Upgrade to E-P5 or E-M10 mk II or GX80/85 or something else?
Started Jan 30, 2017 | Discussions
OP Elmokki Regular Member • Posts: 276
Re: Upgrade to E-P5 or E-M10 mk II or GX80/85 or something else?
Oh, I lived under the impression that the 0 sec anti shock completely cures the problem, but if it disables sequential shooting that's really a shame! Even more reason to try sell my VF-4 and get E-M10mk2 or GX80. Thanks!
 Elmokki's gear list:Elmokki's gear list
Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 12-35mm F2.8 +3 more
Davud
Davud Regular Member • Posts: 238
I have the E-P5 as my second camera and for me, the only reason I'd consider E-M10 II (if it were available at the time), would be for the touch-pad AF control. Not the EVF, flash, or video.
 Davud's gear list:Davud's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +2 more
addlightness Veteran Member • Posts: 3,641
Re: Upgrade (Question for addlightness)
vallecano wrote:
I have an E-M10 and am considering an upgrade to a PEN-F. I am puzzled over your statement “I do miss the lightweight and smallish size of my EM10”. I do not have access to a PEN-F but did compare the physical size/weight and the difference is minimal. Can you explain why it is feels smaller?
Looking strictly at the specs,
  • EM10: 119 x 82 x 46 @ 396g
  • PEN-F: 125 x 72 x 37 @ 427g
the PEN-F measures smaller, volume-wise.  However ergonomically, when the camera is in your hand, the EM10's flash-hump and protruded eye-piece kind of disappear and the body feels and handles smaller.
Your hand will also feel the ~30g difference because of lack of (front) grip on the PEN-F - I have to add a half-case-grip:
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
vallecano wrote:
I have an E-M10 and am considering an upgrade to a PEN-F...
It's worth every penny the upgrade
And to repeat, I do miss my EM10 and I won't have sold it if I didn't need the GX85 for 8mp still grabs from 4K burst video - my kids' high school swim meets and basketball games.
BG28
BG28 Contributing Member • Posts: 612
I have an E-P5 currently, and I can't really make a good argument to myself (or my wife!) on replacing it with anything but an EM-1 mk2, which is too much camera for me. The EM-10-2 or PEN-F don't seem to have anything that much more capable or different than an EP-5. There's a few things that are slightly better, like maybe IQ or the increased resolution of the Pen-F, but not enough to suck the money out of my wallet. The 'Live Composite' feature is the only thing I feel like I'm missing out on.
Also, I've really gotten used to having a tilting VF. I know that's a small thing, but I use that capability a lot! Is that weird? Also, Having a removable VF is nice because an EP-5 with a 20/1.7 is definitely pocketable, though as others have noted the EM-10-2 is a pretty small camera. I've never held a GX80 but it looks pretty small, too.
I think if you have/use a larger lens regularly (something larger than 12-40 pro), you might go with something other than an E-P5.
 BG28's gear list:BG28's gear list
Olympus PEN E-P5 Olympus E-M5 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH +2 more
vallecano Contributing Member • Posts: 770
Thanks for this info which is helpful.
Earl
Madrid
 vallecano's gear list:vallecano's gear list
Olympus OM-D E-M10 Olympus 12-40mm F2.8 Pro Samyang 12mm F2.0 NCS CS Panasonic Lumix G 25mm F1.7 ASPH +1 more
maltmoose Veteran Member • Posts: 3,051
0 sec anti shock does fix shutter shock on the e-p5. It does not disable sequential shooting at all.
You should also note that 0 sec setting only operates 1/320 or less, above that it isnt used or needed.
So you can happily use sequential shooting with a setting of greater than 1/320 and be worry free about any shutter shock. imo if shooting sequential its for action and would use a higher speed than 1/320. so reality is that its not an issue for me atleast.
Also worth noting that theres an additional setting of 1/8 sec in sequential mode if you need it for less than 1/320. its hidden in the menus but to be honest i never used it. just set higher than 1/320 sec shutter.
Also worth noting that the evf on the gx85 is poor compared to the vf-4. I went to buy the gx85 as an upgrade myself but just didnt like the evf.
If it comes down to image quality all these cameras are all in the same ball park, so unless theres a feature you really need, maybe stick with what you got and save up for the next level up.
Next level up for consideration is pen f/g80/a6300/xt20
Well, considering I have E-PL6, which isn't clear from my first post now that I re-read it, these cameras all are a level up for me already, aren't they?
