Does the manual focus ring of a EF-S USM lens (17-55mm f/2.8 IS) need electricity to work?
Started Jan 16, 2017 | Discussions
FotisK Junior Member • Posts: 38
Hi! A friend wants to adapt his EF-S 17-55mm f/2.8 IS USM (Ultrasonic) lens on a GX1 (micro 4/3) body and we read that the simple adapters (that don't have electronics), won't work with most EF-S lenses since even the manual-focus ring needs power to operate!
Anybody who knows if this particular lens can manual focus without electricity?
Thank you!
Canon EF-S 17-55mm f/2.8 IS USM Panasonic Lumix DMC-GX1
GordonAtWork
GordonAtWork Regular Member • Posts: 482
Re: Does the manual focus ring of a EF-S USM lens (17-55mm f/2.8 IS) need electricity to work?
Hi,
The USM on this lens is the ring type and will allow full manual focus without power.
It's the aperture you will have problems with as it's electronically driven so the lens will have to be used wide open.
Signature ? You can't handle my signature !!
 GordonAtWork's gear list:GordonAtWork's gear list
Canon EOS-1Ds Mark II Canon EOS D60 Canon EF 20mm f/2.8 USM Canon EF 50mm F1.4 USM Canon EF 400mm f/5.6L USM +9 more
OP FotisK Junior Member • Posts: 38
Thank you @GordonAtWork!
