Canon EOS 760d - sensor issues resolved?!
Started Jan 23, 2017 | Discussions
mensreaTHR New Member • Posts: 6
Hello all
I am thinking about upgrading from my 550d to a 760d. However, while looking into that, I read on a few (mostly German) forums or reviews that the 760d has some sensor issues. One seemed to concern spots or points on the sensor. Canon seems to have addressed that issue successfully.
A second issue, however, appeared to point towards a design "flaw" in the sensors used which results in horizontal stripes in pictures. Canon claims this only happens when the pictures are edited heavily; yet reviewers claim it is visible in unedited or weakly edited pictures.
There is even a thread on here that brushed the question. I have, unfortunately, not found any information whether that is still a problem or if it was a problem at all.
Could any one of you point me in the direction of useful information in case it has been answered or resolved? Thanks in advance.
M.
 mensreaTHR's gear list:mensreaTHR's gear list
Canon EOS 550D Canon EF-S 18-135mm F3.5-5.6 IS Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM
Canon EOS 550D (EOS Rebel T2i / EOS Kiss X4) Canon EOS Rebel T6s (EOS 760D / EOS 8000D)
Stan in NH
Stan in NH Senior Member • Posts: 1,898
Re: Canon EOS 760d - sensor issues resolved?!
I've had my US version, the T6S, for a few months and have taken hundreds of shots with it.  I have not seen any artifacts with either unprocessed or processed pictures.  On my sample, the images are very clean with no indication of any sensor issues.
 Stan in NH's gear list:Stan in NH's gear list
Sony a6400 Sony a7R IV
Kaso Veteran Member • Posts: 4,488
Service Notice: Canon EOS Rebel T6s & T6i
Service Notice: Canon EOS 750D & 760D
Phenomenon
In some units of the models listed below, the following phenomenon may occur due to irregularities on an optical layer located in front of the image sensor:
White spots may exist on the optical layer which may result in the appearance of dark circular patterns on the captured image under certain shooting conditions.
Products
The phenomenon described above may occur in cameras whose first and second digits of the serial number are as set forth below.
Identification Procedure:
Serial Number: [XXnnnnnnnnnn]
EOS Rebel T6s: If “XX” is “01” or “02”, the phenomenon described above may occur.
EOS Rebel T6i: If “XX” is “01” or “02”, the phenomenon described above may occur. “n” represents any digit.
This was issued in May 2015 to address the problem observed in early-production units.
(I use a T6s.)
OP mensreaTHR New Member • Posts: 6
Thank you for the information. This refers to the circular patterns on the sensor. That seems to be resolved. What I was further interested in was the reports that you might get stripes in the pictures due to this supposed sensor flaw. Something to do with the two layers for AF.
But it seems that so far nobody here has encountered this problem. So I am not sure what I actually read or whether people were making stuff up.
Will keep my mind open, but the 760d seems to get closer.
M.
VirtualKev Forum Member • Posts: 73
I haven't noticed any issues with my 760D (that aren't a direct result of my own making/stupidity), and I'm into 1000's of images so far.
 VirtualKev's gear list:VirtualKev's gear list
Canon EOS Rebel T6s Canon EF-S 60mm f/2.8 Macro USM Canon EF 70-300mm f/4-5.6 IS USM Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +6 more
NYS photo
NYS photo Regular Member • Posts: 155
My T6s was bought in December of 2015, I have over 4k pictures taken now and have had zero issues with anything you have described.
 NYS photo's gear list:NYS photo's gear list
Canon EOS Rebel T6s Canon EF 75-300mm f/4.0-5.6 III Canon EF-S 18-135mm F3.5-5.6 IS STM Sigma 150-600mm F5-6.3 | C Canon EF 50mm F1.8 STM
jrkliny
jrkliny Veteran Member • Posts: 4,887
The sensor defects occurred with some of the initial Canon 760D units.  I thought Canon was really sloppy with their quality control and did a poor job of handling the recall.  Canon wanted the whole issue to vanish rather than acknowledge or explain the issue.
Anyway that issue was long since resolved.  In terms of an "upgrade" you might think twice.  You are not going to see much improvement in image quality or camera capabilities.  Unfortunately the rate of improvement in digital cameras seems to have all but halted.  The 760 series is likely to be replaced in the near future.  You might want to wait a bit longer to see what upgrades are coming.
 jrkliny's gear list:jrkliny's gear list
Canon EOS 90D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 55-250mm f/4-5.6 IS +6 more
Thanks for everyone's kind words. I did check again and found the report about stripes in the pictures on the German Amazon from last year. That's what made me unsure. However, I did not really find widespread evidence of this problem; only occasional mentions without any solution. So it seems it was either a fluke or maybe an older unit the reviewer had.