I know the EVF on GX80 can't match VF4. I'm pretty sure neither can the one on E-M10 mark II. That said, the only cameras that are upgrades that it fits are E-M1, E-M5 and E-P5 and it feels a bit pointless on two of those since they have built in EVFs. I rarely enough use EVF already since it's bit of a hassle to put it on so I don't think I'd miss it too much.
I'm also not considering non-MFT cameras. I have enough lenses that changing the system does not feel like it's worth it.
AznJunkie Regular Member • Posts: 156
It’s only an upgrade if you’re needing the extra features that the other cameras offers. If the E-PL6 is lacking feature(s) you need then it would make sense to upgrade to a new camera that has the feature(s). I mainly take photos of my baby (now toddler). I started out with a E-PL6 and I got a major case of GAS and went crazy buying camera bodies and lens. I used the VF-4 on the E-PL6 and really liked it. Then I bought a M10 Mark I since I wanted the EVF to be built-in instead of an add-on. Then I bought a M5 Mark II on Cyber Monday and just recently picked up a Panasonic GX85 for a great price. So in a 1 year time frame, I tried 4 different cameras. Right now I still have the Panasonic GX85 and the Olympus M5 Mark II.
With all those cameras, IMO, the image quality look very similar. I use JPEG out of camera and I don’t use RAW. Most of those pictures get saved onto the PC or ends up on Facebook. What sets each camera a part are the features. So you need to ask yourself do you want or need those features.
The EVF on the Olympus cameras are much better than the one on the GX85(GX80). I can’t use the EVF too long on the GX85 as it will give me a headache. Since you don’t use the EVF too often that shouldn’t be an issue. The body is slightly larger than the E-PL6 but it feel better in the hand (to me).
As IBIS, all of those cameras will be much better than the E-PL6. The GX85 isn’t as good as the M5 Mark II on the long lenses but it great for videos.
As I said earlier what is it that you’re needing/wanting that the E-PL6 can’t fulfill? I’m really like the GX85 right now and I do find myself using the GX85 more than the M5 Mark II for some reason.
 AznJunkie's gear list:AznJunkie's gear list
Sony a7 III Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 50mm F1.8 Sony FE 200-600 F5.6-6.3 Tamron 28-200mm F2.8-5.6 +3 more
NoTx Senior Member • Posts: 2,071
So just to clarify: the VF-4 is the best viewfinder in MFT. PEOD. You do give up when you select a different body. You are gaining handling and integration with any of the cameras you are discussing.
I am still stuck trying to decide bodies myself. Same situation (E-PL5 + VF-4). Mine is further impacted by my glasses and my current lens choice. The Panasonic bodies focus my favorite lens much slower (43 14-54mm Mk II). On any of the Olympus bodies it is a rapid focus as a contrast detect lens. Now, I love this lens, so I wanted to compare the viewfinder and the focus speed. The bodies I used for testing were: E-M10.2, E-M5.2, GX85 and G85.
Viewfinder comparison to VF-4. E-M10.2 and E-M5.2 are not as bright and do not have enough eye relief so the corners are clipped off when using the viewfinder built into the camera with my glasses on though I do wear my glasses fairly far far off my eyes. The GX85 was no where near as bright and clear, and kinda looks funny (camcorder feeling). It was however visibly easier to see corner to corner without moving the camera. The G85 had a nice and bright, though still weird looking (camcorder look) but was very image centric and nice. It was notably the best for wearing glasses, however the information was very… non-distinct as everything was displayed in white (can this be changed). Its nice but makes it less noticeable when you may have information you need but nicely focuses you on the image.
Handling comparison. In hand handling, the G85 was the nicest grip, the E-M10.2 actually had the nicest controls, followed by the G85 and E-M5.2. All of them are a major step up from the E-PL5 (E-PL6 is basically identical).
In focus speed with the old Oly 14-54mm Mk II, in the indoors store test? The speed difference was insane. The E-M10.2 and E-M5.2 were very, very fast. The E-PL5 is actually about like the old Contax G series cameras r the old 50/2 Macro on an E-1. The G85 and GX85… were significantly slower. Like count to one almost two between focus.
This is completely a store shelves demo test of cameras I had available that should be on my list. The problem is… I was disappointed in the absolute most important part of the Olys to me: the viewfinder.
No E-M1, but with the viewfinder issue… kinda sucks.
Rob aka NoTx...
-Always searching
 NoTx's gear list:NoTx's gear list
Panasonic Lumix DC-G9 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +5 more
I completely recognize that the sensor on E-PL6 is pretty close to as good as you can get in an MFT body. In fact I'd probably be happy with a worse sensor if I hadn't used this one. I'm really not expecting a bump in image quality but a bump in features.
