Okay, ladies and gentlemen, I've got my fire extinguisher handy, but let's generate light, not heat. I submit the following both to teach and to learn.
I didn't find it practical to do every possible permutation.
All were made under similar settings, ISO 200 with ambient light, ISO 400 with flash, f5.6, 60mm lens on an Oly E-M1 (Mark I). There is the little on-camera flash, the trigger, set at "0" but it still flashes enough to give the little fellow an eye-highlight.
Camera-left is an FL-50R, about even with the bear, and pointed variably into a back wall/ceiling corner of the room (fore-lighting) or a front corner of the room (backlighting). Camera right is an FL-600R, positioned as the FL-50R.
The ambient light exposures varied, and were all longer than 1/6 second, so ambient light is almost irrelevant in the flash exposures, all at 1/125. I'm pretty sure that the flashes never went anywhere close to full power; it didn't sound like it, and I've examined some of the exif files and they show far, far less than maximal output.
I have used the RAW files to make smaller but otherwise unmodified max-quality JPEGs. The files went through ACR and then PSE. WB adjusted in one photo (my error).
Every different lighting setup I exposed in evaluative, centre-weighted, and spot metering. The centre-weighted sometimes veered one way and sometimes the other, more often barely different from evaluative, so I'm generally omitting it below.
I've numbered the images from my own file-names.
First, we've got this humble-but-cute little teddy bear, and all he wants to do is spread a message of love.
464 -all-around incandescent ceiling lighting, evaluative-metering
466 -all-around incandescent ceiling lighting, spot-metered, so brighter foreground than with evaluative metering
This bear has a fairly shiny ribbon, and the tufts of "fur" are bright, so there's probably a wide range of tones in that creature.
463 -incandescent ceiling back-lighting, spot-metered, so the bear stays relatively bright, as it should, and the background brightens, as expected
468 -flash lighting, aimed behind the camera into the far walls/ceiling corners, so essentially diffused front-lighting -evaluative metering - both flashes on RC TTL at "0"
Would this brighten up by converting to spot-metering?
470 -same lighting as previous, but spot-metered -brightness essentially unchanged from evaluative metering
Let's try backlighting, aiming the two flashes into the corners in front of the lens, behind the bear.
474 -flash-lighting, aimed into the walls/ceiling corners behind the bear -spot metering -so: backlighting, essentially unchanged exposure from front-lighting -the bear has gone a bit darker than 470
All right, 'nuff foolin' around, let's make some adjustments. As many others seem to do, I generally start with the RC TTL exposures set a bit high - often as follows:
478 -flash, one RC flash at +0.7, the other at +0.3, diffused front-lighting, evaluative metering -bear still too dark and/or too little contrast
480 -same setup, except spot-metering - better than with evaluative metering, still dark and flat -it is brighter than the "TTL 0" image 470- but not as much as one would think from the settings
477 -flash, diffused back-lighting, +0.7 and +0.3 -only a trace brighter than the "TTL 0" 474
I didn't do it today but have on occasion tried higher than +0.7, all the way up to +1.7 and beyond, and sometimes when the flashes decide that they aren't going to do it, they just don't seem to want to do it. Bright backgrounds are harder.
Then, just when I thought I had at least some data to debate, I also altered the focussing algorithm. I did that because of a brain-slip. Nonetheless, to my amazement, as I went from "all-targets" focussing to "single-target" focussing, the image brightened up (what?!?) ... if I switched to a black background. This is from a different-but-similar series:
445 -flash, TTL +0.7 & +0.3, evaluative metering, all-targets focus -back-lit, so highly dependent on scattering of light hither and yon
(Yes, I'm sorry, I'm changing two variables.)
448 -flash, TTL +0.7 & +0.3, evaluative metering, single-target focus
And there, I got visually identical images with diffused front- or back-lighting.
So, two things from that:
- bright backgrounds do seem to be ("seem", not "are positively") a factor, and it's as if on RC TTL flash-mode, it's like plain, old-fashioned, full-frame, "dumb" auto-exposure;
- why changing from all-targets to single-target focussing should matter I have no idea, but the effect was dramatic.
Of course, even the brighter back-lit bear is probably no brighter -it just stands out better from a dark background.
It's complicated, but still I submit not as easy and transparent to use as ambient-light TTL. Again: RC TTL appears, to me, to behave like dumb full-frame metering - or worse.
No knocking anybody - just what I see.
Charles