Concerning the upgrade: I was mostly impressed with the accurate AF when I tried the camera in the store. I really have the feeling it is way above my old 550d. But maybe you are right. The 760d is already 2 years old, a new model seems likely. Or maybe I will invest the money in better lenses instead.
photosen Veteran Member • Posts: 6,226
Given that this is the complaints department for Canon, it's a good sign that we haven't come across this...
M.
The best bokeh goes unnoticed, grasshopper.
 photosen's gear list:photosen's gear list
Canon EOS 30D Canon EOS 70D Canon EF 35mm F2.0 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +3 more
I am not quite sure what you are trying to say. But thank you.
ThePointblank Regular Member • Posts: 119
I would actually consider an upgrade to the Canon 80D instead, if your budget allows for it. Going from the 550D to the 760D isn't that much of an upgrade; going to the 80D makes more sense.
 ThePointblank's gear list:ThePointblank's gear list
Canon EOS R Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 100-400mm F4.5-5.6L IS II Canon EF 50mm F1.8 STM +1 more
totleytom Contributing Member • Posts: 564
There is an argument that says that when the new camera is released it will be expensive, but the remaining examples of the previous model might get cheaper.
I think we've reached the point when any DSLR is "good enough". There will always be a newer model to tempt us, but I think the differences between old and new are getting very small.
 totleytom's gear list:totleytom's gear list
Canon EOS 90D Canon EF 70-200mm F4L IS USM Canon EF 40mm f/2.8 STM Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Canon EF-S 24mm F2.8 STM
patticake Senior Member • Posts: 1,308
there's another reason to get the 760d over the 80d - the 80d is heavier than the 760d.
and for me, there are a couple reasons i prefer the t6i (760d) over the t5i - two control dials instead of one plus that handy top screen.  depending on how you shoot, that could make moving up worth doing.
 patticake's gear list:patticake's gear list
Olympus PEN E-PM2 Sony a6100 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +3 more
Stan in NH
I replaced my old 40D with a T6S, and chose it over the 80D.  The 80D is a superb APS-C camera, but I also wanted something smaller and lighter.  The price difference is not huge, but the T6S is a bit less.  I have been very pleased with the T6S overall, but the small battery can be a handicap on an otherwise excellent camera.  The 80D has much better battery life, which is a big advantage.  With the T6S, I won't go out with it at all unless I'm carrying two batteries.  For now, the T6S can do everything I want it to so, even with its relatively poor battery life,  it's not going anywhere.
SHood Veteran Member • Posts: 6,100
800D DPAF is coming next week
The 800D will have the latest sensor with DPAF. That could also be a viable alternative.
http://photorumors.com/2017/02/09/canon-eos-800d-pictures-and-specifications-leaked-online/
 SHood's gear list:SHood's gear list
Olympus E-M1 II OM-1 Olympus M.Zuiko 300mm F4 IS Pro Olympus 12-100mm F4.0 Olympus 17mm F1.2 Pro
Hello
thanks for the advice. I kind of followed it, but with the 70d. I looked around and also thought that 550d to 760d might not be the biggest step. So I looked further, found the 80d and saw it is outside my budget. But I found a used 70d from a photo studio that was rarely used even with the screen protection intact and the price was more than acceptable. So I went and bought it.
Now, however, I have to get used to the weight difference, which is significant. But it seems I am beyond the point-and-shoot holiday snaps. So so hopefully, it will work out fine.
Thanks to all who shared their insights.
M.
Congrats, excellent choice. You won't regret it.
Stan in NH
Fresh report on Canon forum
There is currently a thread on a Canon forum with a report of banding on a T6S that was purchased in December.  One of the responses quotes a Canon explanation that this is caused by low pixel density in the AF section of the sensor, and is only visible with very heavy processing.   So, it is apparently not a defect but rather a characteristic of the sensor.  I have done some heavy processing on a large variety of pictures, and I have not yet seen this effect.  The poster who started the thread posted two pictures which do not appear to have been heavily processed, so this one may actually be a defective sensor.
Kameratrollet Senior Member • Posts: 1,106
Re: Fresh report on Canon forum
http://community.usa.canon.com/t5/EOS-Rebel/Rebel-T6I-Sky-Banding/td-p/200363
http://www.photomacrography.net/forum/viewtopic.php?t=30169
http://www.exclusivearchitecture.com/?page_id=1332
About focus pixels in raw video https://www.magiclantern.fm/forum/index.php?PHPSESSID=m5gblvgvgbeoetubm4akiudh67&topic=16054.0
Stan in NH
I have now read quite a bit about this banding issue.  Although it appears to be part of the sensor design, not everyone has been able to replicate the problem  There are reported cases of this showing up in normal RAW or JPEG files, but most appear after heavy processing and/or stacking.  There may be two issues here ... one an actual production defect in the sensor, and the other an inherent design issue.
On my own T6S, I have been unable to produce any visible banding even after heavily post processing some sample pictures.
