Panasonic lenses on Pen-F ?
Started Jan 29, 2017 | Discussions
PhotoBunny
PhotoBunny Regular Member • Posts: 230
Hi, I have some old M43 Panasonic lenses from previous cameras:
  • f/1.7 20mm (a prime I really like)
  • f/3.5-5.6 12-32mm (useful little travel pancake zoom)
  • f/4.0-5.6 45-150mm ASPH OIS (useful, but not essential)
I am thinking of getting an Olympus Pen-F, would these lenses work fully with it?
- PhotoBunny
www.photoIR.net
gary0319
gary0319 Forum Pro • Posts: 10,540
Re: Panasonic lenses on Pen-F ?
I have the Pen F and use the Panny 12-32 and small 35-100, as well as the 14,2.5 and the PanLeica 100-400 without hesitation. All work great.
I'd not be too concerned about it, unless someone can cite specific lenses that at problematic.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
BruceRH Veteran Member • Posts: 3,087
I use the 12-32mm quite a bit on my Pen-F, the 20mm once in a while. Both work great and make a very nice walk around kit.
 BruceRH's gear list:BruceRH's gear list
Sony RX100 III Ricoh GR III Leica Q2 Olympus TG-6 Olympus PEN-F +44 more
Skeeterbytes Forum Pro • Posts: 23,186
No technical traps, so feel free to bring them along with the body swap. You'll have to decide which IS--lens or body--to use with the OIS lens(es). Generally, IBIS will be more effective until you get out to longer focal lengths.
Rick
SkiHound Veteran Member • Posts: 3,939
I use several Panasonic lenses on Olympus bodies, including the 12-32 which I like well. I'm not aware of anyway to use manual focus with that lens on an Olympus body, since there is no MF ring. Some Panasonic lenses seem more prone to purple flare on Olympus bodies (7-14 f/4 seemed especially so) but you shouldn't have any real issues.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Yes, no problems, except that no manual focus available for the 12-32mm on Olympus. Some say the AF on the 20mm is a bit slow and not so good in low light - but that's maybe much the same with Panasonic bodies anyway.
The 45-150mm will work well, but if you decide to use the lens OIS then you need to leave IBIS on as the master switch and then turn On Lens IS Priority in the custom menus. The advantage of OIS is a constant stabilisation in live view without needing half press, the difference is no roll correction and only about 2 to 3 stops stabilisation with Mega OIS, if staying with IBIS only then the usual up to maybe 5 stops slower shutter speed is possible.
I have the 12-32mm and the 45-150mm and on Oly E-PL5 I use the OIS, but on Oly E-P5 I use only the IBIS.
With IBIS plus 0 sec anti-shock or using fully electronic shutter the results will be OK with the Pen-F, you will have a nice light and small kit to carry.
Regards..... Guy