Then again I did already joke to my girlfriend that if I'm buying whatever I'm planning to buy now, I'm probably buying an E-M1mk2 next year. I truly hope it really was a joke and not a self-told prophecy.
The thing is:
- The 5-axis stabilization has been hyped so much that I really want to see if it is as good as it sounds like. Even one more stop over the really basic 2-axis stabilization in my E-PL6 would be quite useful occasionally, but I am expecting two at least, which would be amazing.
- E-PL6 has just one control dial. This has been passable in aperture or shutter priority, but in manual mode when I occasionally play around with remote triggering a flash it's pretty annoying. That said, being able to tweak exposure compensation more easily might be nice for A and S modes too.
- Having mentioned flashes, I use the tiny flash that came with my camera to optically trigger an off camera flash that's bigger than my camera. It's somewhat annoying to fool around with a separate flash for this, though it's still a very minor issue.
- The viewfinder. I rarely use my VF-4 now. I keep wondering if I'd simply use a VF, even an inferior one, more just because it'd be always ready. VF-4 is a nice viewfinder, but it's also a huge extruding piece of plastic on top of a tiny E-PL6. It's not something I like to keep on the camera unless I know I need it. Then again wearing glasses seems to be a real problem for using a viewfinder in the first place. VF-4 feels much better without glasses, but I have fairly strong astigmatism in both of my eyes and that's not something the diopter setting can compensate for.
There are also minor other features I'm excited to try. Focus bracketing sounds great and apparently GX80/85 has focus stacking, which sounds even better. There are some other things like WiFi too, which I've slowly began to yearn for.
I wouldn't even discount video completely. I actually did video a friends wedding once. She did know my lack of skill and the general lack of equipment and I think she had sufficiently low expectation that she was positively surprised. However, I am still annoyed by the results myself. Just 60fps and proper IBIS during video would've made it look much better. The image quality was also adequate at best. I suppose some of the washed out colors might've been fixable in post, but I had even less idea on how to edit video then than I do now.
But, having written all that, I'm pretty sure some of the hunger for features I listed above is simply GAS.
Oh, I know VF-4 is the best.
Is VF-4 perfect for you with glasses? I, too, have glasses and I cannot see all the corners at once even with VF-4. It's also a bit annoying to center the viewfinder on your eye on a flat glass surface compared to putting it on your eye without glasses. I guess I could get contact lenses, but I'm really not going to do that for a camera.
This is one of the reasons I kind of want to sell my VF-4 and move to an integrated EVF. All it needs to be is good enough for the occasional shot and I figured that since using glasses clips the corners off slightly from VF-4, maybe a smaller magnification EVF wouldn't be that bad. Additionally, of course, the VF-4 is a big plastic clump on top of a fairly small camera. It's pretty unwieldy.
If you can, go out and see if you can hold each of the camera. That could dictate which camera you should go with. I thought they would feel the same but that’s not the case. The M10 Mark 1 felt too small and I had to use the optional grip. The M5 Mark II feels fine and felt off with the Fotodiox grip. The GX85 felt good but I had to adjust my grip to use the shutter button.
The IBIS does indeed make a difference on static subject (in low light or lower ISO) or if you have shaky hands. IBIS with electronic shutter can produce some very sharp picture. Another big benefit is when using long telephoto lens. It helps stabilize the image in the viewfinder which helps a lot with composing the picture.
I agree completely with the single control dial. Have dual control dial is great.
As for the VF-4 viewfinder, I didn’t feel it was better than the M10 or the M5 Mark II. I wear contacts and I can see corner to corner without any issues. I find myself using the Viewfinder a lot more when it was built in. Like you I felt the VF-4 was big and out of place. The GX85 viewfinder is like looking through a cheap telescope. It’s hard to find a good eye relief with everything nice and sharp.
The video is better on the GX85. People complain about the 1080P on the GX85 but I thought it was much better than the Olympus 1080P. I honestly feel you can’t go wrong with the M10 Mark II or the GX85.
rz350 Regular Member • Posts: 293
Never said that. You have to make a choice. If you want the diamond setting (fix shutter shock), you have to set it to that and it is single shot. If you set it sequential, you don't get the delay for shutter shock relief. Because shutter speeds for me bounce around a lot, I leave it on the diamond setting. I have other cameras which focus far better in action settings or fast moving situations.
There are additional settings beyond 1/8 sec, but regardless, it is a flawed camera and as long as you know about it's flaws, and are able to work around them, it is a very good camera. One thing though is that touch screen system and menus are superior on any Panasonic. The super menu is not an equivalent.
