The Nikon F-mount has a bigger distance from mount to film/sensor (flange distance) than the Minolta mount. This means that there is no space for a normal adapter. Only solution: an adapter with built in teleconverter.Hi,
I need an adapter for my Minolta MC/MD to Nikon F mount. If anyone has done this successfully-- may I please have the info a/o a link. Right now I'm too brain fried and bleary eyed.
THANKS
Sadly, I can see the difference clearly even without looking at the full size -- although it sure is dramatic (traumatic) at full size! That's even worse than I got on my Sony A-mounts using an old Spiratone glass converter from MC->A: all my converter did was add an unpleasant amount of glow (SA) -- it didn't smear things. In fairness, a Nikon glass converter should be slightly worse because the Nikon mount is a little farther back, so it has to magnify slightly more, but I wouldn't have expected this much difference....You'll need to look at the full size images to see the difference.
