EF-M 15-45 extremely soft?
Started Jan 31, 2017 | Discussions
neb Junior Member • Posts: 35
I've found that the EF-M 15-45 kit lens with my M3 is much softer in all shots than my EF-M 22, especially at the edges. I know that the latter is meant to be sharper, but how noticeable should the difference be?
This result is very disappointing for me, as 15-45 is otherwise the perfect zoom range. I've found myself consistently using the entire range of focal lengths on the few shoots I've done with it.
Canon EF-M 15-45mm F3.5-6.3 IS STM Canon EOS M3
M02 Contributing Member • Posts: 603
Re: EF-M 15-45 extremely soft?
My copy of the 15-45, like yours, is very soft at the edges, until you stop down at least a couple of stops. It is the only EF-M lens that I have been disappointed with. All the others have been excellent. Some people like it though, so maybe there is copy variation. I recently acquired a 18-150 which I think is stunning for what it is, so you might consider that.
 M02's gear list:M02's gear list
Canon EOS 5D Canon EOS M Canon EOS M5 Canon EF 24mm f/2.8 Canon EF 50mm F1.4 USM +11 more
(unknown member) Senior Member • Posts: 2,153
I gotta ask, off topic, your equipment list, is current?
Amazing, an original 5D, and lenses of that era. Truth told, that's all you need is a couple good primes and a 5D and a good zoom or two.
On topic, yes the 15-45 is a bit soft on the corners. I believe the MTF charts reflect this. It's a compromise made for keeping the size/weight down it would appear. It is sharp in the center though, which is arguably where it counts.
4xdog Contributing Member • Posts: 556
I'm finding I like the EF-M 15-45 quite a bit. It's a fine walking-around lens with a useful combination of zoom range and lightweight, compact packaging.
Is it the sharpest lens I have? Probably not. Is it disappointingly soft? Not in the least!
Here's an image walking around the other day, (conveniently of a brick wall)! Jpeg out of the camera, no additional processing, stopped to f/5.6 at 35mm (56mm equiv FF). The overall image isn't hurt one bit by the corners. YMMV, but my EF-M 15-45mm f/3.5-6.3 STM IS does exactly what I want.
Canon EOS M5 + EF-M 15-45mm f/3.5-6.3 STM IS on South Grand Avenue, Saint Louis, January 2017
 4xdog's gear list:4xdog's gear list
Canon PowerShot SD870 IS Canon PowerShot S95 Canon G1 X II Canon EOS 5D Mark II Canon EOS M3 +12 more
rickysuper
rickysuper Regular Member • Posts: 103
I only use the EF-M 15-45 for video filming or panning mode shooting. As it was one of the only two lens that support Combine IS. 100US price (kit lens) was fine to me.
 rickysuper's gear list:rickysuper's gear list
Kodak DX3500 Canon EOS 50D Canon EOS M5 Canon EF 75-300mm f/4.0-5.6 III Tokina AT-X Pro 12-24mm f/4 (IF) DX +9 more
nnowak Veteran Member • Posts: 9,075
Yes, the corners on the 15-45mm can be pretty bad, especially at the wide end.  If you shoot RAW and process the images with Canon's DPP, you can greatly improve the corners by activating the DLO function in DPP.
Alan Sh Senior Member • Posts: 2,758
I've had two and one was sharper than the other at the edges. Both are fine at the centre and both clean up well with DLO
Can you post some samples of yours?
If you look here https://www.dropbox.com/sh/oqs0ja8vdtnftzg/AADGRq-4N08j5Nf2BWayHv6La?dl=0 you can see the tests I did with my two. How do they compare with yours for softness?
Alan
 Alan Sh's gear list:Alan Sh's gear list
Canon EF-M 55-200mm f/4.5-6.3 IS STM Panasonic Lumix DMC-ZS40 (TZ60) Canon EOS M100 Canon EOS M50 Fujifilm X-T5 +13 more
plantdoc Veteran Member • Posts: 4,339
Have not used this lens, but my M3 came with 18-55mm, which I have found to be quite good. Of course, not quite as compact and not as wide, but sharp pics. I am think about the 18-150mm, but waiting for more supplies and more reviews and maybe some deals. Amazing how this lens is so much smaller and lighter than the 18-135mm stm. I wonder if the QC with 18-150mm is better since 2 copies of the 18-135 stm I tried had noticeable decentering (soft along the left 20% of the frame in mid wide angle. This could easily be missed by taking some test pics at just 3- 4 FL.
