GX7 panasonic - yellow exclamation mark on shut down
Started Jan 28, 2017 | Discussions
rjd1969
rjd1969 New Member • Posts: 21
Hi All
looking for some help. When i switch off my GX7 theres a yellow exclamation mark,
Everything else works fine though.
Understand it may be because I checked how many shots have been taken.
Any feedback appreciated,
Cheers!
Panasonic Lumix DMC-GX7
gopacic New Member • Posts: 4
Re: GX7 panasonic - yellow exclamation mark on shut down
I have yellow mark on shutdown on my LX100. I have unlocked 30fps 4k video recording, after that there is yellow mark on it because "30fps law" is in America, for EU is 24fps 4k video. My LX100 is from EU region so I think it's for that.
 gopacic's gear list:gopacic's gear list
Panasonic LX100
dholt Regular Member • Posts: 145
You might get more responses over in the Micro Four Thirds Talk forum since the GX7 is a micro 4/3 camera.
rjd1969
OP rjd1969 New Member • Posts: 21
agreed - didnt know how to delete or transfer this post/ thread tho!
rjd1969
found out and now sorted. you need to reinitialize your camera to revert back to the lumix outro rather tha the exclamation mark. a service manual is needed to identify the necessary keystrokes.
DanMen New Member • Posts: 1
Hi,
I own a G85 Lumix and I love it, at one point I needed to know the shutter count, I managed to get it but after this, I got stuck with the yellow warning (!).
I have searched quite a lot for a way to cancel it. Here is what I found and it did work for me as I now have the Lumix logo whenever I turn off the camera.
Warning: it returns your camera to factory settings, so you will loose all saved settings and have to redo them (set time, date, custom settings, etc).
You may want to try it at your own will. Again, this is what I did on my Lumix G85, it may not be the same on other models.
  •  Turn camera on
  •  Set mode to P (program)
  •  Press and hold Menu set and WB (right arrow)while turning off
  • Press DISP, WB (right arrow) and again WB (right arrow)
  • The Lumix logo should appear instead of the yellow (!) warning.
You will have to set time, date, etc.
Hope that helps.
