Zuiko 9-18 v. Lumix 14 + Converter v. Zuiko 12 for a city shooter
Started Jan 27, 2017 | Questions
MCMCNYC New Member • Posts: 14
Salutations, everyone,
Long-time lurker, first-time inquirer. Before we get started, I actually want to thank all you wonderful people for helping me pick a GM5 over a GX85, a decision that will hopefully reveal a bit of what I am looking for in a second lens.
I live in New York, I love shooting architecture, and I even feel a bit like my eyes just "look" wide, like when I've got the 35mm on my wife's D5500, which is supposed to be standard human site, right, well, I always find the FOV is too narrow. I bought my camera to basically be in my briefcase at all times, so that it might help me share what a marvelous world we live in with everyone else.
I picked up a great Sigma 30mm for $100 at B&H to go with my camera, because it didn't come with a lens, just a lightly used body. But now I'm in the market for the lens I really want, and I was hoping you all could help.
Quantitatively, I understand the fixed lens will have better IQ than the zoom. I really don't want to carry more than two lens, though, the 30 and a wide-angle something. I like the idea of the versatility of the 9-18. That said, true to some prior discussions, I wonder if wouldn't be happier with a better lens than the Sigma, like the 25/1.4, since some of my night shots are indeed noisier than I'd like.
In short, will I be grateful I have the reach/versatility of the 9-18, or will I be happier with the 12, or maybe the 14, which with an adapter is about as big as the 12, and gives me some of that added versatility. And as I mentioned, these are briefcase lens, so not really considering the 7-14s, unless you guys can really convince me. Also, is there another set up I'm totally forgetting and should consider.
Hope I haven't gone on too long. Just love the spirited debates around here, so I really wanted to give it my all.
Thanks, and happy shooting.
Skeeterbytes Forum Pro • Posts: 23,186
Re: Zuiko 9-18 v. Lumix 14 + Converter v. Zuiko 12 for a city shooter
I can say the mZD 12 spends a lot of time on my GM5 as a fast, do-all wide prime. Confess I don't know anything about the Panny 14 but I'd rather have the 15/1.7, which looks to be super sharp while significantly faster. The 9-18 is a very good UWA zoom for the money but will be rather large on the GM5 and quite a bit slower than the 12. 9mm is a lot wider than 12mm so the choice probably revolves around how much WA shooting you anticipate.
Good luck!
Rick
FaFik
FaFik Regular Member • Posts: 147
You may also want to consider Panasonic 12-32. Yes, it's slower than both mZuiko 12mm and Lumix 14mm, but unlike them it has OIS, which on a body without IBIS may prove more important than a step or two wider aperture.
 FaFik's gear list:FaFik's gear list
Panasonic Lumix DMC-G3 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital 45mm F1.8 +5 more
Almagest Contributing Member • Posts: 561
I can't answer your question, but I do have a suggestion.
Get a Panasonic 12-32mm lens, it was made for the GM series. B&H might even have some used ones.
Use the 12-32mm for a month or so and then go through all your images to determine what focal length you use most. After that, get a lens that is closest to that focal length.
As the GM5 has no IBIS, and the lenses you mentioned have no IS. This may not be important to you, but it's something to consider. If you find the 12-32mm to your liking than you should upgrade to the 12-35mm f2.8, even broad daylight those NYC canyons can be quite dark.
Warren
Fredrik Glckner Veteran Member • Posts: 3,894
I would get the Lumix G 12-32mm f/3.5-5.6:
http://m43photo.blogspot.com/2014/04/lumix-g-12-32mm-f35-56-review-small-and.html
It is small, very good optically, and fun to use. Given the size, you should not stand out as a "pro photographer", if stealth is important to your street style.
Albert Valentino Veteran Member • Posts: 9,770
The 12-32 sounds like a good option for that size body. For a small, fast, superwide lens them wait a few months for the upcoming Laowa 7.5mm f/2 lens. It is a manual focus lens which is very tiny. I would expect it to ship around the beginning of the next quarter. These lenses are ideal for that body.
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
PSCL1 Veteran Member • Posts: 3,770
To the OP:  The 12-32 for the GM1 is so tiny, versatile, and sharp for the money that it would be my first choice (Note:  I also own the Sigma and like it very much on a very old Panasonic G3 body).
I own and use the Panasonic 14 f2.5,  I believe it is the shallowest prime in m43.  It is WAY smaller than the Olympus 15 f1.7 which some are recommending.
I own and use the 9-18 Zuiko.  While not a "pancake" lens, it is collapsible and relatively small for what it does.  I use it a lot as a travel lens because I find 12 is not wide enough.  I think its current $600 price is a little high but........