Greg
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
Y'know, it can a funny (and often realistic) scenario...
...in that different copies of the same lens can perform radically different - go figure!
I like how the 15-45 performs (have it attached to my wife's M10) and when she shoots with it, we keep it at anywhere from f5.6 to f8 and we're getting some fairly sharp images for that genre of lens.  Of course, that's when shooting at ISO 800 and below.  Once you further up the ISO chain, then things start to show up, IMO.
And let's face it, whenever you compare a prime with a zoom lens (especially in this price range), you will be disappointed as the prime almost always wins out in the "sharp" department.
In addition, I almost always shoot in RAW mode, rather than in JPG mode.  But in getting back to my original remarks, reality shows us that copy to copy variations often can result in two of the same lenses performing quite differently with regards to optical sharpness, contrasts, etc.
Semper Fidelis...
Ben Herrmann
US Marine Corps (Retired)
North Carolina, USA
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
ScratchDisk Veteran Member • Posts: 3,803
Nice - I've been very impressed by my copy too.
 ScratchDisk's gear list:ScratchDisk's gear list
Canon EOS 5D Mark III Canon EOS M5 Canon EOS 90D
At the risk of coming across as a pixel peeping nerd, those corners are somewhat soft. But as long as you're happy, that's all that counts.
Abu Mahendra Veteran Member • Posts: 5,312
Extremely soft? No. Soft and lacking contrast in the corners wide open at the wider end? Yes. Softer than the M11-22? Yes
I've been shooting with the M15-45 for the last few weeks, and did a controlled test of corners and a comparo with better lenses in my thread Clash with the Titan .
Here are some images from this weekend, all at the lens's worst (but most interesting for me) setting of wide open at 15mm. Keep in mind the relatively high ISO when assessing softness.
>> I'm already lovin' my Canon 35IS lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
Is it the sharpest lens I have? Probably not. Is it disappointingly soft? Not in the least!...
No arguments about corner sharpness at all, M02. But I guess as a (now) old guy who's shot thousands of images as a kid when I couldn't afford top quality glass, I've settled into a way of looking at photos that studiously avoids pixel peeping. (smile).
I was playing with in-camera monochrome settings on the M5 the other day, and I can almost get the look of my old Plus-X Pan images right out of the camera. The compact size of the M5 + EF-M 15-45mm makes me smile as I walk through old areas of town looking at things through the viewfinder. It's all about having fun with the hobby, and the M5 is doin' it for me right now.
Here's one of those "filmy" far-less-than-perfect images from the M5. Nothing special at all, but the image looks like I wanted.
MannyV
MannyV Senior Member • Posts: 1,055
I had the same initial impression as you about this lens while testing this lens. Yet slowly but surely, this lens has become my goto lens on EOS-M5. In my day to day practical shooting, I find the lens produces images with excellent colours, and contrast, and decent sharpness. Way more than sufficient for my needs. Below two images captured with this lens recently. I have stopped to F8 intentionally here to get the DOF required for this landscape scene.
Lovely landscapes, MannyV.  There's some weird stuff going on in the full-size view -- almost posterized in some areas.  Did you do a lot of post on them?
MannyV
I have no idea whats going on. Yes I do post process. I shoot raw and in post process, correct lens profile, sharpness, boost saturation in lightroom. Also usually low size JPG's for internet
and first one is high ISO at 6400. I was shooting early morning without tripod. I hate lugging tripods
How do you like lugging IS around?
MannyV
I love IS as it helps. I meant I hate lugging tripods around.
OP neb Junior Member • Posts: 35
Obligatory brick wall. First is the 15-45, second is the 22.
EF-M 15-45
EF-M 22
Alan
What happens if you shoot but put the aperture to F8?
Alan
