All EM1-II and Panasonic 100-400 lens combination problems
Started Jan 21, 2017 | Discussions
Ezra Koper
Ezra Koper New Member • Posts: 2
Hello.
For the benefit of others i would like to note all the problems i found unfortunately by myself rather then anyone reporting it on YouTube.
1. EM1-II will not work in continues focus mode whenever the Lens range limiter switch is set to 5m-infinity. It will work OK when the range limiter is set to Infinity.
2. Pre Capture new feature highlighted so much by Olympus will also not work with Panasonic 100-400 lens. Thos options LPreCapture and HPreCapture will be left gray not allowing the user to select them. It will work only with Olympus lens as the 40-150 F2.8.
3. Not sure exactly how the IBIS and OIS work together , even that in general i had no notable issues.
Will appreciate other adding their own experience with the EM1-I and Panasonic 100-400 combination.
Olympus 40-150mm F2.8 Pro Panasonic Leica 100-400mm F4.0-6.3 ASPH
Harvey Melvin Richards Regular Member • Posts: 295
Re: All EM1-II and Panasonic 100-400 lens combination problems
The E-M1.2 manual states that Pro Capture only works with Olympus micro 4/3 lenses.
There have also been discussions about not using the focal limiter on the 100-400 when used with the E-M1.2.
 Harvey Melvin Richards's gear list:Harvey Melvin Richards's gear list
Olympus OM-D E-M10 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +9 more
drj3 Forum Pro • Posts: 12,634
Ezra Koper wrote:
Hello.
Lots of posts on this.  Don't use the lens focus limiter, the camera can set 3 different ones to the distances you want.  The camera one is much better than any lens implementation.
Again several posts.  Some find the OIS has a problem with panning and recommend IBIS for moving wildlife, but the OIS for stationary images.  The two do not work together.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
Rich K
Rich K Senior Member • Posts: 1,006
5
I was unaware that YouTube was the gold standard for reporting camera and lens problems.  I'll keep that in mind for the future ...
Rich in Reno
 Rich K's gear list:Rich K's gear list
Sony RX100 III Olympus PEN E-P5 Olympus E-M5 II Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic 12-35mm F2.8 +5 more
Namaste58
Namaste58 New Member • Posts: 11
Has anybody had this problem? I had purchased the 100-400from ebay to go with my Olympus m1 ii. Company from Korea. OEM box. Initially lens was tight fitting on cam. After the third use the seal was coming off lens. I than noticed the base was pulled a bit off lens. Two screws appeared to have loosened although they were still "tight." I sent lens back to Korea. They said I mishandled lens of which I did not. It is such an excellent lens and I really would like to repurchase it but am hesitant as I do not know if it was a lens problem or what. Any ideas?  I am very careful with my equipment and there is NO WAY I dropped it or such.. Ohhh, I did get my money back after having to escalate it to resolution center..
 Namaste58's gear list:Namaste58's gear list
Olympus Tough TG-4 Canon PowerShot G5 X Canon EOS-1D X Olympus E-M1 II Canon EF 50mm f/1.2L USM +12 more
goodbokeh
goodbokeh Senior Member • Posts: 1,535
My 100-400 is solid in fit and finish and your experience is the first I have read about such an assembly problem. I'm glad you got your money back and I recommend you purchase this lens again.
 goodbokeh's gear list:goodbokeh's gear list
Leica Q2 Leica M10 Monochrom Leica M10-R Fujifilm GFX 100S Sony a1 +2 more
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
My 100-400 is beautifully well put together and has been used daily for 6 months.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
HGFGKM Regular Member • Posts: 248
Does anybody know how will the 100-400 work with the GH5? Will IS of GH5 and the lens by synced?
 HGFGKM's gear list:HGFGKM's gear list
Sony RX100 Canon G1 X III Nikon D750 Sony a7R II Panasonic Lumix DMC-GX8 +8 more
Adrian Harris
drj3 wrote:
Ezra Koper wrote:
Hello.
