
Alan Dewey Junior Member • Posts: 37
I have 150-600mm sport and the Sigma 1.4 teleconvertor.
With this combination, the D7100 indicates max aperture is f/9, but it will autofocus.   (The camera manual says it only autofocuses with max aperture f/8 or larger.)
So....
  1. use the teleconvertor or
  2. do not use the teleconvertor and just crop in post processing?
I only used teleconvertor a few times and I could not determine which was better.  Mainly because what I was using it for there was so much atmospheric distortions I could not tell.  (Car racing on hot asphalt, and a ship sinking 1/2 mile away on the ocean.)
I have not tried it on something closer and stationary.
Alan Dewey
Delray Beach, Florida
My day job is with a very large underwater photography & video equipment company in Fort Lauderdale.
Jura S Senior Member • Posts: 1,982
150-600C with Kenko Pro300 1.4x DGX on Canon 7D.
distance: 29 meters
Robert Sommers Contributing Member • Posts: 955
The combination did nothing for me. Focus on this nesting osprey was pretty degraded on this trip to Yellowstone. I never bothered again.
Robert Sommers
 Robert Sommers's gear list:Robert Sommers's gear list
Sigma DP2 Merrill Nikon D810 Nikon D7200 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +6 more
Stevie57 New Member • Posts: 3
Just received my Sigma 150-600mm with 1x4 teleconverter,well to be honest at the moment I’m quite disappointed,first time I’ve used a teleconvertor,also used to the Canon 70-300L lens,I’m a wildlife photographer I use a canon 80d ,the hand held shots I’ve took on the canon lens are superb ,anyway on to the sigma,as I said I’ve just received it and took a lot shots but I’m really disappointed as most are not very sharp,so unless it’s a bad combination ,I don’t no I’ll have to play with it a bit see were it gets me.the lens itself us supposed to be sharp as I read reviews so,I’ll percivier,after all its 600mm anyway should be enough without the teleconverter.
briantilley
briantilley Veteran Member • Posts: 7,646
I wouldn't blame the lens (or the TC) just yet!
Going from 300mm focal length to 840mm (with the TC) is quite a jump.  Many people find that they need to tighten up their technique in order to get acceptable results.
By the way, this thread is more than two years old
 briantilley's gear list:briantilley's gear list
Nikon Df Nikon Z fc Nikon Z9 Nikon Z8 Voigtlander 35mm F1.2 Nokton +26 more
Mark B.
Mark B. Forum Pro • Posts: 30,068
Doesn't matter; 2 years on isn't going to change the fact that putting a TC on a long consumer-grade zoom is not going to result in very good IQ.
Cavig1 Contributing Member • Posts: 756
This combo will work better with a full frame, or almost full frame camera.  Since you will be focusing at F9 wide open.  This combo seems to work decently on my 1D IV  Not very well at all on the 70D or the 7Dii.   Despite using a Tamron 1.4x that doesn't report aperture.
As mentioned this lens has a learning curve and adding a 1.4X will slow AF and make it easier to lose the subject.  You'll need to spend some time perfecting your technique before you can reach an informed conclusion.
Good luck and good shooting.
Cavig
 Cavig1's gear list:Cavig1's gear list
Canon EOS 20D Canon EOS-1D Mark IV Canon EOS 70D Sony a6000 Sony a9 +7 more
I’ve since changed the Focus Distance Range to 10 and the images seem better although on a tripod and without the teleconverter but need to try same settings with teleconverter
at f6.3 f7.1 f8.0  with teleconverter it starts at f9 does that make a difference.
Thanks for the info,I’ve been out today changed settings on camera used the 600mm lens and got some perfect shots,so I thought I’d add the teleconverter,loads of shots of the chafinch got back not one any good so you might be right,so it seems like the lens alone is the answer,but 600mm is still good length,never had a teleconverter before so won’t miss it now.but I might keep trying .
rsn48 Veteran Member • Posts: 7,755
So I read a review written by a wildlife photographer and he likes the images he is getting with his long sigma and 1.4 TC.  I had another lens from Canon that had a reputation for being soft reported by many users.  And I was one of those users.
What I learned about me was that I wasn't using a fast enough shutter speed.  Shutter speed with long lens, especially with a TC added is critical for reasonable sharpness.  So on a hunch I look at the "Nesting Osprey" photo and it had a very low shutter speed guaranteed to produce soft images.
On a full frame camera with 1.4 TC, the minimum shutter speed should be 1/860 (or closest faster shutter speed).  If you are shooting with a Canon cropped camera plus 1.4 TC then your minimum speed shout be  1/1376 (or closest faster shutter speed).
When using this combo on my Canon full frame, I'd want a shutter speed around 1/1500 or faster and let my ISO float.
According to Manny Faber, there are "termite artists" who shoot in obscurity pursuing an inner vision others can't see (think Vivian Maier). And there are "white elephant artists" who shout out with technique and vision for all to see (think Ansel Adams). Which one you are doesn't matter, both have produced fine art.