Olympus makes two "body cap" lenses,  lens caps with lenses in them.  No focusing ring but there is a tiny stop down lever to give you some control of depth of field.  The 15mm f8 is about $50 new and a 9mm f8 fisheye is $75-$100, new prices.  The 15 is surprisingly good in full sunlight.  These are definitely the smallest, no matter what anyone else tells you, flush with the camera body.
However, my favorite small lens is the Panasonic 20mm f1.7.  It is criticized for its slow AF but it has Summicron-like qualities.  Based on nothing, I speculate that Leica helped design this lens since there are a number of Leica-Panny m43 lenses
 PSCL1's gear list:PSCL1's gear list
Leica X1 Nikon D80 Olympus PEN E-PL1 Panasonic Lumix DMC-G3 Sony Alpha NEX-3N +27 more
Saxton Regular Member • Posts: 127
From this description I can't tell exactly how wide you want to go. Is a 28-30mm equivalent still too narrow? The 14 and 15 are both good lenses with different selling points. But if you don't need a real UWA the 12-32 is probably the best all around option.
OP MCMCNYC New Member • Posts: 14
Warren
Thanks all for the suggestions. The idea of using the 12-32 to figure out my "ideal" length is an interesting one. That said, the point about the 12-35 highlights what I'm really after.
Part of the reason I got the GM5 was to always have it with me, along with one, maybe two lens. The 9-18 is barely half an inch larger than many Sigma prime, whereas the 12-35 and the like are half an inch wider and twice as long as the lens I'm considering.
So leaving aside the 12-32 for now, any other suggestions/experience from folks? Size and weight are definitely as much of  consideration as performance — otherwise I would have just gotten the GX85.
Will the output of the 12 or the 14/11 wow me so much I won't miss the flexibility of the 9-18? Another data point: Our Nikon kit includes the 18-140 3.5-5.6, and I definitely wish it was wider, and perhaps faster, but that's usually when I'm taking more cropped shots with a tight DOF. Not trying to sound like I've made up my mind on the 9-18, I really haven't, its that I haven't played with any of these lenses yet, so I'm not sure costs and benefits.
Two other things to consider: I think I've got a line on a 9-18 for about $350, and the lack of IS on the Sigma hasn't been a huge issue for me so far, even for some night time shots around the Barclays Center.
btwango Contributing Member • Posts: 538
Almagest wrote:
......and then go through all your images to determine what focal length you use most.
ExposurePlot
The 12 will surely outperform the 9-18 and at 2+ stops faster. A crazy/fun UWA option is the Oly 9mm BCL, which would give the smallest possible pairing with the GM5.
I have and use the 12-32 but prefer primes when willing to bother with lens swaps.
Rick.
btwango wrote:
ExposurePlot
Thanks btwango,
I knew there was a piece of software that would do this, I just could not remember the name.
Warren
$350 for the 9-18 sounds like a great deal.
There's always the Samyang 7.5 FE too, depending on how you feel about defishing, if you don't want the wait and expense of the new Laowa.
addlightness Veteran Member • Posts: 3,641
My very first m43 prime lens was the 14/2.5 (bought used for ~$150).  I also bought a 0.76x wide converter to go with it.
My first zoom lens was the 9-18mm, very good IQ and superb for city portraits like NY.  I use it mostly @9mm.
The 14/2.5 goes very well with my GM1, even with the converter.  I like its warm color and its IQ is up there with many other prime at f2.5 - see lensrental review
For outdoors, I prefer the 9-18mm.  For lowlight/indoors, I find the 14/2.5 (being 1.3 stops faster) more suited.
FWIW, I prefer primes and only take the 9-18 when I need the 9mm.  The 14/2.5 + 0.76x converter is only a 10.6mm/2.5, not as wide as 9mm.  Waiting for a 8/9mm f2.5 or f2.8 rectilinear prime.
GM1 + 14/2.5 + 0.76x converter
GM1 + 14/2.5
EM10 + 9-18mm hand-held.  The 3-axis helps a lot.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
atomgr Forum Member • Posts: 90
After a couple of years with the 14mm I got the 15mm 1.7.
It is bigger and makes the camera a bit bulky but there is no comparison.
Especially if you do architecture. The pop and the sharpness helps in post.
You can get close results with the 14mm with a little post but they will never look the same.
If you use the Capture One you can get some more FV.
 atomgr's gear list:atomgr's gear list
Canon EOS 5D Mark III Olympus E-PL7 Panasonic Lumix DMC-GF7 Olympus E-M5 II Canon EF 70-200mm F2.8L IS II USM +9 more