I have a gx8 and 100-400, and also 100% agree with your statement above regarding IBIS and OIS not working well together for birding under certain circumstances, especially when the subject is at a great distance!  In fact my shots with the older gx7 which does not support Dual IS are sharper, but at 16mp less detailed. So am strongly considering trying to find the money for a EM1 mk2 if it solves the Panasonic Dual stabilisation 'soft image ' issue!
drj3
AussiePhil Contributing Member • Posts: 691
Ezra Koper wrote:
Hello.
Boo bloody hoo, doesn't anyone read anything in other threads
1. Has been fixed completely with firmware 1.1 for the lens, version 1.2 has also been released, so this is a non issue
2. RTFM.... and what feels like 100's of threads on dpr already. Should not have been a surprise
3. Also discussed in depth multiple times and they do not work together, OIS will override IBIS when turned on and for the most part is better
Cheers and best wishes
Phil
Galleries at
https://www.flickr.com/photos/byphilg/
 AussiePhil's gear list:AussiePhil's gear list
Olympus E-M1 Olympus OM-D E-M1X OM-1 OM System OM-5 Olympus 40-150mm F2.8 Pro +4 more
fft2000 Contributing Member • Posts: 987
AussiePhil wrote:
Ezra Koper wrote:
Hello.
Well, RTFDate ;). The OP is 2 months old, at that time there were no fixes for the limiter and no threads about cross-brand sync/dual-IS.
Phil
Galleries at
phil from seattle
phil from seattle Veteran Member • Posts: 3,699
I've have the PL100-400 for about 4 months now.  Lots of local shooting and carted it on a 6 day photo trip to south Florida (not exactly the ends of earth but it was a long haul for me). No problems at all, still feels very solid and no complaints on IQ.
 phil from seattle's gear list:phil from seattle's gear list
Olympus E-M1 II OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +2 more
Is there already a thread that discusses this issue? I think this is an important shortcoming and I probably would have decided against pure Panasonic if I had known before :/ Dual IS 2 was an important decision factor for me!
From my first day out I thought I wasn't affected with G81+100-400 (Dual IS 2). Unsharp images were caused by the strong wind. The next days I was disappointed because I produced too many soft shots from small birds in the tree about 20m away. After reading this statement I went ahead and did some testing. My finding: Dual IS works quite well for me for shutter speeds up to about 1/600s. FASTER shutter speeds cause trouble, I get softer images starting at 1/800s and mostly unsharp ones at 1/1300s. Of course this sometimes causes trouble with small nervous birds (tits...). The issues for started at a distance of about 15 meters.
I can get even better hitrates If I take photos while recording a video. Though I need to test this more. Today I will play with 4K-photo a little bit, probably it is the best solution.
One of the first images taken with the 100-400. Distance somewhere around 10m.
1/640s didn't cause an issue.
OOC jpeg with slightly adjusted settings. Taken while recording a video. I am really pleased with the result! Tree is about 20 meters away. Some test shots with 1/1300s were soft...
drj3
Adrian Harris
Speaking to photographers who use other brands, apparently their IS disables as the shutter speed increases.  Many well respected canon and Nikon bird photographers have informed me that they have IS switched off !
There is no doubt that the Dual IS works stunning for most camera uses, but it appears that birds at extreme distances with certain camera and lens combinationns (IE: gx8/100-400) isn't it's best scenario.
I wish Panasonic would provide a menu option to switch IS, so we could choose:
Dual ON.  OIS only,  IBIS only,  All OFF.
Namaste58
I'm starting to feel more comfortable purchasing again. It looks like I got an isolated case from the comments folks are making.  I really thought hard about the Oly 300 but at that range I need to have zoom as it's just too liming for my taste. Hey Phil...being you are in Seattle how is your experience in rain/light showers? I live in Eugene and as you know we have this to contend with in the Northwest....
phil from seattle
Only had it 4 months but so far it's been out on a few rainy days. No problems but I tend to baby my gear, even the weather sealed stuff. Force of habit from my Nikon days.
There is kind of a natural limiter as the PL100-400 is not super fast so those grey rainy days are challenging when you need 1/1000 second or faster. That said, when the light is good the small size makes it so easy to carry that I forget all about the grey "don't bother" days. When I was in Florida last week, I saw so many people with huge DSLR lenses. Monopods, tripods and advil, oh my!
