Picture break
Started Jan 16, 2017 | Discussions
newmikey Veteran Member • Posts: 5,203
Picture break
Just a few shots to take us away from discussing the K-70, K-1 or K-P and remind everybody that the K-5 II(s) series can still deliver! The first three were shot with the DA*50-135mm/f2.8 and the last two with a Revuenon 55mm/f1.2
 newmikey's gear list:newmikey's gear list
Pentax KP Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 85mm F1.4 EX DG HSM Pentax 16-85mm F3.5-5.6 WR +2 more
Pentax K-5 IIs Pentax smc DA* 50-135mm F2.8 ED (IF) SDM
philzucker
philzucker Forum Pro • Posts: 10,390
Re: Picture break
Like #2 very much, and love #3 - what are we looking at there? Great catch & framing!
Phil
robbo d Veteran Member • Posts: 3,884
Re: Picture break
I don't get too caught up with surmising about new gear which comes up every 12 months ........... but I have the K5iis and together with nice glass can still kill a great image.
Nice shots.......
This taken last night in a rare walkabout for me with cam in hand. Lowering light handheld, city in contrast, Perth, Western Australia.
MightyMike Forum Pro • Posts: 41,691
Re: Picture break
Nice photos, but your sharpening seems a bit harsh, unless you were being artistic about it.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
OP newmikey Veteran Member • Posts: 5,203
Hi Phil
It's part of an announcement board near the beach access at a small North-sea village called Castricum, in the North-West of the Netherlands. The board itself is made of what seems to be washed-up wood and an artist drilled through some stones he found and stacked them on top - that's "modern art" for you!
I pulled an image off Google Maps for context:
Right on the money!
It is an effect of a GMIC script I used based on this discussion: https://pixls.us/articles/highlight-bloom-and-photoillustration-look/
It gives some interesting results which may or may not be to everyone's liking of course. In this case and with these images I used it on purpose so you are quite correct about the sharpening!
Mike
philzucker
Re: Hi Phil
Interesting. Been to Zandvoort, Amsterdam and Enkhuizen in this region, but have never been there ...
Works for me! As I said good framing - you saw the graphic potential in that very well.
Thanks very much for that!
Phil
Twong Contributing Member • Posts: 849
Re: Picture break
#2 is my favorite. Good work and desperately needed break from talks of camera bodies.
 Twong's gear list:Twong's gear list
Olympus PEN E-PM2 Pentax K-3 II Pentax smc FA 50mm F1.4 Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Sigma 70-200mm F2.8 EX DG OS HSM +18 more
miles green
miles green Veteran Member • Posts: 7,827
Re: Picture break
Thank you for the much-needed picture break!
I really like these, a little abstract/geometric, a little nature, a little human intervention, a recipe that's just right for my taste!
Can you share some post-processing tips?
Miles Green
Pentaxian with chronic LBA since 1997
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
Ouch! That is a haaaaard question to answer!
I find that extremely hard to answer as I fiddle around so much with my images and my processing varies along with the direction the wind is blowing
One thing I do end up doing a lot is to always grab a hand-held bracketed series of 3 shots (-2, 0 and +2) as a basis. Whether or not I end up using all three or not is decided on behind the computer.
I often experiment a bit with HDR (all of these were based off HDR versions of 3 exposures) trying to get detail in all areas. Usually I'm aiming for a more or less "natural look" , not the extremely colorful HDR's you sometimes see. I save the result of tonemapping as a 16-bit LDR image to avoid banding and deterioration.
Sometimes the tonemapped file needs only a bit of tweaking of the levels or curves and a bit of WB fiddling but I also use a lot of editing in Gimp (the newer 16/32 bits version) to remove distractions like roadsigns etc. There are a couple of scripts I use either with ImageMagick to generate an Orton-effect or with GMIC to get a more graphic representation (such as f.i. in https://pixls.us/articles/highlight-bloom-and-photoillustration-look/ )
Cropping and keystoning comes last after which I save the result as a jpeg file.
But that's just me and then even only the past few months until another way of processing grabs my attention - I love experimenting. Sometimes I do a lot of long exposure stuff using 10-stops ND filters or horizontal pano's to decrease the apparent DOF (not quite true Brenizer effect but something along those lines).
I could go on and on - I don't really have a "silver bullet" or a personal style to be honest. It's more of a spur-of-the-moment thing with me ... I just mess about a bit after reading up online. Maybe the fact that I'm using ever-evolving open-source stuff that requires a lot of fiddling about (Tommy - The Who reference unintended).
Mike
Dariousz
Dariousz New Member • Posts: 21
Re: Picture break
x2. Despite being an old camera, the 5IIs carries on being amazing.
 Dariousz's gear list:Dariousz's gear list
Pentax K-5 IIs Pentax K-3 II Pentax smc DA* 55mm F1.4 SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Samyang 16mm F2 +1 more
miles green
Re: Ouch! That is a haaaaard question to answer!
aaaah, i see!
i like them better too.
I've gotta download that ASAP, I'm still running the old 8-bit version.
interesting. i've been meaning to shoot some of those, using two images (=without cheating)!
i use that one for portraits sometimes
Very interesting indeed.
It shows that these evidently simple images have been cared for extensively (and subtlely) to make them look this good. Nicely done!
Mike
Thanks for sharing Mike,
Kind regards,
Miles
Miles Green
Corfu, Greece
