Coolpix 5700 dead pixel?
Started Jan 27, 2003 | Discussions
Hansplast26
Hansplast26 Senior Member • Posts: 1,247
I've experienced some strange pixel on my new 5700.
Sometimes I see a light purple pixel on a frame which was taken with a slow shutter time (e.g. inside in the evening). This pixel is at a certain fixed point. This pixel appears not often, but I know how to reproduce this 'problem'.
I've seen dead pixels on other camera's which appeared in all circumstances, but this is something odd. So is it a dead pixel, and if so, should I go back and how to convince the guys in the store that this sometimes-appearing-dead-pixel is a dead pixel?
Hans
 Hansplast26's gear list:Hansplast26's gear list
Leica Q
kccheng Regular Member • Posts: 278
Re: Coolpix 5700 dead pixel?
it is a hot pixel. showing up in long shutter. you can enable NR in camera setting for such siturations, or send it back to nikon to get it "mapped" out, or see the "4500 has a raw mode" thread to check out the home made software to MAP the pixel out.
map it out means to tell the camera to replace the problematic pixel with nearby pixel. so you will never see it again.
of course doing such operation on your beloved camera with a beta/alphar home made software is a bit risky. you can always wait longer for it to stableize. good news is some people are already getting good result in this software already.
Ka-Chun Cheng
Nikon 5K7
http://www.biblecrawler.com
Ron T Senior Member • Posts: 1,712
Hans,
Here is a link for free pixel test software.
http://www.starzen.com/imaging/deadpixeltest.htm
Ron T
Hans
Hansplast26
OP Hansplast26 Senior Member • Posts: 1,247
Thanks for your help sofar,
So I've a hot pixel, the software tool isn't a great help, i trust my own findings a bit more.
Currently this hotpixel doesn't annoy me at all, it only appears sometimes. I can be that it will annoy me in the near future and then I will certainly go back to the shop. Or when I am in an experimental mood, do it myself with the software mentioned in an earlier reply:)
Hans
Ron T wrote:
Hans,
Ron T
Hans
Leica Q
Terry Talton Junior Member • Posts: 42
I tried the CCD_Defect software...
that was brought up in the 4500 Raw Mode discussion on my 5700. I had a bright pink hot pixel that was showing up in all pictures at all speeds without NR.
The software said it found and mapped out 459 hot pixels which seemed a bit high to me but the one I was concerned about is definitely gone now.
I took a few test shots after remapping and it looks like it worked just fine. No hot or dead pixels and I can't see any artifact in the pictures where the pixel was.
Overall I'd say it worked beautifully.
IMHO, YMMV, CYA, BYOB, Enter at your own risk, etc...
Terry
Hansplast26
Re: I tried the CCD_Defect software...
I've not yet looked into this sofware, because the search functionality at this forum is currently unavailable. I am wondering if it is possible to give the x,y coordinate of the hot pixel manually, or is the software that sophicated that it thinks is able to detect the dead/hot pixels on its own?
Hans
Terry
Leica Q
The software maps them on it's own.
There is no way to manually specify location.
Austin_316 Senior Member • Posts: 1,932
Do you have to buy this or is it a download, do you...
Have a link? thanks tons!
Michael
Terry
Michael
Here it is...
http://e2500.narod.ru/ccd_defect.htm
The page is not in English but the utility is.
I used version V0.05
Here's a link to the thread where I found it:
http://forums.dpreview.com/forums/read.asp?forum=1007&message=4228226
Terry
nino Regular Member • Posts: 142
it works on a Nikon 4500
Had a hot pixel in my nikon 4500
It worked just great. Amazing.
I have put in my website a black picture before and after the remapping.
Just great.
Thanks to this guy
NN
I've seen things you people wouldn't believe.
Attack ships on fire off the shoulder of Orion.
I watched c-beams ... glitter in the dark near Tanhauser Gate.
All those ... moments will be lost ... in time, like tears ... in rain.
Time ... to die.
http://www.pbase.com/ninonino
RPK Senior Member • Posts: 1,104
Where do we find that home made pixel mapping software? My 5700 also has a dead pixel right in the middle of the frame, white hot.
This camera is headed back to OM for a replacement anyhow, no big deal BUT I would like to have the ability to map out the dead ones next time.
My 995 was plauged with dead pixels, had three different cameras.
The website listed is for the test, now where do we get the mapping software?
A simple test would be to take a frame wit the lens cap on. It will show you every little spot in the image. Nice black background too!
DaniR Forum Member • Posts: 60
Fine for my 4500 too
My 4500 has been fixed with this proggie too.
Cheers again for the programmer.
kitgard Senior Member • Posts: 1,067
Re: Fine for my 4500 too
in my cp4500 works fine TWO times
thx to the guy who make this possible
rgs.
cp4500, tc-e2
http://www.pbase.com/kitgard
baw Senior Member • Posts: 1,025
http://e2500.narod.ru/ccd_defect_e.htm
Here is the english version of the website with the Hotpixel removal software.
A brilliant trick of the programmer, he just uses a routine in the camera's firmware that maps out the hotpixels.
Make sure the camera has been off for some time (perhaps even cool it for a couple of hours) otherwise you will map out 512 pixels (the maximum table length)
After remapping my 5700 i took some lenscap tiff's and checked them with the deadpixeltest program. Only pixels with a luminance of 1 showed up. So my CCD is near perfect!
I have 276 removed hotpixels on my CCD.
Success
Ben
Nikon 5700 Sunpak MZ440AF
Marty Scher B Senior Member • Posts: 1,205
What version of firmware do you have?
Glad it had worked for you.
I have 1.0.
removal software.
Success
Ben
Re: What version of firmware do you have?
1.0 as well.
Success
Ben
xcutter Senior Member • Posts: 1,076
RPK
Why is the camera going back to OM? Is their a defect besides the hot pixel?
Rich B.
http://www.pbase.com/xcutter/galleries
CP5700, PS7
next time.
Hotpixel mapping success
It would be interesting to hear from other Nikon users how they did with the hotpixel remapping software.
Especially how many pixels were remapped after using this software, and how they achieved this (camera cooling etc.)
Success
Ben
Re: Hotpixel mapping success
Has anyone tried this with the 5700? Can you UN-map those bad pixels at some point? Meaning, is this a reversible process or?
