100d-sl1 and 500d question
Started Jan 17, 2017 | Discussions
with lots of gear but no idea Regular Member • Posts: 240
Whilst I generally take family and garden shots I also like to do BIF and Action for which I use a 500d with the 55/250 stm lens. Which is OK for me now. 'Had the 400mm and 300L but too heavy nowadays'. I want to get down to one Body by replacing the 500d and another smaller camera I use with the 100d. So my question is. Will the 100d be as fast as my old trusty  500d for my BIF and action? Thanks for any help.
 with lots of gear but no idea's gear list:with lots of gear but no idea's gear list
Canon EOS 500D Fujifilm X-E1 Fujifilm X-A2 Fujifilm XF 35mm F1.4 R Fujifilm XC 16-50mm F3.5-5.6 OIS +2 more
Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3) Canon EOS Rebel SL1 (EOS 100D)
Robin Empson Regular Member • Posts: 111
Re: 100d-sl1 and 500d question
The SL1 will do almost everything even better than the T1i. Better ISO, better IQ, faster. Here is a comparison for you.
http://snapsort.com/compare/Canon-Rebel-SL1-vs-Canon_EOS_Rebel_T1i/detailed
The 6d has been my main camera for a few years, while I searched for the "perfect" backup crop camera.
I did use the SL1 for wildlife and was pretty pleased with the performance. But sold it, as I seldom used it.  However, I recently picked up the T6i kit, with the 55-250 STM lens.  Took it out this past weekend to try it out.  Got eagles and birds in flight and was amazed at the results.  I wasn't expecting as much.  I have been the full frame route with the 100-400 L lens, only to find it difficult to handhold and too heavy for this grandma to lug around.
The newer Rebels are amazing.  The T6 series has a more advanced sensor and better AF system.  If you are considering a new camera, you might want to look at this.
jvc1 Senior Member • Posts: 2,202
I use an SL-1 as a 2nd body and when I kayak. I've noticed that even at 4 fps, if I'm shooting RAW & JPEG, the buffer can't handle it. So unless you'll only shoot JPEG for BIF you'll want a bigger buffer than the SL-1 has.
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
OP with lots of gear but no idea Regular Member • Posts: 240
Thanks both for your replies. I have decided to hold fire on a change for the moment and keep with two cameras. This will allow me to possibly treat myself to some glass.
