Fuji S5 Pro with the Nikkor 24mm F2.8D
Started Jan 23, 2017 | Discussions
fPrime
fPrime Veteran Member • Posts: 3,727
13
Finding this combo to be a great, light, walk-around system. Color saturation and pop are so off the scale that I had to turn down the vibrance in Lightroom for both of these examples shot over the weekend.
Who says you can't do action with the S5 Pro? Natural light shot at f/2.8.
24mm may produce a 35mm equivalent FOV, but at f/2.8 the DOF is closer to that of a 35mm f/4 lens.
Hope you enjoy the old school Fuji colors.
fPrime
 fPrime's gear list:fPrime's gear list
Canon EOS 5D Fujifilm FinePix S5 Pro Leica M8 Nikon D60 Nikon D1X +3 more
fishy wishy
fishy wishy Veteran Member • Posts: 9,358
Re: Fuji S5 Pro with the Nikkor 24mm F2.8D
fPrime
Yes I do, but old school? When you discover them late they can be new school!
I went back to Fuji S pros after later Nikon cameras. An old CMOS camera nowadays tends to fall between the stools. It doesn't have the dynamic range or high iso of the newer cameras, and it may not have much of that old approach to color either. So I explored older CCD cameras like this. I tested m4/3 cameras quite recently, without being impressed. When I went back to browsing thumbnails from cameras like the S pros I was almost jumping up and down in my seat. The difference in color and tone curve is obvious, even from thumbnails.
But I have tested several s5 and I have seen a problem in all of them with grainy, almost mottled overcast skies when pulling the highlights. It's so tempting to pull those highlights and apply sharpening but one must be vigilant.
fPrime
OP fPrime Veteran Member • Posts: 3,727
fishy wishy wrote:
fPrime
Haha, true but saying the colors are "new school to me" just didn't sound right.
Indeed. My Nikon CCD bodies also have their own great color but clip easily. In that sense the Fuji S series is much more forgiving.
M4/3, I'm not surprised. I used to read comments on here from users who felt that even their modern APSC Fuji bodies didn't equal the color quality of their old S5 Pro bodies.
With which RAW converter, Fishy? I saw mottling in skies using DXO Opitcs Pro so dropped it for usage with the S5 but LR works beautifully for me.
fPrime
fishy wishy
fPrime
I started off using LR but it's not my thing and now I use Adobe Camera Raw. It's a long time since I used Fuji's own antiquated software, a clunky affair which looked like it came from the Windows 98 era. I looked around for the Fuji software they used to sell but only got an older version. The problem is most obvious  on 1:1 viewing and largely on overcast skies where the change in tone in areas is relatively subtle. I suppose I really should post a couple of samples.
It probably is something to do with the way Adobe has reverse-engineered the way to read Fuji files and the interpolation. This behaviour came from the files of 4 different bodies I tested with ACR and it's so blatant it's unlikely to be the sort of thing Fuji would let pass with their own converter.
fPrime
fishy wishy wrote:
fPrime
Interesting, you really should post an example so others can recognize the artifacts you are seeing when they occur.  You do keep Adobe's RAW sharpening in ACR turned off, I hope?  I've found sharpening on S5 Pro images is best left to more sophisticated deconvolution tools after conversion.
Adobe get rightly criticized for being slow to create profiles for some cameras and doing a mediocre job on others.  However, I can definitely tell that their profile for the S5 Pro got a lot of loving care from someone at Adobe... perhaps a fellow Fuji enthusiast themselves.  Colors, tone curves, and relatively artifact free interpolation to 12 MP are near perfect in LR and trumped the output from DXO and C1 Pro when I tested them head to head.  Like you, I wasn't able to test Fuji's orphaned RAW converter for lack of availability.
fPrime
jjz2 Veteran Member • Posts: 4,396
It's a nice combo on those year sensors for sure. I liked it on my D80, but the lens really started to show it's limitations once I stepped up to 24mp files, where I found even a newer kit zoom produced better results. You seem to still be fine with the older bodies, so yes it's a great walkaround for those.
I think color saturation WAS always pretty high due to nature of the lens, being designed for landscapes/film in the 70s.
 jjz2's gear list:jjz2's gear list
Nikon Z6 Nikon Z5 Nikon Z 24-70mm F4 Nikon Z 35mm F1.8 Nikon Z 85mm F1.8 +1 more
fPrime
Indeed. The 24D Is still highly regarded by Nikonistas for color and contrast today despite its slightly softer corners versus its 24G cousins. I also have a 24mm 1.4G but it has serious back focus issues on my S5 Pro so I reserve it for use on my full frame.
One thing for sure, the 24D is a small and light optic which makes the S5 extra easy to carry!
fPrime
MOD BobsYourUncle Veteran Member • Posts: 8,944
fPrime
Have you made prints from the combo? Sometimes the large prints look better than on screen......just my opinion, though.
Bob
 BobsYourUncle's gear list:BobsYourUncle's gear list
Fujifilm X-T30 Fujifilm GFX 50S II Fujifilm X-H2 Fujifilm GFX 100S Sony a1
knows_nothing
knows_nothing Regular Member • Posts: 219
I always wanted that lens, but could never find one at reasonable price. I did spend £60 on a used Sigma 24mm f2.8. The Sigma has great close focusing. The real party trick of the S5 pro was its dynamic range - with the right software. Only the Nik D3 got close got close. Using the software - the Raw highly recovery was amazing! See Ken Rockwell's Overexposure and Blown-Out Images http://www.kenrockwell.com/fuji/s5/dynamic-range.htm
 knows_nothing's gear list:knows_nothing's gear list
Canon EOS 5D Mark III Panasonic Lumix DMC-GX7 Fujifilm X-T1 Nikon D7000 Nikon D610 +4 more
fPrime
fPrime
I'm just now getting my preferred camera settings worked out so I have not printed from the S5 Pro yet.  But you do make an interesting suggestion about print quality.  I recall reading somewhere that someone said in prints the softness of the S5 Pro is mitigated and the tonality really shines.  Is that what you meant, Bob?
fPrime
fPrime
fPrime
That's not a bad way to put it.  The gradients in color seem to yield a more life-like print.  13 x 19 is my usual max print size for enlargements and I have been quite satisfied.  In my office/gallery the S5 prints get more "oohs" than others.  Let me know what you think about your prints when you get to that point.
Bob
fPrime
It's a great lens on DX even wide open as you saw.  You should get ahold of one to compare to the Sigma.  My used copy cost me $250 but it's well worth the rock solid AF compared to my focus troubles with the Nikon 24mm 1.4G.
fPrime
